ANSI Y14.5M Absolute Limits and Measurement question
9
93ramvert
Here is what ASME Y14.5M-1994 says...
1.6.1(a) Where the dimensions is less hthan one millimeter, a zero precedres the decimal point.
1.6.1(b) Where the dimension is a whole number, neither the decimal point nor a zero is shown.
1.6.2(a) A zero is not used before the decimal point for values of less than one inch.
1.6.2(b) A dimension is expressed to the sam number of decimal places as its tolerance.
Now heres my question.
If my engineers put say 1.240-1.260" on a drawing, and my inspectors come in and measure that dimension but measure to 1.26005, it's technically a nonconforming part. According to the standard they should not even be measuring to that accuracy, am I correct?
This question is raised because of a class I attended with Pratt and Whitney, and they require absolute measurments. Basically what they have said is if our drawing is labeled as .000" then we want to see an inspection report with .XXX" and not .XXXX".
Am I getting this right or am I off base?
Al Rosen
Re: ANSI Y14.5M Absolute Limits question
It's nonconforming. And it's not accuracy, but resolution. If you were to round-off the measurement, it would be 1.2601.
9
93ramvert
But according to Pratt it's absolute, it is what it is, no rounding up where does it say to round up or round down in the standard? I am told that if they have .000" on thier drawing then they want .XXX" on the inspection report and not .XXXX". It's incorrect format regardless of the dimension being right or wrong.
Kingsld1
See Paragraph 2.4 Interpretation of Limits.
It states "All limits are absolute. Dimensional limits, regardless of the number of decimal places, are used as if they were continued with zeros."
After some examples, it continues with " To determine conformance within limits, the measued value is compared directly with the specified value and any deviation outside the specified limiting values signifies nonconformance with the limits"
If your parts are right on the edge of going out of tolerance a more accurate instrument may be needed to make the final determination of conformance.
Two points:
  1. Unless ASME Y14.5M is called out in the contract or on the drawing, it's irrelevant. A standard is only a standard when two or more parties explicitly agree to it.
  2. 1.2601 is greater than the upper limit of 1.260, which means that it is out of tolerance. You need to discuss with your customer how these things should be handled. The explicit specification says that 1.260 may not be exceeded. If your customer allows you to round to the third decimal place, they need to tell you that. If they allow for truncation beyond the third decimal place, they need to tell you that as well.
Al Rosen
I stated "if" to for emphasis. I know it's an absolute. All digits after the 3rd decimal must be "0". If they want 3 decimal places on the report, they are closing their eyes.
andygr
Lets keep sight on what is required.
The print is designed to let production know what to build and QA folks what to verify. IF there are other contractual items then they should be clearly called out.
Since we are not dealing with model based design (where there is no limit to the resolution and is truly a absolute) the key here is the resolution that is defnied on the print established by design( I will leave the commentary on the ability of some design engineers to correctly perform this function to another thread) They call out X.XXXX you measure/report to X.XXXX
For why you would measure to the next level of resolution a simple example is to take your everyday digital mic and try and get the last digit to show anything other than a 0 or 5. For us old school inspectors the same applys to "splitting the lines" and picking which one it is closer to. This is supporting that you measure 1 level past the signifigant digit and round to ensure that you avoid the 1:1 error.
:2cents:
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
M What Preceded ANSI/ASME Y14.5? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M GD&T (ANSI Y14.5) Perpendicularity Callouts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
J ANSI Y14.5M-1994 Interpretion Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
K Understanding True position - Drawing Feature Control Frames - ANSI Y14.5 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M ANSI-Y14.5M vs. ASME-Y14.5M - Does an ANSI-Y14.5M-1994 document actually exist? Various Other Specifications, Standards, and related Requirements 9
R ANSI/ASQ Z1.4. for CQE Exam Professional Certifications and Degrees 8
N Database that lists labs accredited to ASTM / ANSI standards Various Other Specifications, Standards, and related Requirements 6
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 3
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
Q ASQ/ANSI Z1.4–2003 (R2018) Change Log? Various Other Specifications, Standards, and related Requirements 2
S Medical Device Endotoxin Testing for ANSI/AAMI ST72:2011/2016 Other Medical Device Related Standards 1
Sidney Vianna ANSI acquires full ownership of ANAB - December 2018 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
C AS9100 rev D 8.5.1 c 2 - Defining the Machine in-process frequency per ANSI/ASQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Which Version of 60601-1 to Purchase (IEC, EN, ANSI...)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
J Can ANSI Z1.4 sampling plan be used for sampling alone without the Acc/Rej criteria? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M AAMI/ANSI 11135-1:2007, EO Sterilization Other US Medical Device Regulations 8
N Database (Like ASSIST) to subscribe to & have access to new SAE-AS & ANSI standards Various Other Specifications, Standards, and related Requirements 2
E Cleaning Validations for Reusable Products - ANSI/AAMI TIR30:2011 Requirements Other Medical Device Related Standards 3
V Locking in a Standards Version (ANSI Z1.4) Statistical Analysis Tools, Techniques and SPC 1
K Can I use ANSI/AQL for the Total Number of Containers for the entire Lot? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Where to find the ANSI Z1.9 Rosetta Stone Capability, Accuracy and Stability - Processes, Machines, etc. 9
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Calibration system must meet ISO 10012, ISO 17025 or ANSI/NCSL Z540? ISO 17025 related Discussions 38
M ANSI/ASME B1.2 Revision Changes from the 2001 version Various Other Specifications, Standards, and related Requirements 1
WCHorn AS9100 and Sampling - ANSI ASQ Z1.4 C=0 Conflict AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Using ANSI/ASQ Z1.4 to Reduce Impact of Field Service Campaign AQL - Acceptable Quality Level 17
L Steam Sterilization Validation per ANSI ST 79 Other Medical Device Related Standards 2
G Dial Indicator Calibration Frequency - ASME/ANSI B89.1.10M-1987 Calibration Frequency (Interval) 4
E Does anyone have a good understanding of the application of ANSI/AAMI AT6? Various Other Specifications, Standards, and related Requirements 3
A Where to obtain ANSI/ASQ Z1.9 C-1 and D-1 tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R Summary / Checklist for ANSI Z80.1 and ANSI Z80.3 Other Medical Device Related Standards 2
R ISO 10012, ANSI/NCSL Z540, ISO 17025 reference meet ISO 9001 7.4.2 (a) intent? ISO 17025 related Discussions 13
S ISO 2859-1 or Ansi ASQ Z1.4 in using AQL or AOQL - Need Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A ANSI/ASQ Z1.4 tables for C=0 - Setting up a robust Sampling Inspection Scheme Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
P Use of ANSI Standard for Metric Thread Plug Gage? General Measurement Device and Calibration Topics 1
R ANSI Z1.9 AQL 0.4 - What are the starting equipment expectations? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D ANSI Z540-3 Risk Analysis - How to do the math for risk analysis General Measurement Device and Calibration Topics 2
P Inspection Level Interpretation - ANSI Z1.4-2008 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
G ANSI & ASME regardless of Maximum Material Condition when none is specified Various Other Specifications, Standards, and related Requirements 3
D ANSI IPC A-610 Maximum Jumper Wires Allowed on Boards by the IPC Standard Various Other Specifications, Standards, and related Requirements 1
W ANSI Z1.4 Switching Rule Applications Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q What are the differences between ANSI Z1.4, ANSI Z1.9, and ISO 2859-2? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Monitoring changes in ANSI standards - Control of External Documents Document Control Systems, Procedures, Forms and Templates 6
H Which OHSMS standard to choose? ILO? ANSI? CSA? BS? OHSAS? Occupational Health & Safety Management Standards 15
T Special Inspection Level 3 (S-3) per ANSI Z 1.4 & its relationship with ISO 2859-1 AQL - Acceptable Quality Level 1
triathlonx13 ISO vs. ANSI Thread Standard (Dimensions) and Luer Taper for Medical Devices Various Other Specifications, Standards, and related Requirements 4
