Analysing the data from three different cavities of one mould
I
ingov
Dear Cove members,
I have same gears from three different cavities of one mould and two pins in gearbox on which these gears are mounted and creates a gear train. We have the problem that in some combinations of the gears the gear train can't rotate smoothly. Is it possible a creation of a disigned experiment to find the right combinations(with that there is a smootly rotation)?
for instans I've tried the following design that covers all combinations of the gears, but i can't analyse it with Minitab because pin 1 and pin 2 are not factors (they are places where the gears are mounted)
gear 1 - pin 1 - gear 1 - pin 2
gear 2 - pin 1 - gear 1 - pin 2
and so on.
Any help will be highly appriciated!
Thank you in advance!
Steve Prevette
Deming Disciple
Re: analysing of the data
I'd first suggest some good measurement of the gears. If there is too much variation in the measurements, on a random basis some gears won't work with others, and testing pairs will just react to that random variation. However, if you find variation is small within each cavity, and there are signifcant differences between cavities, then you may be on to something.
Statistical Steven
Statistician
Dear Cove members,
and so on.
You can have pin be a factor in the study if you like...regardless you have the following combinations gears and pins
Pin 1 Pin 2
1 1
1 2
1 3
2 1
2 2
2 3
3 1
3 2
3 3
If you have repeats on the 9 combinations you can use a one-way ANOVA with 9 levels OR you can use pin as a factor and two-way ANOVA.
I
ingov
Thank you very much! I've just tried the two-way ANOVA, it gives good picture of which gear where can be mounted.
Have you done a quick MSA on the repeatability of the measurement of 'smooth'?
I would treat pin as a factor (because it is) and the two different pins as levels. Just like treating the 3 different molds as levels in the factor gear.
I would run the experiment with muliptle replicates of hte gears and pins. If you can collect gears and pins that came from assemblies htat are known to fail and known to be good it will reduce your replicate set for the DoE.
Once you have pairs that are very smooth and that are very 'not smooth', Steve P's idea of measuring the dimensions on the parts would work in telling you which factor(s) affect smoothness. measuring after the DoE will provide the large contrast in smoothness to be able to detect the characteristics with confidence...
S Need help with analysing a survey on minitab Using Minitab Software 1
V Analysing Results after DOE Using Minitab Software 1
R Analysing Scrap from Machinery Statistical Analysis Tools, Techniques and SPC 8
A Sample size selection for process validation - continuous data Reliability Analysis - Predictions, Testing and Standards 3
T CMM Max/Min data and Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
G Record test data into Word document Document Control Systems, Procedures, Forms and Templates 3
Stoic Warning letter examples for medical device companies related to the pharma guidance on data integrity? US Medical Device Regulations 5
C Primary data record ISO 17025 related Discussions 6
H Is it a requirement for run charts to have inspection data or can it have just a pass/fail check mark Records and Data - Quality, Legal and Other Evidence 4
I Brazil clinical data/trial requirement Other Medical Device Regulations World-Wide 1
W Part 145 Maintenance Data Review EASA and JAA Aviation Standards and Requirements 1
E Electronic Data Management ISO 17025 related Discussions 1
D ISO 14001 Finding - Missing Safety Data Sheets ISO 14001:2015 Specific Discussions 2
P Comparing Two Test Variables Using Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
K Before-After Data Analysis Statistical Analysis Tools, Techniques and SPC 1
D Gage type and data base maintainence Using GAGEpack Software 2
Dazzur Sharing Suppliers Performance Data with Supplier. Supplier Quality Assurance and other Supplier Issues 6
M Conducting a clinical investigation with clinical data from India EU Medical Device Regulations 3
T Data types vs Mathematical operations Six Sigma 4
T Gage R&R study - Ordinal data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
optomist1 Data Bias - Surveys Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Levels of actions and consequence to data integrity US Food and Drug Administration (FDA) 10
M ADME data- substances based MD EU Medical Device Regulations 0
B Can a software that receive data from a MD be classified as Class I?or is not a MD? EU Medical Device Regulations 5
T Process Potential estimation for binary data Capability, Accuracy and Stability - Processes, Machines, etc. 3
RoxaneB Data Storytelling Misc. Quality Assurance and Business Systems Related Topics 4
MaHoDie Summative Evaluation with Post-Market Data? Human Factors and Ergonomics in Engineering 2
J EU Data Act Medical Information Technology, Medical Software and Health Informatics 0
P Transferring medical data from a device (Sec 201(h)): regulatory implications US Medical Device Regulations 3
Z Change color or shape of individual data point in control chart Using Minitab Software 6
R FDA ECG Data Requirements Medical Information Technology, Medical Software and Health Informatics 3
T SQL Server 2019 - Master Data Services - Validation needed? ISO 13485:2016 - Medical Device Quality Management Systems 4
C Elaborating a control chart with skewed data Manufacturing and Related Processes 4
D Data normality versus capability Capability, Accuracy and Stability - Processes, Machines, etc. 11
I In-Process Inspection Raw Data ISO 13485:2016 - Medical Device Quality Management Systems 3
T Class III device and shelf life data requirements US Medical Device Regulations 7
S Discussion on OBL and OEM test data for submission as per new EUMDR EU Medical Device Regulations 0
C How to place software version for SaMD product in HIBC secondary data structure (UDI-PI)? Other US Medical Device Regulations 4
PQ Systems Better Data Visualization & Communication with Statistical Indices Using SQCpack Software 0
PQ Systems Data Entry Workflows with SQCpack Using SQCpack Software 2
PQ Systems Data Security in the Quality Industry Using GAGEpack Software 0
B Establishing a Data Analysis Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Fjalar ISO 20417:2021: Technical Data (6.6.4 c) Other Medical Device Related Standards 0
Z PMS Data collection for SAMD SaaS from clients EU Medical Device Regulations 3
S How to upload data in bulk on EUDAMED? EU Medical Device Regulations 17
M Validation of Data verification tool per 21 CFR 820 Quality Assurance and Compliance Software Tools and Solutions 1
J Stage 2 audit initial cert, few data points ISO 13485:2016 - Medical Device Quality Management Systems 4
placebo_master Risks of executing a verification protocol against existing data ISO 13485:2016 - Medical Device Quality Management Systems 4
Z Why Control Limits are not the same depending on type of exclusion of data points Using Minitab Software 7
D Question: How to analyze numerical and attribute data Reliability Analysis - Predictions, Testing and Standards 11
