Angularity or Composite profile - Angularity callout on a recent print
JIMO1972
Hi All,
I had a question about the following angularity callout on a recent print (see attached). My question is if this is the correct way to describe this tolerance zone with an angularity fcf or should it be a composite profile fcf. im leaning toward the composite profile but would like some feedback from the guru's.
Thannks for any help you could offer.
Jim
The customers intent for the profile / angularity call out is as follows ,
Profile:
The intention of the profile tolerance is to locate the interfacing surface of the marmon flange. This surface can move +/-0.25mm perpendicularly to the 20 degree plane starting from a point defined as 35mm from the axis of Datum B and 4.58mm from Datum A. Utilizing triginometry, we find that this corresponds to a "horizontal" movement of +/- 0.235mm. When transposing an angle of 20 degrees on detail Y at a distance of 4.345mm and 4.815mm from Datum A, the surface should not break this plane to satisfy the profile dimension.
Angularity:
The intention of the angularity dimensions is further specify the limits of the surface as a 20 degree angle with respect to Datum A. This angularity tolerance can be summarized as a tighter profile tolerance of +/-0.075 that must fall within the wider profile tolerance specified previously. This tolerance zone is also perpendicular to the surface and corresponds to a total allowable "horizontal" movement of 0.141mm.
It depends on the customer's intent.
Profile plus angularity as shown will control the angularity tightly, but allow for more variation in location.
A composite profile as you suggest will definitely control the angularity, but will also control the location.
So the the answer to which is best depends on the customer's intent. Does the customer want to tightly control location as well?
Stijloor
Friends,
Obviously, we have no knowledge of the design intent, plus we're only looking at a portion of the print.
An angularity callout is typically placed in a view where it makes most sense.
In my view, a more appropriate callout in the lower feature control frame would be profile of a line as the refining control. Also keep in mind that when observed in a section view, this profile control only applies from tangent point to tangent point. The radii are not included in the profile control.
Just some observations...
Stijloor.
JIMO1972
Thanks for the replies!!
Their intent is that the location is not as important as the shape. therefore the .5mm profile and the .15 angularity. According to the customer the intent is that the angularity will be a sort of flatness for the conical shape, controling it to .15mm (to datum A?). And then that .15mm shape must fall within the .5mm profile tolerance zone.
So I think Im clear with their intention and can have it measured accordingly to make sure they are getting what they need/want. Im just not that familiar with seeing angularity used on the prints I come in contact with so Im not sure if its used properly.
Also yes this is a cross section of the connecting ends of a cylindrical part, so the surface in question is actually conical.
David DeLong
Firstly, this drawing is not to ASME Y14.5M-94 and I think that it is of European origin.
One could have any component of a profile of a surface in the lower section of the composite feature control frame. It could be profile of a line (includes location, angle and straightness on the edge) , angularity (includes angle and straightness) or straightness (to itself) depending on its function and relationship. If some sort of flatness was desired, then the correct call out would be straightness but it depends up the design intent.
F Angularity of 2 Surfaces to a Datum which is a Radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Angularity - When angularity is called out should it be to a basic dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
K Half-Fractional vs. Full Factorial Central Composite Design Using Minitab Software 6
E Composite Position Calculation on a 12 X 4 Hole Pattern Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
S Understanding, Analysis and Monitoring Quality Defects on Composite Components Statistical Analysis Tools, Techniques and SPC 3
K Where do I find Frequencies and Composite Scale in Minitab? Using Minitab Software 2
M Reporting Composite FCF on Layout (GD&T) Various Other Specifications, Standards, and related Requirements 4
M Measuring Holes in Material Stack - Carbon Composite-Aluminum Alloy-Titanium Statistical Analysis Tools, Techniques and SPC 6
optomist1 Composite Profile Tolerancing Clarification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 21
D Gage R&R on the Center Deflection of Composite Tubes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Composite Materials Machining - Out of Specification Holes in Parts Manufacturing and Related Processes 8
F Composite AutoClave Internal Audit Checklist - needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C Validate the idea of a Composite Performance Index Quality Tools, Improvement and Analysis 4
B New Japanese automotive launch (composite plastics molding) - Acceptable Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 12
C Composite Process Capability Index - Cpk is not additive Capability, Accuracy and Stability - Processes, Machines, etc. 3
Jim Wynne Composite deck material -- any experience? Coffee Break and Water Cooler Discussions 5
C CCp : Composite Cp. A new star born (?!) Statistical Analysis Tools, Techniques and SPC 8
L Classes offered for training on composite quality assurance and inspection? Training - Internal, External, Online and Distance Learning 2
Brizilla User Profile - How do I edit my profile info? Elsmar Xenforo Forum Software Instructions and Help 3
I Lifetime Support Calculation - Thermal Operating Profile Reliability Analysis - Predictions, Testing and Standards 7
M How to verify profile gages provided by customer General Measurement Device and Calibration Topics 5
E Department Plan for QA and HSE (profile, plans, structure, goals, etc.) Misc. Quality Assurance and Business Systems Related Topics 2
G Gear Profile & Lead Report Manufacturing and Related Processes 1
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Temperature Profile for Transport Simulation (Sterile Eye Drops) Other Medical Device Related Standards 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q Form IPC 1720A Assembly Qualification Profile still required? Various Other Specifications, Standards, and related Requirements 1
J Profile of Surface with Basics and Angle Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
B Requirement to have Customer Signature Profile on File Document Control Systems, Procedures, Forms and Templates 4
T CMM Inspection of Profile Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
M Measuring a circle's profile Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Complex Surface Profile as a datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Surface Profile and True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
R Capability for CMM Scanned Profiles on a feature with a Bilateral Profile Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 26
C Inspecting a Profile Tolerance for a Die Cut Gasket Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Profile of a Surface Tolerance - Part with a 195 mm radius on it Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
S Surface Profile of a Hole - The meaning of the tolerance in the provided drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
AnaMariaVR2 A Profile of the Pharmaceutical Manufacturing Industry: Russia Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
B Surface Profile Callouts - How the profiles are being dimensioned Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C I need to verify the surface profile of a part - Sine plates General Measurement Device and Calibration Topics 4
optomist1 Contour vs. Profile - Is there a connection between "Contour" & "Profile"? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
optomist1 ASME GD&T Certification Test - Converting Coordinate Tolerances to Profile Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
optomist1 Profile of a Surface - Applying Profile of a Surface Geometric Control Symbols Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A Customer Profiles - Creating a Customer 'Profile' for our Top 10 Customers Document Control Systems, Procedures, Forms and Templates 2
B Measuring the Profile of a Surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
