I have a in-process final drawings prepared by designer and he added following to the print which is not mentioned on the customer print:
1. In-process print, lets say Op10 has Inner diameter, we are making splines in next operation and later on, that become Major spline Outer Dia. Do I need to add a new character in the characteristic library for Inner diameter at OP10. If I do that then I have to include this in Annual Layout Inspection and I assume that the Layout inspection done on only characters shown on Customer print. Please advise?
2. There are form tolerances added on OP10 print i.e., circularity and concentricity on inner diameter, which is not on the customer print but as per designer that is important for the process.
So if Annual Layout Inspections are based on customer print then what happens to the additional characters added by us (supplier). I cannot ignore the additional characters as I need to create
FMEA and Control plan.
