Another study that does not reach any conclusion, but helps creating an article
tarheels4 - 2007
#11
Right EMS audit is not a compliance audit, it is conformance to ISO 14001. But to test the committment to compliance as made in the environmental policy, the CB auditor should test the compliance system through sampling of environmental compliance.
V
vanputten
#13
Hello Qualeety, Cncmarine, and Tarheels4:
Would you please explain your comments on legal compliance, ISO 14001 3rd party audits not being compliance audits, etc. as they relate to the 4th paragraph of the Introduction, to 1.0 Scope, and 4.5.2 of ISO 14001:2004?
Thank you, Dirk
tarheels4 - 2007
#14
Thank you, Dirk
Sorry I don't have "the 4th paragraph of the Introduction, to 1.0 Scope" with me here at home, but Bud is with me. Only section 4.1 - 4.6 is the audit criteria anyway, and that is ingrained.
I can say that there is a difference in compliance and conformance. In EMS, compliance relates to legal requiremnts such as EPA. Conformance is to the standard. The CB be auditor is there to audit conformance. When there is a clear lack of a committment to compliance, as required in the policy there may be a major non-conformance.
In regard to 4.5.2, a CB auditor should verify that the compliance evaluation by the organization is effective, and covers the legal requirements of the organization.
Compliance issues identified by the CB auditor should be addressed through operation control or some other avenue rather than be written as a clear non-compliance, if possible. At least that is the experience I have had with the CBs.
Paul Simpson
#15
What does it say?
qualeety said:
ISO 14001 certification does not mean legal compliance. :nope: ....it was never meant to be and no registar should make that claim. If one wants legal compliance, then on should do a legal compliance audit, not ISO 14001.
Throughout the standard - particularly the 2004 revision there are references to legislation and regulation. There is a new element added that requires the organization to have a procedure in place to demonstrate they meet legal requirements and there is requirement for the third party assessment body to verify that this is taking place. I know it is not the same as a legal compliance audit but the wording I used stands:
Paul Simpson said:
we should be able to use ISO certification as a demonstration of legal compliance
V
vanputten
#17
Thank you Tarheels4.
Only 4.1 through 4.6 are auditable? Everything else in ISO 14001:2004 is not auditable; does not apply to 3rd party conformance audits?
Thank you,
Dirk
Paul Simpson
#18
A good report - spoiled by the press release
JSW05 said:
Professor Lenox sent me a copy of the paper and his permission to post it.
It took a little while (I have been out of the academic sphere for a while) and have to own up to not being familiar with the statistical tests applied to the data but accept that it is fact. The effort was worth it. As a desktop study of links between ISO 14001 certification and a whole host of factors it was very interesting. I am not sure about some of the measures - the researchers have used a lot of binary (Black / White) answers to questions that are more shades of grey. With that proviso aside it provides a lot of data - although as the authors acknowledge - it creates a need for more research to understand why these correlations exist.
The press release attempts to use the "shock" headline “Our analysis provides evidence that firms with lower environment performance, not higher, have a greater propensity to certify, thereby raising doubt that certification serves as a signal of superior environmental performance,” and ends up detracting from the report.
But then of course the correlation between ISO 14001 certification and an EMS and between an EMS and improved environmental performance is not news!
tarheels4 - 2007
#19
Thank you,
Dirk
That is correct Dirk. IMHO. But you might want to check with Sidney for confirmation.
:topic: I am not trying to be nosey. I am just curious about your ISO 14001:1996 certificate. It has a January 24, 2002 issue date. Did you get an extension from TUV? Because it also says the certificate is valid until May 15, 2006. That is well over three years.
V
vanputten
#20
Hello Tarheels4:
Our ISO 14001:1996 cert states it was revised on 2/3/2005 and is good until May 15, 2006. Tomorrow is the last day of our annual surveillance audit which is also an upgrade audit to ISO 14001:2004.
A year ago we went through a full system re-cert audit. Our registrar "revised" our cert on 2/3/2005. Their wording.
Regards,
Dirk
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
U Adding another Subcontractor EU Medical Device Regulations 3
T IATF Rules for sharing production space with another company IATF 16949 - Automotive Quality Systems Standard 10
S Complexity Rating - CB adding another audit day for "high complexity" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Leveraging another company's ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
F Internal transfer of work from one line to another? Qualification and Validation (including 21 CFR Part 11) 3
C FDA Establishment registration - Buying some medical devices from another manufacturer Medical Device and FDA Regulations and Standards News 5
J Another DFAR question 252.225-7009 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
F ISO 13485 - EU countries that could request another audit ISO 13485:2016 - Medical Device Quality Management Systems 2
M Can a PLD Registered in only one state sell prescription drugs to one in another state Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
J IVD CE transfer to another manufacturer EU Medical Device Regulations 4
F Adding a medical device in another medical device package EU Medical Device Regulations 2
M Informational From RAPS – Another Notified Body Bows Out Ahead of EU MDR: ‘Investment Too High’ Medical Device and FDA Regulations and Standards News 2
M Medical devices as an accessory from another manufacturer EU Medical Device Regulations 2
D How about another torque discussion? Assembly processes General Measurement Device and Calibration Topics 9
D Yet another torque question... Assembly processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Informational FDA Preps for Device Shortages as Another Sterilization Facility Will Close Medical Device and FDA Regulations and Standards News 0
I Another design change or new product? IVD device ISO 13485:2016 - Medical Device Quality Management Systems 6
S Our products borrow DHF documents from a previous DHF for another product ISO 13485:2016 - Medical Device Quality Management Systems 2
S Internal Audits performed by another local business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
M ISO TS 16949 Transfer to another CB (Certification Body) IATF 16949 - Automotive Quality Systems Standard 3
Wes Bucey Another year - still happy! Covegratulations 5
M 2 Quality Manuals after merging with another company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Can we have our CE mark on another Manfacturer's parts ? EU Medical Device Regulations 3
G How to cover another manufacturing "site" or warehouse into current ISO 13485 cert ISO 13485:2016 - Medical Device Quality Management Systems 7
M Licensing of a 510K to another manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
P Who can give another company ISO Cert? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P Requirements for Marketing Collateral for product distributed by another company 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Tensile Testing Transfer from one site to another site Manufacturing and Related Processes 2
A Medical Device Licensing - We are planning to sell another product Canada Medical Device Regulations 2
JoCam Control of Works Transfer to another location AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
H Assessment Question - We are using another company's procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
5 Transfer of an ISO 13485 Certificate to another Company ISO 13485:2016 - Medical Device Quality Management Systems 4
F Excel I want to use the count I get in another formula Excel .xls Spreadsheet Templates and Tools 13
J Auditor approval by AABs already authenticated by another AAB from other sector AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R How to address an audit of another facility that is not ISO/TS 16949 ? IATF 16949 - Automotive Quality Systems Standard 9
C Is it required to mention another non certified organization in our Quality Manual ? ISO 13485:2016 - Medical Device Quality Management Systems 9
S Validation and Qualification when moving to another Facility Qualification and Validation (including 21 CFR Part 11) 2
D Device that makes another Device (Active Implant Medical Device) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Q Non Conformity of Support Processes - Need another NC form? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Movement of Final Product from One Warehouse to Another Manufacturing and Related Processes 2
S Our device as part of another company?s device ? FDA liability? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
Wes Bucey Another twist on email spam After Work and Weekend Discussion Topics 6
J How to change the Manufacturing Site to another Contract Manufacturer Japan Medical Device Regulations 1
Q How to determine if another company is our Supplier? Supplier Quality Assurance and other Supplier Issues 3
Q Need Guidance - One job offer with another one in the works Career and Occupation Discussions 26
G Subcontracting work (manufacturing) to another company location EASA and JAA Aviation Standards and Requirements 4
F Not another thread about what Environmental Aspects are... Miscellaneous Environmental Standards and EMS Related Discussions 19
Q Non Conformance Closure by including it on another Corrective Action ISO 13485:2016 - Medical Device Quality Management Systems 8
R Distribution of a Device by another company - Questions about 510 (K) Clearance US Food and Drug Administration (FDA) 6
