ANSI/ASQ tables (Z1.4) / OC Curves - Percent accepted, how'd I do?
P
paperclip
I used the ANSI/ASQ tables (Z1.4) to inspect lots that had quantities of 151 units to 500 units. AQL was .40 (point four zero) and used single normal, G 2.
The number of samples worked out to 32. Per the OC curves, how high a probability of accepting lots? The way I read the curves, it's about 99 percent. Am I right? If not, what is the percentage of lots expected to be accepted?
Thanks!
howste
Thaumaturge
Re: Percent accepted, how'd I do?
That depends on the actual percent defective in the lot. If there are zero defectives, then the chance of acceptance should be 100% If the lot has 100% defectives, then the probability would drop to 0% The rest would fall somewhere in between. Look at the Operating Characteristic (OC) curves and they will show the probability of acceptance with a given % defective.
howste
Thaumaturge
It probably would be more helpful if I gave some examples:
There would be a 99% probability of accepting a lot with .0314% nonconforming.
There would be a 95% probability of accepting a lot with .160% nonconforming.
There would be a 50% probability of accepting a lot with 2.14% nonconforming.
There would be a 10% probability of accepting a lot with 6.94% nonconforming.
There would be a 1% probability of accepting a lot with 13.4% nonconforming.
P
paperclip
I'm sort of getting it. Does that mean that accepting a lot with .40 will fall just under 95 percent (based on .16 being 95 percent)?
Perhaps my question should be: Customer doesn't want lots with AQL more than .40 and wants Z1.4 tables used. If I want to say we are 95 percent confident (or even 90) that the lot is equal to or no worse than .40 percent defective, what inspection level should I have used?
Thanks for help given so far!
Tim Folkerts
If you keep thumbing thru the Z1.4 standard, you will find that Table P has 5% chance of accepting 0.37% defective. That of course means a 95% chance of rejecting a lot with 0.37% defective.
That would require, however, 800 samples with no defects to accept the lot! That is quite a step up from 32 samples you are doing now! You could also us the binomial distribution to calculate the exact odds ... presumably you would get a similar sample size.
The point is that it is very difficult to be sure of very small defect rates like this. If possible, you should see about measuring a variable instead of a pass/fail text.
Tim F
howste
Thaumaturge
Tim F
The numbers you gave are for an AQL of 0.015 though, not 0.4. If the AQL is 0.4, the probability of acceptance for a lot with .36% defective is actually 99%. Of course the sample size in this case exceeds the lot size, so there would be 100% inspection and (theoretically) all defectives would be removed.
A Where to obtain ANSI/ASQ Z1.9 C-1 and D-1 tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A ANSI/ASQ Z1.4 tables for C=0 - Setting up a robust Sampling Inspection Scheme Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D Need to purchase ANSI/ASQ Z1.4 & 1.9 - Sampling Procedures and Tables - Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R ANSI/ASQ Z1.4. for CQE Exam Professional Certifications and Degrees 8
Q ASQ/ANSI Z1.4–2003 (R2018) Change Log? Various Other Specifications, Standards, and related Requirements 2
C AS9100 rev D 8.5.1 c 2 - Defining the Machine in-process frequency per ANSI/ASQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
WCHorn AS9100 and Sampling - ANSI ASQ Z1.4 C=0 Conflict AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Using ANSI/ASQ Z1.4 to Reduce Impact of Field Service Campaign AQL - Acceptable Quality Level 17
S ISO 2859-1 or Ansi ASQ Z1.4 in using AQL or AOQL - Need Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J AQL Inspector Ruler based on ANSI/ASQ Z1.4-2003 AQL - Acceptable Quality Level 2
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
A New version of ANSI/ASQ Z 1.4-2008? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
howste ANSI/ISO/ASQ QE19011S-2008 - information on 2008 version? General Auditing Discussions 6
L ANSI/ISO/ASQ Q10005-2005: Quality management ? Guidelines for quality plans Other ISO and International Standards and European Regulations 2
Hershal ACLASS purchased by ANSI-ASQ General Measurement Device and Calibration Topics 3
J ANSI/ASQ Z1.4-2003 Sampling with Skip Lot Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R ANSI/ASQ Z1.9 on-line acceptability calculator Other ISO and International Standards and European Regulations 4
Wesley Richardson ASQ has posted ANSI/ISO CD1 9001:2009, ANSI/ISO CD1 9004:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Steve McQuality ANSI/ASQC Z1.4-1993 vs. ANSI/ASQ Z1.4-2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L ANSI/ASQ Z1.4-2003 - Page 13 in reduced sampling code "M" sample size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
T Where to find ANSI/ASQ Z1.4-2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Ansi/ASQ Z1.4 C=0 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
4 ANSI/ASQ Z1.4, Section 6.2 Nonconforming Units Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Sampling Plans - Inspection Levels I, II, III - I'm looking at ANSI/ASQ Z1.4-2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
T AQL for Laymen - ANSI/ASQ Z1.4 - MIL-STD-105 AQL - Acceptable Quality Level 15
Douglas E. Purdy ANSI/ASQ Z1.4-2003 - 1993 version vs. the 2003 - What changes were made? Various Other Specifications, Standards, and related Requirements 2
J Designing a Mil-Std-105 or ANSI/ASQ Z1.4 Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 49
N Database that lists labs accredited to ASTM / ANSI standards Various Other Specifications, Standards, and related Requirements 6
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 3
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
S Medical Device Endotoxin Testing for ANSI/AAMI ST72:2011/2016 Other Medical Device Related Standards 1
Sidney Vianna ANSI acquires full ownership of ANAB - December 2018 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Which Version of 60601-1 to Purchase (IEC, EN, ANSI...)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
J Can ANSI Z1.4 sampling plan be used for sampling alone without the Acc/Rej criteria? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M AAMI/ANSI 11135-1:2007, EO Sterilization Other US Medical Device Regulations 8
N Database (Like ASSIST) to subscribe to & have access to new SAE-AS & ANSI standards Various Other Specifications, Standards, and related Requirements 2
E Cleaning Validations for Reusable Products - ANSI/AAMI TIR30:2011 Requirements Other Medical Device Related Standards 3
V Locking in a Standards Version (ANSI Z1.4) Statistical Analysis Tools, Techniques and SPC 1
K Can I use ANSI/AQL for the Total Number of Containers for the entire Lot? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Where to find the ANSI Z1.9 Rosetta Stone Capability, Accuracy and Stability - Processes, Machines, etc. 9
A Calibration system must meet ISO 10012, ISO 17025 or ANSI/NCSL Z540? ISO 17025 related Discussions 38
M What Preceded ANSI/ASME Y14.5? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M GD&T (ANSI Y14.5) Perpendicularity Callouts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M ANSI/ASME B1.2 Revision Changes from the 2001 version Various Other Specifications, Standards, and related Requirements 1
L Steam Sterilization Validation per ANSI ST 79 Other Medical Device Related Standards 2
