Any Easy Way to determine Linearity Study Acceptability?
beaser3
Does anyone know of an easy way to determine if a linearity study is acceptable? Each time I calculate it graphically on our software, it runs a straight line at zero. Does that seem correct? Could standard error or goodness of fit (both of which are calculated in the software) be used as an acceptable number? Ex: If standard error is below "whatever number" linearity is acceptable. Our procedure used to direct us to use the % tolerance for acceptability but that is no longer calculated in the software. Any help would be appreciated.
Re: Linearity study acceptability
It would help to know what the study is being performed on. Some types of measuring equipment might have other characteristics which could affect linearity, bias for example. Let us know and we'll try to help.
beaser3
Thanks for the quick response!
We do one time linearity studies on all of our equipment. Some examples are digital calipers, digital micrometers, microscopes, smartscope, etc. We only do this when the gage is purchased and it is never done again.
BradM
Interesting! I am intrigued that you only perform initially. Most instrument/equipment's linearity degrades with time.
Exactly how many points along a line are you choosing? Are they spread out along the area of interest, or clustered high, low, or middle?
As you well know :), there are lots of ways to graph something. You could establish a raw value above/ below the line as an acceptance value.
I would think Goodness of Fit would benefit you if you are estimating/modeling. For example, you develop a linear formula to estimate some behavior, put in numbers, and see how close that formula predicts.
Not much point in doing the study really, IMHO, except as a baseline for a 'family' of equipment types. What you say about 'running through zero' probably will happen with new equipment.......
Atul Khandekar
beaser3, Welcome!
If you have the AIAG MSA manual, it gives the criteria for acceptability based on two hypothesis tests: 1. that the bias is zero and 2. that it is uniform over the range of the gage. Also, if you search through the posts in this forum, you will probably find this issue discussed. The straight line at Zero is the 'ideal' Bias=0 line.
beaser3
Thanks to all for the replys. This is getting a little bit clearer. On one study, my results show a standard error of .00012 and is flagged "UNACCEPTABLE" by the software. The graph still shows all points along the zero line though. Would this gage be accepatble?
Can you attach the results and advise what software you are using?
Reference the attached file from Minitab data. This shows an unacceptable Linearity study. If the blue zero Reference line falls within the red confidence limits, the study is acceptable. You may also interpret the p-values for each reference value. If all p-values are greater than 0.05, the linearity is acceptable.
S Easy way to determine % (concentration) of NaOH in an aqueous solution? Manufacturing and Related Processes 1
B Complaint Records - Accessing records on Easy Track Software Records and Data - Quality, Legal and Other Evidence 3
W Does anyone have any experience with the Easy Metric System? General Measurement Device and Calibration Topics 2
B Easy Software Needed for Recording Mainly Attribute Data Quality Assurance and Compliance Software Tools and Solutions 2
Q How to provide evidence of Strategic Direction (Easy) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A EASA Easy Access Rules for Continuing Airworthiness - June 2017 EASA and JAA Aviation Standards and Requirements 0
Q Easy Way of "Implementing" Risk in ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Metrics and Statistics for Improvement - Easy to implement Statistical Analysis Tools, Techniques and SPC 4
Marc How to Live Easy in China on $475 a Month and still be able to Save Money Immigration and Expatriate Topics 2
N Moisture Analyzer Out of Calibration - Easy Way to Confirm Everything Ok? General Measurement Device and Calibration Topics 3
N Tracking Shelf-Life of Materials - Is there an easy way? ISO 13485:2016 - Medical Device Quality Management Systems 2
K An easy way to distinguish Tooling vs. Equipment Design and Development of Products and Processes 7
L Easy Access of Obsolete Documents - Corrective Action help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
G All FDA Regulations in a New Easy Download Format US Food and Drug Administration (FDA) 1
G VERY easy savory baked Thanks Giving party treat Coffee Break and Water Cooler Discussions 0
M How to Implement the QHSE Integrated Management System Easy Steps? Occupational Health & Safety Management Standards 1
smryan EASY Chicken Enchilada dish Imported Legacy Blogs 4
U Easy-Difficult Coffee Break and Water Cooler Discussions 0
J Easy Method to Test a Caliper - Good or bad? General Measurement Device and Calibration Topics 10
B Newbie, easy to follow guide for organizing/assembling very first PPAP booklet APQP and PPAP 3
N SPC Light Program - Easy way of Cpk extraction from multiple control charts Statistical Analysis Tools, Techniques and SPC 4
T Very Basic, Easy Document Control Training - Preferably Powerpoint .ppt Document Control Systems, Procedures, Forms and Templates 6
A 510(k) Ownership Change - Is it painful or is it a pretty easy process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
G BillMyParents makes it easy for kids to spend parents' money After Work and Weekend Discussion Topics 5
P Easy, Albert... Funny Stuff - Jokes and Humour 0
N A Man Leaves Home - Teaser - Easy Brain Teasers and Puzzles 5
R Recommendations for a Low cost and Easy to Implement Quality Management System Quality Manager and Management Related Issues 9
H Is it easy to change to another field as a quality engineer? Career and Occupation Discussions 3
L Employee Morale Boosters - Low cost, quick, and easy ideas to boost morale Preventive Action and Continuous Improvement 31
A Proper term for 'Easy Identification'? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R What is this formula? Translating Gage R&R result to something easy to grasp Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Antonio Vieira Learn any language! Text to Speech - It's easy to speak for example Portuguese After Work and Weekend Discussion Topics 3
B Grammar Made Easy In 23 Steps Funny Stuff - Jokes and Humour 2
Marc Are you affected by hurricane Katrina? New Orleans (The Big Easy) due for a bash? Coffee Break and Water Cooler Discussions 64
S Stamping part numbers on components for easy identification without a print change Document Control Systems, Procedures, Forms and Templates 5
S Shiny new CAPA system! - Easy way to close the old one? Nonconformance and Corrective Action 1
Douglas E. Purdy Pondering "Document Control Made Easy" by Craig Cochran Document Control Systems, Procedures, Forms and Templates 3
B The Idea Generator - Quick and Easy Kaizen Book, Video, Blog and Web Site Reviews and Recommendations 1
M MSA - Bias Study - Is there any easy method to follow and apply? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Howard Atkins TS 16949 Transition - Easy? Changed Auditor Requirements? IATF 16949 - Automotive Quality Systems Standard 25
Marc ISO9001:2000 Interpretations - Year 2000 Change Easy Or Hard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Need Easy Performance Measures QS-9000 - American Automotive Manufacturers Standard 4
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
L How to determine / validate Medical Device Storage Conditions ISO 13485:2016 - Medical Device Quality Management Systems 1
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
E How do you determine if hipot is necessary for a cable product? Manufacturing and Related Processes 8
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
