ANOVA Analysis - Trying to understand MSA analysis- Please review my spreadsheet
Statistical Steven
Statistician
#12
No. A Linearity study may be used to verify the gage over the entire range of measurement.
Why not use parts across the entire range? Just put part into the ANOVA model to eliminate part to part variaiblity (this will be highly significant) then you can get a pooled estimate across the range. If you do a linearity study you assume constant variance across the range (assuming you use regression analysis), so why not get a pooled estimate across the entire range?
P
prabhudvp
#13
Hi
For Attribute Gage R&R what is the Sample size
The TS auditors likes to measure 100 parts
but i could not find the this number in the MSA manual
Regards
D.Prabhu
Stijloor
#14
Hi
Regards
D.Prabhu
Hello Prabhudvp,
Can you clarify why the TS Auditors "required" 100 parts for an attribute gage study? Was there a Customer-specific requirement? If not, you could ask the auditor: "where is the requirement that states that we must use 100 parts?"
I am curious about the reponses from MSA Specialists here at The Cove.
Stijloor.
#15
You can get away with this if your study aim is soley for this purpose, or to obtain the P/T Ratio. If you want the %GRR, your samples MUST reflect the actual process variation. Otherwise, you invalidate the results of the study.
#16
When looking at the %GRR numbers, what is the breaking point between acceptable and unacceptable. Below is some data from a study we did.
Variation | St Dev | %TV | %Cont
Eq Variance (EV) 3.681E-08 | 1.151E-03 | 0.47% | 37.06%
Interaction (INT) 2.152E-08 | 1.291E-07 | 0.00% | 21.67%
Appraiser (AV) 2.103E-08 | 8.701E-04 | 0.35% | 21.17%
System (GRR) 7.936E-08 | 1.443E-03 | 0.59% | 79.90%
Part (PV) 1.996E-08 | 8.478E-04 | 0.34% | 20.10%
Total Variation 9.933E-08 | 2.465E-01 | 100.00%
Typically, < 10% is excellent, 10 - 20% is acceptable, 20 - 30% is okay if the dimension is non-critical and the expense of improving the gage is not warranted, and > 30% is not acceptable. Also, there is more detail in other posts within this forum.
O
OceanDiver
#17
So looking at this data you say that the GRR should be < 30%. Is the % Total Variation number or the % Contribution number the one to look at? The %TV is 0.59%, extremely low while the % Contribution is 79.90% completely unacceptable.
If neither of these values are the correct one then what do you look at?
#18
Please attach your raw data. Your %TV numbers do not "look right" to me.
%GRR should be assessed against the %TV or % Study Var (Minitab). The %Cont just provides a quick Pareto analysis of the sources of variation.
O
OceanDiver
#19
I did find an error in my calculations which I did fix. The numbers look "more real" now. But I still do not if this would be good or not.
The raw data is in the "Calc1" worksheet. Thanks
#20
Now it looks right! I see that your decimal points were off by 2 in the results.
This gage is unacceptable. Your results are off somewhat from Minitab. I attached the Minitab Analysis for your review.
Your %GRR results of %Total Variation = 86.22% (Minitab's %SV = 89.39%) is much greater than the 30% max acceptable, so this gage is not acceptable for use in process control provided that the variation of the parts accurately reflects the actual process variation. An ndc = 1 is also unacceptable. Since the P/T Ratio is also unacceptable at 56%, you have a problem with the gage.
The % Contribution shows that the sources of measurement variation are large in all categories (Repeatability, Reproducibility and Operator x Part Interaction). Are your parts subject to variation in form (shape)?
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
B WEDM Taguchi and Anova Analysis - L16 array with 5 parameters at 4 levels Manufacturing and Related Processes 5
S Regression Analysis / ANOVA using Excel Excel .xls Spreadsheet Templates and Tools 2
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
L Analysis of Variance (ANOVA) Quadratic Model - Minitab - 2 Factors Using Minitab Software 40
J Analysis reproducibility between-instruments by two way ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Destructive Gauge R&R Sample Sizes - Does ANOVA work better for the analysis? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 1
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
H Taguchi mixed model DoE [L16 (4^3 2^6): factors interaction and ANOVA calculation Using Minitab Software 3
S Taguchi Design with ANOVA - 3 factors each with 3 levels Quality Assurance and Compliance Software Tools and Solutions 13
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E GR&R ANOVA 3rd Factor for Fixture Nests Using Minitab Software 3
N ANOVA vs 2 sample t-test Statistical Analysis Tools, Techniques and SPC 6
F Help me understand the ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F Post Hoc test for two way ANOVA Using Minitab Software 9
E ANOVA for Taguchi method - Four factors and three levels and nine runs (Minitab) Using Minitab Software 6
M ANOVA for S/N ratio gives different results Statistical Analysis Tools, Techniques and SPC 5
T Minitab Two-way Anova example (EXH_AOV.MTB) Quality Assurance and Compliance Software Tools and Solutions 1
S ANOVA/Regression - Analyzing a Dataset which contains over 4500 Points Using Minitab Software 3
P Taguchi Anova Error with Minitab Using Minitab Software 9
J Why doesn't ANOVA Method take the specification into account when determining GR&R % Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
F Fully nested ANOVA: A missing p-values (Minitab) Using Minitab Software 11
C GR&R MSA-4 ANOVA Excel Template Verification Check wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R P-value and interpretation of ANOVA Gage R & R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
L What is the the difference between the Gage R&R Nested Anova and ISO/REMCO N263? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S ANOVA and Test Method Validation for a Drug Delivery Device Statistical Analysis Tools, Techniques and SPC 4
L How is the interaction physically happening while performing ANOVA GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Using ANOVA during the PQ Validation Run to evaluate Statistical Differences Statistical Analysis Tools, Techniques and SPC 4
M Understanding of Regression and ANOVA in Minitab Statistical Analysis Tools, Techniques and SPC 8
J Minitab Error - * ERROR * Unbalanced Design - Unbalanced Anova Using Minitab Software 9
V Sample Range for a valid GRR using ANOVA in Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Anova Gage R&R Calculations for 4 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Multi-factor Anova with Minitab Using Minitab Software 1
R New to MSA - I was told to use ANOVA for the GRR's Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G GR&R (Gage R&R) Anova versus Xbar Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Strange PT Ratio on an Excel spreadsheet for variable GRR ANOVA Method Excel .xls Spreadsheet Templates and Tools 2
J Variation (using ANOVA method) Required for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Minitab ANOVA Error Message - *ERROR* No data in column. Using Minitab Software 3
I Choosing the alpha level in an ANOVA Study Statistical Analysis Tools, Techniques and SPC 3
I Minitab ANOVA Gage R&R Error (vs. EXCEL ANOVA GRR Calculation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Multi-factor Anova with Minitab Using Minitab Software 11
Rameshwar25 GRR (Gage R&R) Nested Anova Method Example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 40
L Good Excel .xls sheet for Gage R&R that calculates both Anova and Range Excel .xls Spreadsheet Templates and Tools 9
optomist1 Generic question regarding Two Way ANOVA Results Statistical Analysis Tools, Techniques and SPC 8
D ANOVA vs. X bar & R - MSA Study in Mintab - Which to use and why? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
optomist1 Two Way ANOVA Test For Equal Variances Using Minitab Software 10
