Interesting Discussion Analysis of half normal distribution in minitab
01mercy
Hi all,
I have a very simple question. Is there a way to analyse half normal distributed data in minitab?
Like a process that has most of the time no deviation 0 and only deviates from the target in a positive tail.
And take from the analysis the distribution characteristics like stated in the wiki page below (variance, median)
Half-normal distribution - Wikipedia
There is no direct way to analyze a true half-normal distribution in Minitab. There may be indirect ways of which I am unaware. However, there are multiple distributions available in Minitab that will handle positive, right skewed data that may be a close match. What type of data do you have? Is this GD&T data such as position or flatness?
01mercy
Hello miner,
Thank you for your reply. Indeed, I understood today there are other distributions that I can apply like weibull and log-normal.
My question is related to another post of me on ppm calculations. Though I got there an alternative, I still need to challenge what is currently created as a model. In my view they didn't take in account this distribution. I will explain and try to keep it simple.
We have x amount of complaints per month
We have x sales per month
If there would be no delay between when product is being sold and the complaint comes in we could just calculate the fraction
(complaints / sales) per month.
However, there is a delay between time of sales and registration of complaint.
Of the total complaints we have a subset of which the serial numbers are known.
With that we know the delay time between sales and complaint.
If I look at the how the distribution of delay looks like it is like (I thought) a half normal distribution, but the others are better because a complaint will not be raised with no delay.
The idea is to use the right distribution, and take the mode of the fitted model as correction for delay to use on all complaints to put them in the "right" month of sales.
However this introduces the spread of this distribution and I understood today that the month of sales is a condition used on this fraction calculation and therefore if I correct with the mode of this distribution the fraction calculated would get a spread introduced.
Final goal is to take that into account, draw the fitted line of the fraction model with the introduced spread and proof that this spread is so big that it makes no sense to use this model (assumption is that it is)
I understand the issue and have worked with it many times. The best way to handle this is with a reliability (events in time) approach. The behavior that you described is called arbitrary censoring and Minitab can handle this easily. Read the Minitab Help link provided then come back and ask your questions.
01mercy
Hi Miner, thank you for your input.
As I understand that with this technique I can determine the distribution that fits this data.
I have read the part that explains data censoring.
I indeed have some questions on how to choose right, interval or left censored data analysis.
Data I have: Subset of pruducts in the market -> Failure in the market with exact know time production to failure in days.
According to minitab help
1) To choose right censored when I have exact failure times
2) To choose interval censored when I have interval times
3) To choose left censored when failure is between 0 and inspection (regstration time failure)
For the product failure in market I could say
1) I know the exact times, in days, when the product failed
2) I know the exact interval, in days (0-1d, 1-2d etc.) when the product failed
3) I have data that starts to have a chance of failure at zero days.
So I'm struggling which method to use.
You have two options:
  • Enter your data in three columns (times, frequency and censoring), then analyze using right censoring
  • Enter your data in Nevada format, run Pre-process for Warranty data, then analyze using arbitrary censoring
The first option will allow you to use the exact times, but can be very tedious since you may have many rows of data to enter. The second option tends to be easier because you can summarize your data into intervals such as one month.
01mercy
I indeed will take option 2 because I can pivot this easily in excel.
For me the total shipped like here would than be replaced by the total nr of complaints of know production to failure time. The hor/vert month/month will stay the same.
I will give it a try.
In order to analyze this correctly, you need to include how many were shipped in total, not just the number of complaints.
01mercy
Well that is actually the problem we have and why I talked about a subset. Which is actually a subset of a subset.
Sold devices -> devices that give a complaint -> devices that give a complaint of which the production date is known.
This is due to the fact that we don't get the serial numbers back from the customer at each complaint.
This leaves me with 3 sets
-> 1) Total produced devices, of which the production date is known.
-> 2) Devices that give a complaint of which only the complaint date is known not the production date.
-> 3) Devices that give a complaint of which the complaint date and the production date is known.
What I wanted to do is look at the distribution of 3 to apply this on 2.
Than to calculate the fraction of 2(corrected) over 1 given the deviation that the distribution of 3 brings into the calculation.
I understood here from someone that the fraction is calculated given a condition, the condition is the time period (year/month/week) and that this time period condition introduces the deviation of 3.
It is already mentioned in my ppm post that from our data as given above we can't calculate the fraction per time period in a reliable way because of the fact we don't have the production date of all devices that give a complaint so don't know to which production volume to relate to.
But I still need to prove here that this is the case in a mathematical sense.
Would it make sense to downscale 1 with the ratio 3 / (2+3)? To have a volume that relates to set 3 which I can use as total devices produced.
Here’s a thought: instead of torturing the data - and yourself - with what can only amount to meaningless numbers, why don’t you investigate the parts that failed and fix the causes? I know that sounds somewhat radical, but really isnt’ It better to just go fix things? A simple count (and perhaps understanding of severity of the failure to the Customer) in these cases is sufficient to prioritize what to fix first.
M Which Distribution & Analysis - Half hourly interval of ticket inflow Statistical Analysis Tools, Techniques and SPC 2
B Establishing a Data Analysis Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
O Quality Management System Implementation framework and Gap analysis checklist Manufacturing and Related Processes 7
S Consolidated Analysis Report for Moulding Process Manufacturing and Related Processes 1
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
T ANOVA analysis to find F test. Using Minitab Software 3
N Failure Analysis-Potting Gel and Sealants Manufacturing and Related Processes 1
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
B How to exclude empty rows in full factorial design analysis? Using Minitab Software 0
B GR&R Destructive Data Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
H Risk Analysis and Probability of Occurrence ISO 14971 - Medical Device Risk Management 3
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
P Benefit risk analysis on pFMEA ISO 14971 - Medical Device Risk Management 9
Q Process map Evaluation and Analysis Method Process Maps, Process Mapping and Turtle Diagrams 5
I QMS monitoring, measurement, analysis and evaluation requirement - Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 7
J Starting a Weibull Analysis: Source on how to perform Weibull Reliability Analysis - Predictions, Testing and Standards 2
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
JoCam MDR Gap Analysis - Consultant fees EU Medical Device Regulations 10
silentmonkey Overall Benefit/Risk Analysis - Risk Management VS Clinical Evaluation ISO 14971 - Medical Device Risk Management 3
Awais Forklift Reliability Analysis Manufacturing and Related Processes 6
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
A Attribute Analysis for colour matching scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Recurrent event analysis software (python) General Auditing Discussions 2
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
M MDSAP and 13485:2016 gap analysis Quality Management System (QMS) Manuals 1
M Gap analysis on ISO 14971:2019 with previous revision ISO 14971 - Medical Device Risk Management 12
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
R ECG Risk Analysis Standards ISO 14971 - Medical Device Risk Management 2
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
H ISO 13485:2016 Gap Analysis by NB ISO 13485:2016 - Medical Device Quality Management Systems 7
R Capability analysis - What is going on this chart? Manufacturing and Related Processes 15
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Looking for a EU MDR Gap Analysis template EU Medical Device Regulations 6
M What is PESTLE Analysis and is it mandatory? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M IATF 16949 (6.1.1 - Planning and Risk Analysis for a remote site) Process Maps, Process Mapping and Turtle Diagrams 5
D Risk Analysis & Technical File - What detail goes in the Risk Management Report ISO 14971 - Medical Device Risk Management 5
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
