Anyone know what these are called?
Wes Bucey
I agree. Ceramic insulators for residential wiring. (No longer conform to building code in most jurisdictions. Now, most residential wiring is to be enclosed in metal conduit, not just armored BX cabling.)
:topic:this kind of wiring was one of the direct sources of fires in residences and apartment buildings in the early 20th century (1900 - 1940) because the insulation on the wires would be gnawed by rodents (rats and mice) to get material for nest building, exposing bare wiring which could either short and spark or heat up from heavy current loads and set fire to nearby flammable material.
Patricia Ravanello
Re: Anyone knows what these are called
The cylindrical thingmajigs?
Hello Richard,
I believe it was actually called "knob and tube wiring"....Here's what Wikipedia has to say about it...
Knob and tube wiring (sometimes abbreviated K&T) was an early standardized method of electrical wiring in buildings, in common use in North America from about 1880 to the 1930s.[1][2] It consisted of single-insulated copper conductors run within wall or ceiling cavities, passing through joist and stud drill-holes via protective porcelain insulating tubes, and supported along their length on nailed-down porcelain knob insulators. Where conductors entered a wiring device such as a lamp or switch, or were pulled into a wall, they were protected by flexible cloth insulating sleeving called loom. The first insulation was asphalt-saturated cotton cloth, then rubber became common. Wire splices in such installations were twisted together for good mechanical strength, then soldered and wrapped with rubber insulating tape and friction tape (asphalt saturated cloth), or made inside metal junction boxes.
Knob and tube wiring was eventually displaced from interior wiring systems because of the high cost of installation compared with use of power cables, which combined both power conductors of a circuit in one run (and which later included grounding conductors).
At present, new knob and tube installations are permitted in the US only in a few very specific situations listed in the National Electrical Code, such as certain industrial and agricultural environments.
Happy Easter!
Patricia
MIREGMGR
Patricia got it right...knob and tube.
Watch out if you have to disturb a run before you take that run out of service, for the primary wire insulation to be embrittled and to crack off the wire. That especially occurred for circuits that were regularly loaded to almost the overcurrent trip point and therefore ran warm or hot.
Another problem was that sometimes the old copper was much harder/more brittle than modern stuff, and would break at an insulator when disturbed.
If you have to leave some of this stuff in service, my view is that it's a good idea to down-rate it, fuzing branch circuits at 10 amps.
Ninja
Looking for Reality
I've worked a bit for Habitat for Humanity in the Philadelphia area.
Yep, that's knob and tube. (only the knobs showing in the pics...the tubes are used for going through rafters and joists). There is a lot of it in older buildings that have not been renovated.
If you look at replacing it (highly recommended), it tends to be most convenient to run your new Romex or BX cable first, connect it to the outlets and fixtures one at a time, and only then remove the old wiring. That way if you get interrupted during the job, you still have the unsafe power rather than no power.
So what will people think of today's building codes 50 years from now?
I hear "You run an explosive gas into your residence in a pipe, then light the end of it on fire intentionally?!?"
M Has anyone used Quality Software from ION called Simple Trak Quality Assurance and Compliance Software Tools and Solutions 7
M Has anyone evaluated or purchased APQP software from Omnex called AQUA? APQP and PPAP 4
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
Watchcat Anyone had an MDR technical file review/audit yet? EU Medical Device Regulations 13
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
M Has anyone has been through an MDR audit? (3/2020) EU Medical Device Regulations 1
M Has anyone heard of Run at Risk? Manufacturing and Related Processes 14
C Document Control Stamps - Does anyone still stamp their documents? Document Control Systems, Procedures, Forms and Templates 21
B ASA Aviation Supply Association - Has anyone heard of ASA? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
D Has anyone had sudden challenges from Korea-MFDS? Other Medical Device Regulations World-Wide 1
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
Ronen E Can anyone please explain this? (510k submission requirement) Other US Medical Device Regulations 14
GreatNate Metrotom - Does anyone have any exposure to the Zeiss Metrotom 800 or 1500? Manufacturing and Related Processes 0
D FDA Biomarker Qualification Program - Has anyone prepared an application? Medical Device and FDA Regulations and Standards News 0
T Is anyone working with N299.1 (Supply/service to nuclear power plants)? Various Other Specifications, Standards, and related Requirements 0
GreatNate QMS in SharePoint - Is anyone doing this? Manufacturing and Related Processes 7
M Honda Audits - Does anyone have any experience with the QAV audit? General Auditing Discussions 3
G Anyone working with or planning to do business in the CBD (cannabidiol) industry? US Food and Drug Administration (FDA) 1
L Has anyone heard of the 2 pan system? Manufacturing and Related Processes 6
Q Does anyone have experience implementing a QMS without ISO certification? Quality Manager and Management Related Issues 2
J Does anyone here use ISOXpress/IMSXpress QMS software? Software Quality Assurance 11
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
M Has anyone here assessed the latest Abbreviated 510(K) guidance document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Does anyone has a good verification and validation plan template? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Has anyone undergone a BARDA (HHS) audit as part of their grant process? Other Medical Device Regulations World-Wide 0
QIE Anyone have experience with BPA Quality (QMS system based on Office365/Sharepoint) Quality Assurance and Compliance Software Tools and Solutions 1
M AMS0320 - Electro-deposition of zinc - Anyone come across this spec? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
M Anyone Dropping IATF and going back to ISO ? IATF 16949 - Automotive Quality Systems Standard 18
Sidney Vianna LinkedIn bug - Anyone has any idea of how to fix this? Posts not showing for me in a Group feed. Coffee Break and Water Cooler Discussions 2
R Anyone who can share a checklist for ISO 29134? IEC 27001 - Information Security Management Systems (ISMS) 7
G Can anyone tell me about Tooling FMEA FMEA and Control Plans 3
B Does anyone charge for annual layouts? APQP and PPAP 8
C Will anyone please share training material for ISO:13485:2016 for best practices Training - Internal, External, Online and Distance Learning 0
K Has anyone used QAI for training? Training - Internal, External, Online and Distance Learning 7
N Does anyone know a registrar that offers both ISO 9001 and ISO 17020? Registrars and Notified Bodies 6
W Does anyone have any experience with the Easy Metric System? General Measurement Device and Calibration Topics 2
J Does anyone have a good APQP template that meets IATF requirements? APQP and PPAP 3
A Anyone have experience with Transmille calibrators General Measurement Device and Calibration Topics 1
D Has anyone here had any experience with PQ-FMEA software? FMEA and Control Plans 1
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
C Does anyone have an AS9100:2015 audit schedule template? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
S Has anyone completed IATF 16949 Certification - Share your Audit Experience? IATF 16949 - Automotive Quality Systems Standard 2
S Has anyone created a Turtle Diagram reflecting the new ISO 9001:2015 Structure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Does anyone have example test report of defibrillator IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Can anyone tell me requirements standards for insufflator? Other Medical Device Related Standards 1
