Analysis of Customer Surveys - Auditor not satisfied
millie6901
Registered Visitor
Hi ! All
Anyone can help me on this matter, i had a NCR from the auditor that the "customer survey yet to analysis" i had show her the survey form that from customer. Customer satisfaction index for the Quality OBjectives that customer required example LIPAS.TPT, Yield , Customer complaint.. but the auditor still satify.:(
Aaron Lupo
millie6901 said:
Hi ! All
Was the N/C for not analyzing the data you received from the customer surveys? It sounds like what they are saying from what you stated is that yes you sent the survey(s) but now you need to take the information you received and analyze it to see where you stand as compared to your objectives.
Rob Nix
In addition to Aaron's point, they might also be looking to see what actions you have taken based on the analysis. If other words, are you doing anything different now that you have learned what concerns your customer?
K
kei_ko
refering to ISO9001:2000 8.4 Analysis of data:
The organization shall determine, collect and analyse appropriate data to demonstrate the suitability and effectiveness of the quality management system and to evaluate where continual improvement of the effectiveness of the quality management system can be made. This shall include data generated as a result of monitoring and measurement and from other relevant sources.
:read: i am not sure how it is done in TS16949 but it looks like you have done the action in blue text (see above) but not the action required in red text... am i making sense? :yes:
basically, you may need to come up with action plans to improve the customer survey scores in addition to reporting them and stopping there :nope:
:bigwave: hope that helps
millie6901
Registered Visitor
TQ, very much for the response & idea, i think i need to change the current survey format that i can used the "figure" for analysis.
Is that anyone have the example of the customer survey form.
millie6901 said:
Hi ! All
Which section of the standard was cited, Analysis of Data or Customer Satisfaction?
The measures that you listed appear to be reactive measures of customer disatisfaction. The standard requires a proactive evaluation of customer satisfaction.
If it is the Analysis of Data, the expectation is that you will review the results, identify areas for improvement, develop action plans and implement them.
Caster
An Early Cover
Surveys are only one way
Millie6901
Surveys are not required. There are MANY differenct methods to measure customer satisfaction. Search the Cove for dozens of excellent ideas.
But no matter what method you use, the expectation is that the information is analyzed and reacted to "as required" based on the analysis.
So at the extreme of simplicity, every person who contacts the customer could post a "feeling" from their visit from "customer delighted" to "customer mad as heck".
During the management review, this collection of "impressions" could be looked at. If all is good, no action is needed. If all is not good, something needs to happen. The analysis and action are shown to have happened during the meeting.
As simple as this sounds, I think it is more effect than "surveys". If you are eyeball to eyeball with the customer you know for sure how they feel.
Howard Atkins
Forum Administrator
Caster said:
Millie6901
I agree totally, to many companies think that send a survey is the answer to all problems. The lack of analysis is also prevelant.
I was at an audit where the question arose about the level of customer satisfaction and the marketing dept said but that is the Quality functions responsibility to collect the info. It's nothing to do with me!!!!!:mad: :mad:
Statistical Steven
Statistician
Customer surveys are worth the paper they are printed on (or the electrons used for an online survey). Unless your survey is well designed, you will always suffer from bias. It is this bias that makes interpretation hard. Sending a form to all customers, does not mean you will get back a representative sample of the customers.
Having said that, measuring customer satisfaction is usually accomplished through analysis of a complaints data base (another faulty measure). Monitoring complaints or percent complaints or complaints per 1000 units, etc are just surrogates for customer satisfaction. The real issue is can you take action and improve on the data you received even though it might be flawed.
I worked with a customer who measures complaints per month. They have an internal requirement that complaints must stay below 100 per month. They average about 10 complaints a month. I got involved in helping to reset the requirement because they got an audit finding when they had a month with 75 complaints, but did not take action. We had to create a statistical method to "normalize" the complaints because the 75 complaints also reflected a 35% increase in sales, therefore leading to a higher customer base to complain. When normalized, the 75 complaints was no different than the 10 complaint average they were used to seeing.
I used that example to give you an understanding that measuring customer satisfaction is not easy, and having a metric or improvement plan for it is even harder!
P
preetham - 2007
Hi all,
I would like to put my comment on this issue.
To my observations every ISO certified company will send a format to their customer to get the feedback from them about the satisfaction level about them.
BUt it is the customer, who will not respond to them in many cases.
In these situations can we convince the auditor saying that we had sent a format of customer satisfaction to our customer but the customer has not responded to us.is it a proper justification method of not getting the customer reply:confused:
S Customer Satisfaction Surveys - Response Rate, Analysis, Customer Feedback ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A Marketing Survey Analysis of Customer Surveys using Minitab Using Minitab Software 1
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
F ISO 17025 8.6.2 Customer Feedback Analysis ISO 17025 related Discussions 5
S Customer Scorecard Analysis Templates and Examples IATF 16949 - Automotive Quality Systems Standard 3
Z Customer Satisfaction Survey Analysis Quality Tools, Improvement and Analysis 2
B Analysis & Closure of a Customer Complaint Customer Complaints 6
K Audit NC - No evidence of a full 5 Why Analysis for the Customer Complaint Problem Solving, Root Cause Fault and Failure Analysis 8
A Minitab for Customer Satisfaction Analysis Using Minitab Software 1
K Do all Customer Complaints require Root Cause Analysis? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Customer Service & Risk Analysis Misc. Quality Assurance and Business Systems Related Topics 8
S Customer Complaint Analysis Software Service Industry Specific Topics 3
M Data Analysis Software Recommendations - Complaints, CAPA, NCMR, Customer Feedback Quality Assurance and Compliance Software Tools and Solutions 7
V What regression analysis to use on customer satisfaction data vs. other drivers? Statistical Analysis Tools, Techniques and SPC 2
S Another TS 16949 Dilemma - Analysis of Data 8.4 a) customer satisfaction (see 8.2.1) IATF 16949 - Automotive Quality Systems Standard 5
Peter Fraser Customer satisfaction analysis software Quality Assurance and Compliance Software Tools and Solutions 2
O COP (Customer Oriented Process) for Market Analysis IATF 16949 - Automotive Quality Systems Standard 2
A 6.3 Infrastructure - 8.2.1 Customer Satisfaction - 8.4 Data Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 3
J Starting a Weibull Analysis: Source on how to perform Weibull Reliability Analysis - Predictions, Testing and Standards 2
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
JoCam MDR Gap Analysis - Consultant fees EU Medical Device Regulations 10
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
A Attribute Analysis for colour matching scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Recurrent event analysis software (python) General Auditing Discussions 2
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
M MDSAP and 13485:2016 gap analysis Quality Management System (QMS) Manuals 1
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 8
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
R ECG Risk Analysis Standards ISO 14971 - Medical Device Risk Management 2
H ISO 13485:2016 Gap Analysis by NB ISO 13485:2016 - Medical Device Quality Management Systems 7
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Looking for a EU MDR Gap Analysis template EU Medical Device Regulations 6
M What is PESTLE Analysis and is it mandatory? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
