Anyone know what these are called?
W
Wilderness Woody
#11
So what will people think of today's building codes 50 years from now? "
Wireless power transmission is gaining traction in demonstrations as the technology advances and improves efficiencies. We already use many more low power devices and the ability to eliminate or at least minimize batteries can lead to convenient wireless devices of all kinds.
Induction cooking ranges, charging pads (coil) are common place today.
Just need to drop in my personal nuke power plant in the back yard and I'm ready to go off the grid! :cool:
Ninja
Looking for Reality
#12
LOL, reminds me of a Star Trek Voyager episode ("Time and Again") where a planet used polaric energy for household use.
Someone had an issue with a power line and destroyed the planet as a whole.
Tablet computers and 3D "additive" manufacturing and many other things followed the Star Trek "Wow, that's cool" factor"
....I'll pass on the back yard Nukes.
Richard Regalado
#13
Thank you to all who contributed.
I'll be back to the old house this weekend and I'll tinker more. Last time I tried opening the metal fuse box to see if I can shut down the power if and when I'll do the upgrades but the fuse box door has rusted in place. I may need special tools to pry it open and see what's inside.
Wes Bucey
#14
You ought to also check the power source coming from the transmission line to the building. If the building wiring is this antiquated, there is a strong probability the local feed is as well. If possible, I would consider solid tubing for the wire courses instead of armored cable, but then I'm a Captain Caution from way back. Most modern houses (because of so many appliances) have 100 amp service minimum (circuit breakers rather than fuses) and most of the McMansions in my area have 200 amp service minimum with several 220 volt lines (air conditioning, electric clothes dryers, electric car recharging stations.)
David-D
#16
Yes, as mentioned its knob and tube wiring. Fortunately it isn't carying the power in my 110 year old house anymore. At this point its generally easier to cut all power to it and run brand new wire and breakers to code although I'm sure not cheap. If your house is that old it likely has many generations of "excitement" in it. Knob and tube, paper and brittle tar wrapped wires, aluminum wires, etc.; all of which are potential fire hazards. I'm no electrician and it isn't cheap but in the end you'll be better off and safer to just pot in a new main box and run new lines. If you can't even get into the fuze box then that wouldn't make me real comfortable.
Good luck,
David
Richard Regalado
#17
These are the fuse boxes that have latched shut with rust. I ain't touching these. I'm gonna let a professional electrician tinker. I don't have a BCP in place for this. :)
Wes Bucey
#18
This isn't a big deal. Pull the power switch. If IT is rusted open, THEN you need a pro to cut off the power into the building.
I imagine you only want to see what is in place.
Once power is off, use a block of wood as a fulcrum and just lever the box open with a pry bar.
In any event, you should ultimately replace this box with one with breaker switches versus fuses and probably add a lot more separate circuits than you now have. It will be a lot larger than the space for this one.
Although I know how to do all this work, I don't do it myself any more because I'm getting too old to crawl through attics and crawl spaces running conduit and pulling wire. My community does require a licensed electrician to do the final hookup to the power company feed.
If this were my building, I'd run all new wires and install new grounded outlets with strategic ground fault interrupters and bring to a new box before pulling this one. My circuit breaker box looks like this photo
MIREGMGR
#20
Nasty stuff. Look at the connections, upper left; lower right; and barely visible, lower center and upper right. Dangerous if the wire insulation is embrittled.
As to the "pry the box open" suggestion, note that the enclosed switch and fuses only protect downstream. The upstream supply line will be just as old and possibly embrittled. You don't want to risk accidentally applying significant force to that line due to something happening to the rusted box that you didn't expect, i.e. you pry the whole box off the wall before the cover breaks open. You really don't want to rely on the feed-line overcurrent protection provided by the power company. It might be at a much higher current value than a short through the steel box would flow, resulting in unlimited heating and a fire.
M Has anyone used Quality Software from ION called Simple Trak Quality Assurance and Compliance Software Tools and Solutions 7
M Has anyone evaluated or purchased APQP software from Omnex called AQUA? APQP and PPAP 4
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
Watchcat Anyone had an MDR technical file review/audit yet? EU Medical Device Regulations 13
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
M Has anyone has been through an MDR audit? (3/2020) EU Medical Device Regulations 1
M Has anyone heard of Run at Risk? Manufacturing and Related Processes 14
C Document Control Stamps - Does anyone still stamp their documents? Document Control Systems, Procedures, Forms and Templates 21
B ASA Aviation Supply Association - Has anyone heard of ASA? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
D Has anyone had sudden challenges from Korea-MFDS? Other Medical Device Regulations World-Wide 1
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
Ronen E Can anyone please explain this? (510k submission requirement) Other US Medical Device Regulations 14
GreatNate Metrotom - Does anyone have any exposure to the Zeiss Metrotom 800 or 1500? Manufacturing and Related Processes 0
D FDA Biomarker Qualification Program - Has anyone prepared an application? Medical Device and FDA Regulations and Standards News 0
T Is anyone working with N299.1 (Supply/service to nuclear power plants)? Various Other Specifications, Standards, and related Requirements 0
GreatNate QMS in SharePoint - Is anyone doing this? Manufacturing and Related Processes 7
M Honda Audits - Does anyone have any experience with the QAV audit? General Auditing Discussions 3
G Anyone working with or planning to do business in the CBD (cannabidiol) industry? US Food and Drug Administration (FDA) 1
L Has anyone heard of the 2 pan system? Manufacturing and Related Processes 6
Q Does anyone have experience implementing a QMS without ISO certification? Quality Manager and Management Related Issues 2
J Does anyone here use ISOXpress/IMSXpress QMS software? Software Quality Assurance 11
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
M Has anyone here assessed the latest Abbreviated 510(K) guidance document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Does anyone has a good verification and validation plan template? ISO 13485:2016 - Medical Device Quality Management Systems 3
D Has anyone undergone a BARDA (HHS) audit as part of their grant process? Other Medical Device Regulations World-Wide 0
QIE Anyone have experience with BPA Quality (QMS system based on Office365/Sharepoint) Quality Assurance and Compliance Software Tools and Solutions 1
M AMS0320 - Electro-deposition of zinc - Anyone come across this spec? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
M Anyone Dropping IATF and going back to ISO ? IATF 16949 - Automotive Quality Systems Standard 18
Sidney Vianna LinkedIn bug - Anyone has any idea of how to fix this? Posts not showing for me in a Group feed. Coffee Break and Water Cooler Discussions 2
R Anyone who can share a checklist for ISO 29134? IEC 27001 - Information Security Management Systems (ISMS) 7
G Can anyone tell me about Tooling FMEA FMEA and Control Plans 3
B Does anyone charge for annual layouts? APQP and PPAP 8
C Will anyone please share training material for ISO:13485:2016 for best practices Training - Internal, External, Online and Distance Learning 0
K Has anyone used QAI for training? Training - Internal, External, Online and Distance Learning 7
N Does anyone know a registrar that offers both ISO 9001 and ISO 17020? Registrars and Notified Bodies 6
W Does anyone have any experience with the Easy Metric System? General Measurement Device and Calibration Topics 2
J Does anyone have a good APQP template that meets IATF requirements? APQP and PPAP 3
A Anyone have experience with Transmille calibrators General Measurement Device and Calibration Topics 1
D Has anyone here had any experience with PQ-FMEA software? FMEA and Control Plans 1
D IATF 16949 - 8.5.2.1 Traceability Plan - Does anyone have an example? IATF 16949 - Automotive Quality Systems Standard 4
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
C Does anyone have an AS9100:2015 audit schedule template? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
S Has anyone completed IATF 16949 Certification - Share your Audit Experience? IATF 16949 - Automotive Quality Systems Standard 2
S Has anyone created a Turtle Diagram reflecting the new ISO 9001:2015 Structure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Does anyone have example test report of defibrillator IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Can anyone tell me requirements standards for insufflator? Other Medical Device Related Standards 1
