Annex I - General Safety and Performance Requirements. Precise identity - how provided
MiamiDM
I'm working for a device company with 'a system' that has a range of 30+ attachments., supplied sterile. The system is a Class IIb device and the attachments are used singly as required by the clinician.
We are in the process of updating our technical file and creating a STED that addresses the requirements of Annex II of the MDR, Technical Documentation.
My question relates to the level of detail provided in the General Safety and Performance Requirements (GSPR).
Specifically considering section 4 d), which states, 'the precise identity of the controlled documents offering evidence of conformity with each harmonised standard, CS.... etc etc.'
The precise identity of such controlled documents will be covered in full in other sections of the STED, for example within, 3. Design & manufacturing, 6. Preclinical and clinical data etc. As you can imagine for 30+ attachments to the system, this is quite a long list of documents
To avoid generating long lists of document references in the GSPR, would it be acceptable to cite the relevant section/s of the STED?
Thanks in advance for your thoughts and feedback.
s27bax
This phasing is used quite a lot in the MDR:
"The technical documentation and, if applicable, the summary there of to be drawn up by the manufacturer shall be presented in a clear, organised, readily searchable and unambiguous manner and shall include in particular the elements listed in this Annex. "
The above and your quote from section 4d would strongly suggest that the GSPR document should reference the precise identity of the document. I think the intention of the GSPR is to act as a summary which demonstrates conformance to key areas of the MDR.
Is your STED controlled by your QMS? If not, it is not possible to reference sections as they would not be controlled documents.
Based on the above, I would lean towards referencing the full file name of the controlled documents which demonstrate compliance to the relevant GSPR section.
Hope that helps
MiamiDM
Thank you for these thoughts.
Yes, the STED would be controlled by the QMS.
Surely if the GSPR is included in the STED - under section 4, and the other sections of the STED cover the required level of detail, e.g. doc. references, one could say that the information is there and close at hand.
Hope that helps
s27bax
I went to a TUV conference back in August and they seemed quite keen to make the point that documents should be referenced in full and this is likely the course of action that we will follow. Though it will only become clear how strict they are when it comes to audit. It will be mean a tech file update when a document is revised, which has prompted a thorough review of how we handle tech file updates to make sure it can be handled as quickly as possible.
MiamiDM
Many thanks
A MDR ANNEX XI part A or Part B EU Medical Device Regulations 0
S EU MDR Annex I Chapter III 23.4 z EU Medical Device Regulations 2
C EU MDR - Annex II 6.1 Pre-clinical and clinical data EU Medical Device Regulations 4
K Section 13.6 Annex 1 MDD 93/42/EEC for Glove EU Medical Device Regulations 0
D Is PMCF really a continuous activity per Annex XIV,Part B? EU Medical Device Regulations 5
R MDR, Annex I, 23.1 Interpretation - IFU on the website EU Medical Device Regulations 5
L EN 62368 (In an Annex - M.4.2.1) Secondary Lithium Battery Charging Safeguards CE Marking (Conformité Européene) / CB Scheme 2
P MDR/IVDR Annex III - Technical documentation on PMS EU Medical Device Regulations 1
D ISO 14971:2019 vs MDR Annex 1, Requirement #4 - "Manufacturers shall inform users of any residual risks" ISO 14971 - Medical Device Risk Management 5
K Applicability of Cybersecurity EU MDR 2017/745 Annex 1 23.4(ab), 14.2(d) CE Marking (Conformité Européene) / CB Scheme 3
K Applicability of eIFU as per EU MDR 2017/745 Annex 1 23.1 CE Marking (Conformité Européene) / CB Scheme 0
I IVD - 98/79EC - class IIa - Annex to the EC from the NB states the CM as one of the facilities? CE Marking (Conformité Européene) / CB Scheme 2
R Identify Medical Device characterstics as Annex C of ISO 14971 Risk Management ISO 14971 - Medical Device Risk Management 5
K EU MDR Annex 1 Chapter III: Information in the Instructions for Use-23.4 (e) the performance characteristics of the device; EU Medical Device Regulations 1
Rincewind MDR - GSPR - Annex I - Chapter II EU Medical Device Regulations 4
R An indication that the device is a medical device (MDR, Annex 23.2q) - applicable for accessories? EU Medical Device Regulations 5
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
A EN ISO 14971:2019 does not include the Annex Zs ISO 14971 - Medical Device Risk Management 4
S EU MDR Annex XIV - Clinical Evaluation Plan - What do these methods mean? EU Medical Device Regulations 16
K Annex XVI Device Transition Timeline under the MDR EU Medical Device Regulations 2
M EU MDR - Annex II 3b - What documents fall under this requirement? EU Medical Device Regulations 3
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A EU MDR Annex I section 11.3 - Medical Devices labelled as having a specific microbial state EU Medical Device Regulations 7
J MDR Annex VIII, Rule 6 Classification - Implication for lower risk CV products? CE Marking (Conformité Européene) / CB Scheme 3
Z 21 CFR and Annex 11 mapping document Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
A EU-MDR Annex I Requirement 10.1(d) EU Medical Device Regulations 3
T Post-Market Surveillance Plan - Requirements outlined in Annex III (1.1b) EU Medical Device Regulations 2
D Applicable MDR Annex's for Class IIa Medical Devices EU Medical Device Regulations 0
J MEDDEV 2.12/1's new MIR & IMDRF terms & codes (IMDRF Annex) EU Medical Device Regulations 1
M MDR Annex IX Chapter I, 2.2 (c) - Device identification procedures during manufacture. EU Medical Device Regulations 1
D Example for Accessories of "Annex XVI non-medical devices" and how to classify it now with respect ot EU MDR Other Medical Device Regulations World-Wide 1
P Performance evaluation (IVDD Annex VIII) & Design and Development Validation Studies EU Medical Device Regulations 1
H Critical Supplier Agreement acc. to NBOG 2010-1 Annex II EU Medical Device Regulations 10
L EU-MDR-Annex I - 10.4 (CMR & Endocrine-disrupting properties) - Labeling Content EU Medical Device Regulations 5
T EU-MDR-Annex I - 10.4 (CMR & Endocrine-disrupting properties) EU Medical Device Regulations 0
M Annex II - Technical Documentation. V&V, Performance and Safety EU Medical Device Regulations 3
S MDR Annex II Design & Manufacturing info - 'Adjuvants' definition EU Medical Device Regulations 3
J IVDR and MDR ANNEX I Requirements Template EU Medical Device Regulations 7
S Class II Medical Device Conformity Assessment Route according to Annex V only CE Marking (Conformité Européene) / CB Scheme 7
F IMDRF opened a Consultation on Annex E & F and the link to ISO 14971 ISO 14971 - Medical Device Risk Management 4
Douglas E. Purdy ISO/IEC 17025:2017 Clause 8 & Annex B ISO 17025 related Discussions 9
W EU GMP Annex XI - What is an "appropriate QMS"? Other Medical Device Related Standards 2
C Annex II EU MDR gap analysis EU Medical Device Regulations 7
W MDR Annex I chapter 23.2 (q) - Information required on the label EU Medical Device Regulations 17
I Formula in the Annex of IEC 61000-4-3 - How is k=7 determined? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
H Meaning of Annex II, excluding point Clause 4 conformity CE Marking (Conformité Européene) / CB Scheme 4
Paul Simpson Informational The role of Annex SL - High Level Structure of ISO MSS's - Revision Update February 2019 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
N What should be included in the supply contract - Annex 2 list B IVD ISO 13485:2016 - Medical Device Quality Management Systems 6
R Background of Annex X section 1.1d of MDD 93/42/EEC EU Medical Device Regulations 74
K ISO 13485:2016 Self Certification for Class I (annex 9) Stand-Alone Software? ISO 13485:2016 - Medical Device Quality Management Systems 3
