An Example of a Risk Analysis Report for a Class II Medical Device (Oxygen Mask)
terrans
#21
Re: A sample of a Risk Analysis Report - Class II Medical Device (Oxygen Mask)
I was wondering if you could help. I have completed a pFMEA and dFMEA for class 1 medical device.and now need to complete a risk analysis report. Would you be able to point me in the right direction of an example of a completed risk analysis report template, that I could use as a guide.
Bill Evans
#22
I was looking for guidance on the report and did not see a response here. Does anyone have a format/template?
Ronen E
Problem Solver
Moderator
#23
Clarification required please.
There are multiple references in this thread to "report". Which one are you referring to? Also, what guidance are you seeking? The more specific you are, the higher the chances someone will be able to help you.
Similarly what template are you looking for?
Cheers,
Ronen.
Bill Evans
#24
Ronen
I was looking for an example or template for a risk management Report....NOT...The ISO 14971risk management File
Ronen E
Problem Solver
Moderator
#25
Ronen
In my understanding the risk management report is a subset of the risk management file, either as an integral part of a single computer file or as a separate referred document in a paper or electronic binder. In the example provided by Steve K (post #10 in this thread) it is, in my opinion, the former - refer to the part that starts at "Estimation of Risk". Perhaps it's not what you are used to or expected to see, but in my understanding it covers a low-risk device and apparently it is fit for purpose (audit-proof). Yours might require something more elaborate or a different format, however I am not aware of a "preferred" or "standard" such format. If your measure is not ISO 14971, the contents of your report should be governed by some other frame of reference, which will determine what would be "sufficient".
If you are referring to some expectation established by the FDA, please provide more details. I'm not aware of any such well-defined expectation, but I've been through instances where FDA had field-established practices which were not backed by explicit regulations or even by published guidance (either draft or final).
Marcelo
#26
The (revised) risk management report from the 2007 versions require only one thing - the review of the process (and the answer of the 3 topics - the risk management plan has been appropriately implemented, the overall residual risk is acceptable, appropriate methods are in place to obtain relevant production and post-production information).
As most of the information is usually elsewhere, this is usually a 1-2 pages document that simply show that the plan was followed (linking to the records that show this), that the risk is overall residual acceptable (linking to the overall residual risk analysis) and linking to the pms procedures and planning.
Maybe you are confusing the report (which had a lot of other requirement in the 2001 version) with what is usually called the risk management summary that is used to show traceability and comply with 3.5 (as this was one of the things the 2001 originally required).
Jeffers
#27
Michael,
Another beginner question, but regarding the risk management report according to ISO 14971. Our QMS is 13485:2012 and we manufacture a class II medical device. We perform clinical evaluation using literature review, PMCF and PMS activities. In the report, we draw a conclusion about risk, and obviously that "all risks that result from use of the product are outweighed by the benefits provided by the product". this is our CLINICAL EVALUATION REPORT.
As part of our technical file review, our reviewer is asking for our risk report. Can this serve as a risk report according to 14971?
Ronen E
Problem Solver
Moderator
#28
Michael,
the manufacturer shall carry out a review of the risk management process. This review shall at least ensure that:
⎯ the risk management plan has been appropriately implemented;
⎯ the overall residual risk is acceptable;
⎯ appropriate methods are in place to obtain relevant production and post-production information.
The results of this review shall be recorded as the risk management report and included in the risk management file.
(From ISO 14971:2007 s. 8. Emphasis added.)
Jeffers
#29
Ronen, thank you for the great feedback on this forum and the others where I have posed some questions. I am using the referenced standards, but maybe I need to be a bit more clear on my question.
I have a clinical evaluation procedure in place that results in a documented literature search every 5 years, or when any activity from PMS or PMCF reveals a cause to re-evaluate the risk profile. The results of this are written into a clinical evaluation report (CER).
Is there any reason why I cannot include a description about the risk management plan, overall residual risks are acceptable, and that appropriate methods are in place to obtain relevant production and post-production information within the CER? If I effectively communicate these points, can I title the document "Clinical Evaluation Report and Risk Management Review", and cover both points within one document?
Ronen E
Problem Solver
Moderator
#30
I don't see why not, but I'm not your auditor.
Just make sure that a reference in your risk management file points to that document when you get to the Risk Management Report item.
M An example of risk analysis of class I MD ISO 14971 - Medical Device Risk Management 36
J Does anyone have an example of Risk-Benefit Analysis per ISO 14971? Other ISO and International Standards and European Regulations 2
B Section 7.2.2.2 Organization Manufacturing Feasibility - Risk Analysis example? IATF 16949 - Automotive Quality Systems Standard 1
O Example Risk Analysis Procedure or Flow Chart - TS 16949 Document Control Systems, Procedures, Forms and Templates 2
Q Example of the Risk Template Document Control Systems, Procedures, Forms and Templates 1
M Risk managment report of Surgical Mask Example ISO 14971 - Medical Device Risk Management 14
A 5 x 5 Risk Matrix - Looking for a good example Manufacturing and Related Processes 2
D Validation of existing equipment - Risk based approach example ISO 13485:2016 - Medical Device Quality Management Systems 3
M Example ISO 14971 policy and risk criteria ISO 14971 - Medical Device Risk Management 0
O Example of Turtle Diagram with Risk/Opportunities General Auditing Discussions 1
B Process Risk Assessment Example for a Manufacturing Company Quality Tools, Improvement and Analysis 2
P Example Risk Assessment for CAPA's Document Control Systems, Procedures, Forms and Templates 5
M Example of a Risk Assessement File for Medical Device Other ISO and International Standards and European Regulations 5
S Aspect vs. Impact and Hazard vs. Risk - Short/clear explanation & example Miscellaneous Environmental Standards and EMS Related Discussions 11
D AS9100C Risk Management Procedure Example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 111
K Risk Management Policy example and advice wanted ISO 14971 - Medical Device Risk Management 3
O Supplier Risk Assessment template or example needed Supplier Quality Assurance and other Supplier Issues 5
D Risk Assessment - Problem Management Process - Seeking Model/Example Software Quality Assurance 1
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
optomist1 Paynter Chart Example APQP and PPAP 1
M Data Protection and Privacy Policy - looking for a template/example EU Medical Device Regulations 1
A Verification protocol example Design and Development of Products and Processes 2
Q Example Process orientation to the process leadership, management, goals (tasks of the top management) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
N Post Market Surveillance Package Example Wanted ISO 13485:2016 - Medical Device Quality Management Systems 1
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
D Redacted 510(k)s - Example wanted Document Control Systems, Procedures, Forms and Templates 17
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
Jimmy123 Example of a P-Diagram for Process FMEA - Uncontrollable noises FMEA and Control Plans 39
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A ISO/TS 22163 Item 5.2.4 Safety policy - Example wanted Other ISO and International Standards and European Regulations 2
F Internal Audit - Procedure example Internal Auditing 5
I Functional Safety Analysis/Report Example IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
H Man Hour Plan 145.A.30 example needed EASA and JAA Aviation Standards and Requirements 0
R Real Example of a currently marketed Procedure Pack CE Marking (Conformité Européene) / CB Scheme 1
D Example for Accessories of "Annex XVI non-medical devices" and how to classify it now with respect ot EU MDR Other Medical Device Regulations World-Wide 1
MichaelDRoach Oganization's Self Declaration of Conformance to ISO 28000 wording example wanted Supply Chain Security Management Systems 1
A Australia TGA Medical Device Sponsor Agreement - Example or Template Other Medical Device Regulations World-Wide 18
J ISO 13485 8.4 Analysis of Data - Procedure example ISO 13485:2016 - Medical Device Quality Management Systems 1
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
N ISO 9001: 2015 - Example standards policies, procedures, acknowledgements and checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M AS9100d (section 7.1.3) example of compliance in machine shop environment. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
supadrai How does the FDA count violations of, for example, misbranding? (Medical Devices) Other US Medical Device Regulations 1
E Labware cleaning validation protocol example Qualification and Validation (including 21 CFR Part 11) 1
D Laboratory Manual ISO/IEC 17025 Example wanted ISO 17025 related Discussions 2
P Template or example Excel list of ISO certificates issued to clients ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
