An ongoing EMC test in accordance with IEC/EN 60601-2-47 EMC
CreMindES
I'm a newbie on the field of medical standards, and I have a little confusion about an ongoing EMC test.
The product is an ECG Holter, marketed in manly in EU and Japan, and a member of the test facility wrote that he's certificating our product according to EN 60601-1-2:2007 and EN 80601-2-47:2010.
Well I haven't found EN 80601-2-47:2010. But we used EN 60601-2-47:2001, which we think we need as it is about ambulant products. Was it a typo? (I will contact with him, I just want to make sure before asking stupid questions)
The second confusion point is the same standard, the EN 60601-2-47:2001 - which I think is valid today - is referring to IEC 60601-1-2:1993. But there are newer versions of the latter (we use EN 60601-1-2:2007), and the points are not perfectly matching. It's kinda strange for me... I've searched around a lot, and found that there is a new version of the IEC 60601-2-47, published in february 2012. As far as I know, the harmonization of this standard is undergoing now by the EU and CENELEC.
My question and asks are:
- Was I correct in the aboves - dates, valid standards, etc?
- Should we use the IEC 60601-2-47:2012 or the EN 60601-2-47:2001?
- Can you give me some clarification about all this to see clear?
Thank you for your help, it's really appreciated as I'm quite new to the world of medical standards!
p.s. It's kinda interesting too, that an ambulant holter, which is recording 24h ECG signal usully, have to confirm such strict standard, particuraly 3V/m 80-1000MHz /according to 60601-2-47:2001/ without significant distortision in (such a low voltage) signal /according to 60601-1-2)/. I mean, if the user doesn't keep the 2,5 meter distance in case of a cell phone (3V/m) or crossing an EMI source and the recorder losses 30 minutes maximum, there will be 23,5 hours of good measurement. Of course we are designing to pass it easily (as a user won't keep that distance) but it looks a little bit to strick at first glance.
Re: Iec/en 60601-2-47 emc
The new version of -2-47 (which as you say was published by IEC in Feb of this year) is edition 2 and replaces the 2001 edition 1. So, at a guess, the reference to a 2010 version is a typo by your test house.
It will take some time for the IEC version to become the EN version; I can't see any mention of it as a "work package" at CENELEC, who do this part of the process. Once it becomes an EN standard it can then be listed in the Eurpoean "Official Journal" to become a harmonized standard that is fully accepted as satisfying all the essential requirements of the European medical device directive.
However - the new version of -2-47 aligns with Edition 3 of the base standard (60601-1) and 60601-1-2:2007. As such it will contain details of the "Essential Performance" required of your device during the EMC tests. It will contain details of how the tests are to be applied and how much distortion or lost signal is to be allowed. As such, I would suggest that it would be very useful to the application of the tests.
I would use the new standard. It also allows some "future proofing". If your Notified Body auditor raised any objection to using a "not EN" standard I would provide a comparison table showing the test requirements from each version, and how the new tests are more rigorous and cover more requirements than the old version (it is unlikely that they would be easier!).
Oh - and welcome to the forums!
CreMindES
First of all, thanks for your detailed answer, it was really helpful. It's good to know that there are place and people like you who you can turn to for help in such cases! :)
As my company doesn't have the new IEC 60601-2-47:2012 version, may I ask you to explain what does it mean by "future proofing"? (as currently we are applying some shielding on our device - as it is an older product, where EMC was mostly out of the designer's scope - to be able to meet the immunity requirements)
My apologies if my use of jargon has made my answer less clear.
I have not seen either version of -2-47 but I would expect that the new version has more requirements and that existing ones are more stringent. If you work to these new requirements then, in 3 or 4 years when the new version of the standard is the only one allowed, you would not have to update your design.
CreMindES
Sorry for my misunderstanding. The mentioned product wasn't designed according to every aspect of EMC unfortunately. That's why I wanted to clear up things regarding how much effort should we take into this hardware revision.
Of course, our focus will be on the new version when developing new products, it will be a good challenge I think :)
Thank you for all your help, it was really helpful! Have a nice day!
billarcher
Hi Pads38
I apologise in advance for this verbose query but I am at my wits end!
I’m QM for a product that has been in the market since early 2007 (via three different owner companies) that has undergone regular Tech File audits with two of the UK’s top NB’s in that period. The first three audits were done by one of the UK’s largest over 4 years and then the owners decided they wanted to change to another company, which was fine. The new NB also carried out the Tech File audit to their satisfaction but stopped offering FDA registration for future development, so I suggested to my new boss that they go back to the former NB which they did.
When we had our Tech File audit recently by the original NB (nothing at all has changed on the product in any way), we had a Trainee Auditor (who had been with them two years) examining our files, who in turn was being monitored by an Assessor.
To our complete surprise one of the NCs they came up with was (and I quote exactly):
Non-Conformity:
“Relevant test reports were not available to demonstrate compliance with Essential Requirements
Requirement (Annex V, Section 3.2d):
“Application of the quality system must ensure that the products conform to the provisions of this Directive which apply to them…the appropriate tests and trials to be carried out before…manufacture…”
Objective Evidence:
“The following test reports were not available: 60601-1, 60601-2-10 to demonstrate compliance with the following essential requirements: 7.1, 7.5, 7.6, 9.2, 9.3 , 11.1, 11.3, 12.6, 12.7, 12.8”
We did have EMC report done by an EMC Test house, costing ?440 (which had been approved by them as well as the other NB several times) which the NB said was not acceptable as it was done by a University Testing Facility rather than an Accredited Test House. So we looked up ACH’s on the appropriate sites and asked for quotes.
These quotes came back at rates between ?8,250 and ?16,700 which was utterly ridiculous and when we asked for justification, verification and validation of these outrageous prices, we were met with comments like: “that’s what it costs us to cover our overheads” and so on…totally perplexing to say the least.
So, in desperation, I showed the Assessment Report to another NB representative for comment and here’s what I got back, which destroyed my faith in both the NB and the ACHs to be honest:
“What I’m saying is your NB’s report is extremely vague in defining what your missing regards to tests.
Just pointing to the ER’s is not helpful, for you the client, or any other assessor.
However you only need to demonstrate that you meet the ER’s, you do-not need to demonstrate you comply with a standard.
If you go through the ER’s
7.1 = biocompatibility
7.5 = phthalates ?
The first two are from you biocompatibility data, not a test house
7.6 = ingress of substances into the device
9.2 = Ergonomics, electrical influences, interference
11.1 = protection from radiation
11.3 = unintended radiation
12.6 = electric shocks
12.7 = protection against mechanical and thermal risks
12.8 = energy supply risk
These 7 are what you need to provide test results for.
For completing the relevant tests to show that the product meets the Essential Requirements I would suggest that the “test house” restrict the testing to these requirements and not complete a full set of tests against the standards mentioned, as this would dramatically and needlessly increase your costs without any benefit.”
So, here’s my problem: I have been totally unable to get ANY of these test houses to give a quote for what we need to cover the above – they all say we should have the full test programmes done which is clearly not true!
Does you know an Accredited Test House that will provide the service we require as indicated by the NB advisor above? Any help will be hugely appreciated!
Regards
Bill
M Informational EU – Ongoing Guidance development within MDCG Subgroups Medical Device and FDA Regulations and Standards News 1
T Timely Closure and "Ongoing" Corrective Action Nonconformance and Corrective Action 15
G Managing Ongoing Compliance to Standards when they are Changed Misc. Quality Assurance and Business Systems Related Topics 3
M Is Validation an ongoing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G Ongoing Cpk and Global/Historical Data Statistical Analysis Tools, Techniques and SPC 7
G Cpk, Subgrouping, and Can Attribute Charts Monitor Ongoing? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Ongoing Stability Testing required for DES? Drug Eluting Stent EU Medical Device Regulations 4
G Change of procedure for handling new projects - do the ongoing ones need to follow? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit questions and plan for ongoing audits of ISO13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 5
M Sustaining the 5S (Five S) Program - What can I do to keep the effort ongoing? Quality Tools, Improvement and Analysis 2
M 4.9.2 Maintaining Process Control - Maintaining ongoing process capability QS-9000 - American Automotive Manufacturers Standard 13
D Essential performance and EMC immunity testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M IEC 60601-1-2 EMC Tables IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
L IEC60601-1-11 Home Healthcare + IEC60601-1-2 EMC (Functional Earth allowed?) IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M EMC Directive and product safety standards CE Marking (Conformité Européene) / CB Scheme 1
B Evaluation of Basic Safety during EMC Immunity or Climate Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B Does EMC Directive 2014/30/EU cease to apply when the Machine Directive 2006/42/EC is applicable? CE Marking (Conformité Européene) / CB Scheme 4
H External power supply - requirements in safety/EMC test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
F EMC testing for a system that is provided with a computer IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
O EMC - EFT (Electrical Fast Transients) on SIP couples erroneously with other cable CE Marking (Conformité Européene) / CB Scheme 1
K Is a 3V torch classified as medical electrical equipment needing EMI/EMC testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Arguing with the test lab about failing in an EMC test IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
E Airborne Medical Equipment EMI/EMC IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Portugal ISO 13485 Certification and EMC Test Houses Other Medical Device and Orthopedic Related Topics 3
T Question: Do we consider 60601-1-2 (4th ed) EMC testing a mode for a diagnostic port? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
O Medical Device EMC Risk Management CE Marking (Conformité Européene) / CB Scheme 4
O Guide on EMC for Functional Safety CE Marking (Conformité Européene) / CB Scheme 3
T CE Marking & Compliance to MDD, EMC, RoHS, and GPSD REACH and RoHS Conversations 4
J IEC 60601-2-2 - EMC Requirements - Surgical instrument manufacturer IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
O EMC testing per IEC 60601-1-2 for considering new cables CE Marking (Conformité Européene) / CB Scheme 1
O EMC testing under RED and IEC 60601-1-2 CE Marking (Conformité Européene) / CB Scheme 1
D EMC Testing for a Production Fixture CE Marking (Conformité Européene) / CB Scheme 0
Q IVD vs EMC OJ (Official Journal of the European Union) Harmonised Standard Conflicts EU Medical Device Regulations 1
A EMC Emission Issues - Communication between PC and Monitor IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Is EMC + Radio Re-Test Required? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E Particular standards, essential performance in EMC Immunity Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F EMC (Electromagnetic Compatibility) Conformity Charts - IFU Requirements Misc. Quality Assurance and Business Systems Related Topics 3
G CE Marking - Low Voltage Directive and EMC Directive CE Marking (Conformité Européene) / CB Scheme 4
T Firmware version in EMC report / DoC CE Marking (Conformité Européene) / CB Scheme 1
W EMC, ESD for battery operated apparatus Other Medical Device and Orthopedic Related Topics 1
N New EMC IEC60601-1-2 4.0 Ed. Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
B What is our requirement for maintaining the EMC series of standards? IEC 61000 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P EMC requirements for an accessory to a medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
T EMC for Medical Devices in Home Environment Other US Medical Device Regulations 4
J EMI/EMC Test differences for Radiography Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M EMC Testing for a US-only, Home-Based Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B Safety & EMC certificate updated when MCU (MIcro-Controller) is changed? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T EMC Tests - While certified power supply is part of device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B EMC Repeat Justification - Reducing NRTL testing required after modification of ME IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C EMC Test Report Requirements to IEC 60601-1-2:2009 ISO 13485:2016 - Medical Device Quality Management Systems 4
