ANOVA for S/N ratio gives different results
mrbhala
I am testing paint Film Adhesion. Measuring it in % of portions are peeled off in a test.
When I am saying the quality of paint in terms of Film adhesion, I have to say % of portions NOT peeled off. So % NOT peeled off = 100 - % of Peeled off.
While doing Taguchi analysis
For the first category (% peeled off) I am taking "Smaller is better"
Also I am trying it
for the Second (% NOT peeled off) I am taking "Larger is better"
The results of Analysis of variance
for Means both (peeled off, Not peeled off) gives same R sqr, Adj R sqr and F values
but for S/N Ratio both gives different R Sqr, Adj R Sqr, and F values
Can anyone please explain me Why it is so?
PS: I have attached the data and results.
Although you have asked several questions, most can be boiled down to one simple reason. None of your factors are statistically significant (i.e., all p-values >> 0.05). This makes all other numbers irrelevant.
Also, a number of noted statisticians have identified major flaws with the use of S/N Ratios and recommend analyzing the mean and the Ln(StDev) separately. S/N Ratios behave in a non-linear fashion, which can cause the exact problem which you have seen. The Smaller the Better version increases rapidly at first then plateaus. The Larger the Better version increases slowly at first then rises rapidly.
mrbhala
Thank you Miner.
Yes the factors don't have significant influence on the response variables. Actually I am testing 4 variables, out of which 2 are being influenced.
I have question here. I am also done the Gray relational analysis in which for its grades, I did ANOVA. even though the P values are not < 0.05, my guide said I can interpret how much each factor influencing based on the F-Ratio. Is it right?
You can do that PROVIDED that the factors being compared are statistically significant at your designated Alpha risk. I do not recommend doing that with factors that are not statistically significant because you have not disproved the null hypothesis of no effect.
Y
yasir ishraq
Dear Miner
your post is help full. i have same issue but the mean and SNR give different ranking. i have same insignificant value issue. but my study purpose is to find percentage of contribution only. the two Graphs should be overlapping each other as done in most of the studies.
can you please help.
S Strange PT Ratio on an Excel spreadsheet for variable GRR ANOVA Method Excel .xls Spreadsheet Templates and Tools 2
B Study Variation and Discrimination Ratio in Gage R&R ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B ANOVA 3 level and 4 factors f and p values are not showing Using Minitab Software 0
A R chart from ANOVA gage R&R test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
OpExPro R Squared Values in One-Way ANOVA Statistical Analysis Tools, Techniques and SPC 2
F Minitab 19 Anova or X bar # of distinct catagories Using Minitab Software 2
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B WEDM Taguchi and Anova Analysis - L16 array with 5 parameters at 4 levels Manufacturing and Related Processes 9
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
H Taguchi mixed model DoE [L16 (4^3 2^6): factors interaction and ANOVA calculation Using Minitab Software 3
S Taguchi Design with ANOVA - 3 factors each with 3 levels Quality Assurance and Compliance Software Tools and Solutions 13
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E GR&R ANOVA 3rd Factor for Fixture Nests Using Minitab Software 3
N ANOVA vs 2 sample t-test Statistical Analysis Tools, Techniques and SPC 6
F Help me understand the ANOVA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F Post Hoc test for two way ANOVA Using Minitab Software 9
E ANOVA for Taguchi method - Four factors and three levels and nine runs (Minitab) Using Minitab Software 8
T Minitab Two-way Anova example (EXH_AOV.MTB) Quality Assurance and Compliance Software Tools and Solutions 1
S ANOVA/Regression - Analyzing a Dataset which contains over 4500 Points Using Minitab Software 3
P Taguchi Anova Error with Minitab Using Minitab Software 9
J Why doesn't ANOVA Method take the specification into account when determining GR&R % Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
F Fully nested ANOVA: A missing p-values (Minitab) Using Minitab Software 11
S Regression Analysis / ANOVA using Excel Excel .xls Spreadsheet Templates and Tools 2
C GR&R MSA-4 ANOVA Excel Template Verification Check wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R P-value and interpretation of ANOVA Gage R & R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
L What is the the difference between the Gage R&R Nested Anova and ISO/REMCO N263? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S ANOVA and Test Method Validation for a Drug Delivery Device Statistical Analysis Tools, Techniques and SPC 4
L How is the interaction physically happening while performing ANOVA GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E Using ANOVA during the PQ Validation Run to evaluate Statistical Differences Statistical Analysis Tools, Techniques and SPC 4
M Understanding of Regression and ANOVA in Minitab Statistical Analysis Tools, Techniques and SPC 8
J Minitab Error - * ERROR * Unbalanced Design - Unbalanced Anova Using Minitab Software 9
V Sample Range for a valid GRR using ANOVA in Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Anova Gage R&R Calculations for 4 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Multi-factor Anova with Minitab Using Minitab Software 1
R New to MSA - I was told to use ANOVA for the GRR's Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G GR&R (Gage R&R) Anova versus Xbar Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Variation (using ANOVA method) Required for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Minitab ANOVA Error Message - *ERROR* No data in column. Using Minitab Software 3
I Choosing the alpha level in an ANOVA Study Statistical Analysis Tools, Techniques and SPC 3
I Minitab ANOVA Gage R&R Error (vs. EXCEL ANOVA GRR Calculation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Multi-factor Anova with Minitab Using Minitab Software 11
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
Rameshwar25 GRR (Gage R&R) Nested Anova Method Example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 40
L Good Excel .xls sheet for Gage R&R that calculates both Anova and Range Excel .xls Spreadsheet Templates and Tools 9
optomist1 Generic question regarding Two Way ANOVA Results Statistical Analysis Tools, Techniques and SPC 8
D ANOVA vs. X bar & R - MSA Study in Mintab - Which to use and why? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
optomist1 Two Way ANOVA Test For Equal Variances Using Minitab Software 10
