ANSI & ASME regardless of Maximum Material Condition when none is specified
G
gutquality
Hi everyone,
Does any one know when the ansi change was made from default of maximum to regardless material condition when none is specified.
Also I have a print that is very old but it was revised multliple of times and since 2003 it has a new note and only note in history its history that shows to use ASME y14.5.(without standard date).
Now does this mean that I have to use the standard dated when note was added to the blue print or when the original rev blue print was made 30 years ago?
Can anyone help?:(
Stijloor
Re: ANSI & ASME regardless or maximum
Hi everyone,
RFS as a default material condition was introduced with the 1994 Standard.
Older prints are OK for the production of replacement parts or so, as long as you know what Standard is/was applicable and above all; what year. Just stating "Y14.5" does not suffice.
I hope I did...;)
Stijloor.
howste
Thaumaturge
Is this an internal print or customer print? Your questions should asked to the design authority.
Marc
<snip> Now does this mean that I have to use the standard dated when note was added to the blue print or when the original rev blue print was made 30 years ago? <snip>
Technically you have to use the revision level of the standard specified by the print unless you get a print change or a waiver, even if the standard has been obsoleted.
M What Preceded ANSI/ASME Y14.5? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M ANSI/ASME B1.2 Revision Changes from the 2001 version Various Other Specifications, Standards, and related Requirements 1
G Dial Indicator Calibration Frequency - ASME/ANSI B89.1.10M-1987 Calibration Frequency (Interval) 4
Q Dial Indicator Verification Procedure - ANSI/ASME B89.1.10M-2001 General Measurement Device and Calibration Topics 13
M ANSI-Y14.5M vs. ASME-Y14.5M - Does an ANSI-Y14.5M-1994 document actually exist? Various Other Specifications, Standards, and related Requirements 9
R ANSI/ASQ Z1.4. for CQE Exam Professional Certifications and Degrees 8
N Database that lists labs accredited to ASTM / ANSI standards Various Other Specifications, Standards, and related Requirements 6
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 3
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
Q ASQ/ANSI Z1.4–2003 (R2018) Change Log? Various Other Specifications, Standards, and related Requirements 2
S Medical Device Endotoxin Testing for ANSI/AAMI ST72:2011/2016 Other Medical Device Related Standards 1
Sidney Vianna ANSI acquires full ownership of ANAB - December 2018 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
C AS9100 rev D 8.5.1 c 2 - Defining the Machine in-process frequency per ANSI/ASQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Which Version of 60601-1 to Purchase (IEC, EN, ANSI...)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
J Can ANSI Z1.4 sampling plan be used for sampling alone without the Acc/Rej criteria? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M AAMI/ANSI 11135-1:2007, EO Sterilization Other US Medical Device Regulations 8
N Database (Like ASSIST) to subscribe to & have access to new SAE-AS & ANSI standards Various Other Specifications, Standards, and related Requirements 2
E Cleaning Validations for Reusable Products - ANSI/AAMI TIR30:2011 Requirements Other Medical Device Related Standards 3
V Locking in a Standards Version (ANSI Z1.4) Statistical Analysis Tools, Techniques and SPC 1
K Can I use ANSI/AQL for the Total Number of Containers for the entire Lot? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Where to find the ANSI Z1.9 Rosetta Stone Capability, Accuracy and Stability - Processes, Machines, etc. 9
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Calibration system must meet ISO 10012, ISO 17025 or ANSI/NCSL Z540? ISO 17025 related Discussions 38
M GD&T (ANSI Y14.5) Perpendicularity Callouts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
WCHorn AS9100 and Sampling - ANSI ASQ Z1.4 C=0 Conflict AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Using ANSI/ASQ Z1.4 to Reduce Impact of Field Service Campaign AQL - Acceptable Quality Level 17
L Steam Sterilization Validation per ANSI ST 79 Other Medical Device Related Standards 2
E Does anyone have a good understanding of the application of ANSI/AAMI AT6? Various Other Specifications, Standards, and related Requirements 3
A Where to obtain ANSI/ASQ Z1.9 C-1 and D-1 tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Summary / Checklist for ANSI Z80.1 and ANSI Z80.3 Other Medical Device Related Standards 2
R ISO 10012, ANSI/NCSL Z540, ISO 17025 reference meet ISO 9001 7.4.2 (a) intent? ISO 17025 related Discussions 13
S ISO 2859-1 or Ansi ASQ Z1.4 in using AQL or AOQL - Need Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A ANSI/ASQ Z1.4 tables for C=0 - Setting up a robust Sampling Inspection Scheme Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J ANSI Y14.5M-1994 Interpretion Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
P Use of ANSI Standard for Metric Thread Plug Gage? General Measurement Device and Calibration Topics 1
R ANSI Z1.9 AQL 0.4 - What are the starting equipment expectations? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D ANSI Z540-3 Risk Analysis - How to do the math for risk analysis General Measurement Device and Calibration Topics 2
P Inspection Level Interpretation - ANSI Z1.4-2008 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D ANSI IPC A-610 Maximum Jumper Wires Allowed on Boards by the IPC Standard Various Other Specifications, Standards, and related Requirements 1
W ANSI Z1.4 Switching Rule Applications Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q What are the differences between ANSI Z1.4, ANSI Z1.9, and ISO 2859-2? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Monitoring changes in ANSI standards - Control of External Documents Document Control Systems, Procedures, Forms and Templates 6
H Which OHSMS standard to choose? ILO? ANSI? CSA? BS? OHSAS? Occupational Health & Safety Management Standards 15
T Special Inspection Level 3 (S-3) per ANSI Z 1.4 & its relationship with ISO 2859-1 AQL - Acceptable Quality Level 1
K Understanding True position - Drawing Feature Control Frames - ANSI Y14.5 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
triathlonx13 ISO vs. ANSI Thread Standard (Dimensions) and Luer Taper for Medical Devices Various Other Specifications, Standards, and related Requirements 4
