Analysis of Data (Rookie Auditor Needs Help) - AS 9100 8.4
Brian0612
I am conductiong an internal audit for AS9100 8.4 and I am having a problem getting the employees that I am interviewing to understand my audit questions. I am asking how is data analyzed to demonstrate the suitability and effectiveness of the quality management system. I ask this question in relation to Customer Satisfaction, Conformity of products, suppliers, etc.
Can someone give me an idea as to how to better explain clause 8.4 to make it easier to understand?
What would be a good example of an answer to the above question which would demonstrate compliance?
Thanks in advance
Brian
K
kiwisfly
Re: AS 9100 8.4 Analysis of Data (Rookie Auditor Needs Help)
Hi Brian
Customer satisfaction data can be gathered by a survey. You could check the analysis of this data by asking the Managers what review of the survey responses was undertaken, what trends or comments were noted, what action has been taken to address the results of the analysis.
For non-conforming product, data from the production line detailing non-conforming product could be analysed to find root causes of the faults, general trends and overall lowering of Cost of Quality.
Supplier performance could be analysed against metrics such as on-time delivery to your plant, quality of products delivered and how quickly suppliers respond to problems when they arise. Improving this results in a more efficient supply chain.
I hope this helps.
howste
Thaumaturge
Clause 8.4 is not a stand-alone clause - it's joined at the hip with 5.4.1, 5.6, and 8.2.3 (among others). In addition, clauses 5.5.3 and 6.2.2e are relevant here.
For the process owner I would ask questions like:
"What's being measured that tells you the process is getting the results we need?
To employees working in the process (controlling outputs) I would ask things like:
"What feedback do you get that tells you your process works?"
"How do you know that downstream processes (and/or customers) get what they need from you?"
"What metrics can you have an effect on?"
By the way, everything listed in clause 8.4 (except supplier info) is required as inputs to the management review process (5.6.2). Supplier information is required in clause 7.4.1.
BadgerMan
I moved this thread to the Internal Auditing page leaving a permanent link from the AS9100 page. Hopefully we will get some good suggestions given the increase in traffic. :bigwave:
Randy
Who are you asking? If you're asking some floor flunky who isn't involved and couldn't care less the responses may be reasonable.
You 1st need to be sure you are asking for relevant information from relevant people.
Also, don't use compliance....use conformance.
Sidney Vianna
Post Responsibly
:agree1:That is an excellent point. The right question being asked to the wrong person is a source of many misunderstandings during audits.....
Brian0612
I am asking Department Managers. The answers I am getting includes the details of their process of data collection and analysis but does not include how they demonstrate suitability and effectiveness of the quality management system. Is the fact that they are performing data analysis and taking corrective action when appropriate enough to conform to the requirement? I have a surveillance audit next month and I want to be sure I'm OK.
Thanks for the input.
Jen Kirley
Quality and Auditing Expert
Thanks in advance
Brian
1) How can you tell if your process is going well or not? (What are the measures, what kind of data is used, how well it's understood)
2) What kind of measurements are taken during this process - do you use charts? Let's look at them please. (What are the measures, attribute or variable, how charted, how well the auditee understands what to do - going into SPC maybe)
3) Where do these numbers go? What happens then? What does that look like - can we look at examples please? (Who gets the data, how it's responded to, follow up/corrective actions linked to data, management review elements maybe)
Randy
Again the question may be incorrectly phrased..........Are you asking about the system or what they are responsible for?
Basically effectiveness is demonstrated when planned courses of action are achieved and are objectives met. You can find that out by looking at what was required to be accomplished and verifying its accomplishment through the records being generated.
You seem to be making a maountain out of a molehill and asking questions where the answers should be obvious.
Compare results to requirements when looking at data for effectiveness.
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
M Data analysis Design of Experiments Using Minitab Software 3
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
J ISO 13485 8.4 Analysis of Data - Procedure example ISO 13485:2016 - Medical Device Quality Management Systems 1
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
T Likert Analysis of Data from a Survey Statistical Analysis Tools, Techniques and SPC 6
E Risk Analysis - Events which may cause to Data Loss ISO 14971 - Medical Device Risk Management 12
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
M Treatment system data analysis - Subject to CFR part 11? Entire system? Qualification and Validation (including 21 CFR Part 11) 7
N Tool frequency change - Data Analysis needed Statistical Analysis Tools, Techniques and SPC 9
R Need Help on Analysis: How to know potential causality model from historical data Problem Solving, Root Cause Fault and Failure Analysis 5
R Variables Data Type Analysis help Quality Tools, Improvement and Analysis 4
M PCDMIS-Excel Data to Minitab for Analysis Using Minitab Software 2
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
A Recording Data and Data Analysis 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Y Statistical Analysis of Road Traffic Data Statistical Analysis Tools, Techniques and SPC 11
M PhD Thesis Data Statistical Analysis Methods Statistical Analysis Tools, Techniques and SPC 2
R MCF analysis with Left & Right Censored (Truncated) Data Reliability Analysis - Predictions, Testing and Standards 1
R Sample vs. Population (Data Analysis) Statistical Analysis Tools, Techniques and SPC 11
A Repairable System Reliability Analysis: Uptime/Downtime Hours, Failure Modes Data Reliability Analysis - Predictions, Testing and Standards 2
N Critical Analysis of Medical Device Bench Testing data ISO 13485:2016 - Medical Device Quality Management Systems 6
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
S Data for Analysis - Construction Industry Table of Data for Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
W What kind of data is expected for a PPAP Material Analysis Report IATF 16949 - Automotive Quality Systems Standard 7
optomist1 Data Analysis - Transform Data or Not Capability, Accuracy and Stability - Processes, Machines, etc. 9
R Capability Analysis (using Histogram) for Subgrouped Data Statistical Analysis Tools, Techniques and SPC 16
F Dealing with, and Analysis of, Data Statistical Analysis Tools, Techniques and SPC 6
T SPSS for Analysis of Medical Data - Need help Statistical Analysis Tools, Techniques and SPC 12
H Minitab DOE Analysis of Data and Transforming Using Minitab Software 4
Q What data analysis software do you use? Quality Assurance and Compliance Software Tools and Solutions 4
M Analysis and Use of Data clarification - TS 16949 Clause 8.4.1 IATF 16949 - Automotive Quality Systems Standard 4
K Non-Normal Data Analysis Literature, Websites, Books for Learning Quality Tools, Improvement and Analysis 2
G The Documentation of Data Analysis for an ISO 13485 Medical Device Submission ISO 13485:2016 - Medical Device Quality Management Systems 9
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
C Process Capability - Variables Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
Q Regression Analysis for the Attached Data - help needed - TIA Reliability Analysis - Predictions, Testing and Standards 13
F SPC Data Analysis - Excel Spreadsheet I can use for Diameters and Perpendicularity Capability, Accuracy and Stability - Processes, Machines, etc. 6
J Applicable Statistical Analysis Method for this Data Six Sigma 17
C Who does the Analysis of Nonconformances and other Data Analysis? Nonconformance and Corrective Action 23
Y Analysis of Data Procedure: Requirements for OBL (ISO 13485) ISO 13485:2016 - Medical Device Quality Management Systems 2
P Data Analysis - Johnson Transformation/Weibull Distribution/Capability Analysis Capability, Accuracy and Stability - Processes, Machines, etc. 15
A Best Way for SPC via Optical Comparator with output to Computer for Data Analysis Statistical Analysis Tools, Techniques and SPC 4
V Help on C Sat Data Analysis - Should I use discriminant analysis? Six Sigma 8
K Data Analysis of Milk Composition (Seven Parameters like Protein, Fat, Lactose, etc.) Using Minitab Software 18
7 Data Analysis of Tensile Strength Test - Graphical Presentation of Results Statistical Analysis Tools, Techniques and SPC 2
T Analysis of Sample Data Sets - Incidence of Canine Rabies Statistical Analysis Tools, Techniques and SPC 2
K GR&R (Gage R&R) Analysis for Negative Measurement Data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B FDA QSR Data Analysis & Trending Requirements US Food and Drug Administration (FDA) 5
Hami812 Normality of Data Question - Minitab Analysis Statistical Analysis Tools, Techniques and SPC 12
Statistical Steven Continuous Data Analysis Sample Size Determination Six Sigma 3
