Antiquated Sampling Standards? Scrap paper tables like Z1.4 or MIL-STD-105E?
Tim Folkerts
I have been learning a bit about sampling plans, and the more I look, the poorer the statistics involved seem to be. Worse, most people involve with sampling have little idea what plans say about the actual quality associated with different plans. In this day and age of computers on every desktop, why not scrap paper tables like Z1.4 or MIL-STD-105E and simple go to a software-based system where the sampling plan is generated based on needs.
Why not replace the paper standards with an electronic standard - a set of equation implemented in a simple computer program that tells you just what you need, based on values you input (alpha, beta, AQL, RQL, lot size).
Currently you say something like "Normal, Level II, AQL = 1". Then you have to look up in a table the values for lot size & acceptance number, but most people still have little idea how this translates into actual statistics. (And I can tell you there is little consistency in the statistics when you start plugging through the numbers.)
Instead, you could say something like "AQL = 1, RQL = 5 with 5% risk" (i.e. there is no more than a 5% chance of rejecting a lot with 1% defective and no more than a 5% risk of accepting a lot with 5% defective).
For those who like names, you could call alpha = beta = 5% "normal". "Tightened" could be alpha = 20%, beta = 1%; "reduced" could be alpha = 1%, beta = 20%.
For those who like tables, it would be simple to generate a set of "standard" tables.
This still doesn't give the whole OC curve, but it comes a lot closed to letting you know what you sampling plan is really doing for you.
Tim
Re: Antiquated Sampling Standards?
Tim - To my knowledge there is no requirement as to which sampling plan you use. I know the customer at times will specify one but normally the sampling plan is up to you. There are a number of small programs around that give sample sizes based on your inputs. I have attached one for you to look at. I can't vouch for it as it was an example I picked up on the net from a college site and I don't use it here at work. If you develop one, please share it with us.
Dave
Tim,
You have a good question. Why not send it to ANSI and ask them?
However, IMO in either case, the program or the AQL tables, to use them effectively will require some training or statistical knowledge.
This link is great, there is an activeX that solves for AQL and plot OC curve
(tanks to the autor of that site William A. Levinson )
https://www.ganesha.org/freesoft.html
wich for AQL take you to:
(broken link removed)
That you can download free.
:vfunny:
