Anechoic Chamber Normalised Site Attenuation (NSA)
E
Elynn
Hi there,
not sure if I should post here. Recently I have a customers asking an advice on their routine test Lab qualification...
What if the NSA for an Anechoic Chamber is expired before the next NSA is arranged (says a gaps of 3-4 weeks without valid NSA)? What should he fault the Test Lab for if there are testing to be done during the period?
MIREGMGR
Is the NSA-survey period of validity of arbitrary length, or is it in some manner related to environmental stability and chamber usage?
Did the problem arise because a manager was forgetful or made poor choices in regard to scheduling and prioritization of operations vs. chamber and staff time for regulatory compliance, or because someone made a possibly valid technical judgment that the dominant physically relevant factors in the NSA survey had not changed?
E
Elynn
The validity is stated in FCC requirement to conduct every 3 yearly. As for the problem, from what I understand was due to the supplier conducting the NSA was not able to schedule accordingly (due to resource problem).
O Validation approach for a Photostability Chamber (used for fluid therapy and injectable drug products) Qualification and Validation (including 21 CFR Part 11) 1
M Saturated salts issue - Humidity Chamber General Measurement Device and Calibration Topics 5
Q Doing an MSA on a Climatic Chamber Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Environmental Temperature Chamber Testing & A2LA requirements IATF 16949 - Automotive Quality Systems Standard 4
BradM What is the minimum size chamber for mapping? ISO 13485:2016 - Medical Device Quality Management Systems 2
A Guideline to Calibrate Chamber Temp. & Pressure of a Medical Steam Sterilizer General Measurement Device and Calibration Topics 8
I Stability Chamber Temperature Mapping General Measurement Device and Calibration Topics 5
I Requirements for Qualifying a Stability Chamber Qualification and Validation (including 21 CFR Part 11) 4
F Laboratory Refrigerator Validation and Chamber Temperature Distribution Qualification and Validation (including 21 CFR Part 11) 17
W Oven Leak Test Method - Integrity of the chamber to hold gas Qualification and Validation (including 21 CFR Part 11) 3
W Drive In / Walk In Freezer and Refrigerator Chamber Validation Qualification and Validation (including 21 CFR Part 11) 1
S Temperature and Humidity Chamber Verification General Measurement Device and Calibration Topics 5
J Temperature cycling thermal chamber accuracy and Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J What is Ts16940? Setting up a Temperature Cycle Chamber Other ISO and International Standards and European Regulations 1
O Need documentation - Designing a data acquisition system for the enviromental chamber Design and Development of Products and Processes 3
