Analysis & Closure of a Customer Complaint
benzkumar
Can somebody share the the presentation of a Customer complaint.
I mean from receiving the complaint, analysis part, taking certain actions, closure & effectiveness. Hope some companies make presentations of this.
The systematic way of handling a customer complaint.
Thanks,
Selva.
Marc
Fully vaccinated are you?
Maybe if you would give us an example of a customer complaint we could better help. There are many kinds of customer complaints so there are different ways to deal with them.
benzkumar
Hi Marc, Thanks again for your help,
For Example, We had an issue of a Hole manufactured undersize & shipped to customers.
Our End Customer couldn't able to use these parts & there is a serious line stoppage.
Can you pls, help me on this.
Marc
I would think for something like that you would do a standard nonconformance investigation with a standard corrective action. In short, an 8D type of approach.
An undersized hole is something that can typically be identified with a check at some point in the process.
You say it was a line stoppage issue so it is a critical aspect so you have to identify how it escaped in addition to how the error occurred in the first place.
Essentially, however, you would use the same process (nonconformance & corrective action) for a customer found nonconformance as you would if you identified the problem in-house prior to shipping.
K
kgott
I don't think a customer complaint should be treated any different from any other unwanted event with the exception of how you interact with customer. You need to communicate what corrective or preventative action you have taken but the process is much the same.
I would suggest that you would find it profitable to use an established investigate method such as 5 whys or root cause anaylses etc to show the customer you have in fact found and dealt with the root cause and not just stopped at the person level.
Mike S.
Happy to be Alive
The basics, IMO:
Acknowledge the complaint.
Try to get the customer compliant product ASAP to eliminate the line stoppage -- this is "correction" of the problem. You can hardly overreact here. Fly to the customer's place with good parts in hand the next day if you can. Let the customer know you are doing everything you can to stop the bleeding -- and do it!
Assure the customer you will perform a full, thorough root cause analysis and then implement corrective action(s) as appropriate, then do it and supply them with a report of same.
Follow up as needed.
B GR&R Destructive Data Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
H Risk Analysis and Probability of Occurrence ISO 14971 - Medical Device Risk Management 3
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
P Benefit risk analysis on pFMEA ISO 14971 - Medical Device Risk Management 9
Q Process map Evaluation and Analysis Method Process Maps, Process Mapping and Turtle Diagrams 5
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 7
J Starting a Weibull Analysis: Source on how to perform Weibull Reliability Analysis - Predictions, Testing and Standards 2
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
JoCam MDR Gap Analysis - Consultant fees EU Medical Device Regulations 10
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
A Attribute Analysis for colour matching scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Recurrent event analysis software (python) General Auditing Discussions 2
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
M MDSAP and 13485:2016 gap analysis Quality Management System (QMS) Manuals 1
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 12
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
R ECG Risk Analysis Standards ISO 14971 - Medical Device Risk Management 2
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
H ISO 13485:2016 Gap Analysis by NB ISO 13485:2016 - Medical Device Quality Management Systems 7
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Looking for a EU MDR Gap Analysis template EU Medical Device Regulations 6
M What is PESTLE Analysis and is it mandatory? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M IATF 16949 (6.1.1 - Planning and Risk Analysis for a remote site) Process Maps, Process Mapping and Turtle Diagrams 5
D Risk Analysis & Technical File - What detail goes in the Risk Management Report ISO 14971 - Medical Device Risk Management 5
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
M 10993-11 vs 2006 gap analysis Other Medical Device Related Standards 2
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
Nicole Desouza AS 9100 Rev D Gap Analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M An example of risk analysis of class I MD ISO 14971 - Medical Device Risk Management 36
R AS9100 REV D gap analysis matrix AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
F ISO 17025 8.6.2 Customer Feedback Analysis ISO 17025 related Discussions 5
M MDR Medical devices Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 2
L UDI Requirments Gap Analysis - EU MDR vs FDA CFR EU Medical Device Regulations 8
A Statistical Analysis - Check if these organisms at different concentrations affect the growth of wheat seedlings Using Minitab Software 4
