Angularity of 2 Surfaces to a Datum which is a Radius
F
fabiolag
I came across a customer drawing that calls out the angularity of 2 surfaces to a datum. The datum is pointing to a radius. The part is an arc with an OR and an IR. The sides of the arc are supposed to form a 75? angle (basic dimension). Both sides of the arc have an angularity callout of .002 to datum A. Datum A is the IR. How would this be inspected? What are they trying to achieve?
F
fabiolag
Here is a quick sketch. The sides are where the angularity is being called out from The angle of the 2 sides is a basic dimension of 75?
J Angularity - When angularity is called out should it be to a basic dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Angularity or Composite profile - Angularity callout on a recent print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Angle between two surfaces Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
D What is satisfactory & acceptable for Coliform - Staphylococcus - Hands and Surfaces Food Safety - ISO 22000, HACCP (21 CFR 120) 3
B How to check the parallelism error of v axis w.r.t to lateral surfaces General Measurement Device and Calibration Topics 1
I Microbiological Monitoring for Surfaces - Switching from Swab to Contact Plates Other Medical Device Related Standards 2
P Food Contact Surfaces presentation # 2 Training - Internal, External, Online and Distance Learning 1
P Food Contact Surfaces Presentation Training - Internal, External, Online and Distance Learning 0
A Test Probes for measuring ohms per square on shielded plastic surfaces Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
optomist1 Counting the number of Coplanar Surfaces on a Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Accredited Surface Roughness Measurement - Requirement for 1Ra surfaces General Measurement Device and Calibration Topics 6
C Implied tolerance - Nominal of the angle between 2 surfaces IATF 16949 - Automotive Quality Systems Standard 9
Q Use of OD Indicator Micrometers - Round Feature vs. Flat Surfaces Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Anodized Aluminum Surface Defects - Stains, raised surfaces, imperfections Manufacturing and Related Processes 17
T Surface Finish Requirements (Ra 150) for Blasted Titanium Surfaces Manufacturing and Related Processes 12
P Light Measurement Help - Work Instruction for Inspection of Powder Coated Surfaces Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Painted Surfaces - IMDS ELV Declaring Harzardous Substances Program RoHS, REACH, ELV, IMDS and Restricted Substances 10
R E-coat on Galvanized Steel parts - Visible and irregular texture on the surfaces Manufacturing and Related Processes 7
2 GDT of datums - Putting Datum C on a drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
O Clamps in checking fixtures used to drive datum features. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
O Orientation with respect to a Compound Datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
O Thread Diameter as a Datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T Establishing -F- datum - need advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
O How to establish Datum Planes with two cylinders? Various Other Specifications, Standards, and related Requirements 0
O Datum A and B are both Cylinders (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
O How to deal with Multiple Datums - Position with respect to Multiple Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Flatness Measurement Errors from a Datum - Test Method General Measurement Device and Calibration Topics 3
K Assumed Alignment and Assumed Datum on a Print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Q as the Datum Maximum Material Condition then MINUS 0.020 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Geometric Tolerance Bonus Datum question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Positional Tolerance - Bonus / Datum Shift / ASME Y14.5M - Clarification Various Other Specifications, Standards, and related Requirements 9
R How to calculate MMC when is placed after datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Complex Surface Profile as a datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
L ASME Y14.5 Coaxial Feature Toleranced with Position w/o Reference Datum Design and Development of Products and Processes 2
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S Does anyone have an AS9100 System Training Datum? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
optomist1 Feature Control Frame is applied to the end of a Cylinder - Datum Dilemma Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J Datum B and C are each both vertical and horizontal - Tolerance of Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
optomist1 Parallel Cylinders (Dowels or Pins) As Datum Features Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
optomist1 Maximum Shift Tolerance Restrained Part - Calculation of Datum Shifts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
P Parallelism call out of .005" to Datum A - A GD&T question Capability, Accuracy and Stability - Processes, Machines, etc. 12
optomist1 Coplanar Widths As Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
optomist1 Tolerance of Position - Pattern of Holes at MMC - Datum Feature Reference Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J True Position with only 1 Datum - Referenced datum is the plane the hole is on Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
CycleMike Profile of datum planes - Profile callout back to datum A (itself) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Definition GD&T Clarification - Callout for Profile of a Surface Reference to the Datum Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 34
G What is meant when a datum (feature) is called a "6 way"? GD&T help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
B True Position without tertiary datum? Establishing a proper rotation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
B How to do a profile on a surface with one datum General Measurement Device and Calibration Topics 23
