API 6A Chokes - PR1 / PR2 Tests
DinuStan
Hi all,
Greetings!!!
For API 6A Chokes, i have some below queries reg testing of validations.
Chokes as per API 6A 20th Edition clause 4 with fulfill the requirements of clause 10.9.
1.What is the difference between the Table 86(Performance Test Requirement) as per clause 10.9 in API Spec 6A and Annex F PR1/PR2 Requirements? since Table 86 doesn't have any detailed procedure clauses and Annex F is just an informative section (it shall be applied if purchaser or manufacturer need).
2. can Table 86 PR1/PR2 test procedure be written by manufacturer since it is only cyclic test for chokes?
Dinu
jmech
The difference between Table 86 and Annex F is exactly what you described: Annex F testing is only necessary if the manufacturer or purchaser specify it. A test procedure for validating that the product meets the Table 86 requirements can be written by the manufacturer.
Note: many purchasers of API 6A equipment misunderstand the meaning of PR2 and assume that requiring PR2 also requires Annex F PR2 testing. If you have a customer requiring PR2, I recommend clarifying with them if they want "normal" PR2 (ability to meet the cycle requirements from Table 86) or if they want Annex F PR2 testing.
DinuStan
Yes Jmech.. thanks for your reply..
the same interpretation is being with me also. but some of auditors from API asks during audit time, many things regardless of the subject about Table 86 and Annex F. Is there any reference documents from API Body about this queries or can we make a query regarding this to API Body?
thanks in advance...
jmech
Please see attached API 6A interpretations summary. Number 6A-2012-30 (at the bottom of page 15) is relevant. It clarifies several items:
1. The cycle requirements in the table are design requirements, not validation requirements. However, you need to somehow validate that your finished design met the design requirements, which is difficult to do without validation testing. For cycle testing of a choke, you need to fully open and fully close the choke 3 times. The temperature and pressure at which you do this is not specified by API 6A, so it is up to you.
2. Annex F is not required if not specified.
If an auditor is insisting that Annex F is required even when not specified by the manufacturer or the customer, you need to remind the auditor about the meaning of "informative". If they simply need an answer for the product questions of an audit, the answer is "not applicable". If they still insist that it should be required, contact the audit manager. If they write a finding, appeal it, and you should win easily.
DinuStan
oh my goodness!!! Thank You so much jmech...
the information and documents are really gonna very helpful for me.. thank you once again.
can i have your email Id... i am reachable at [email protected].
Thank You So much!!!
thrownrod
You don't happen to know of an API 6A 21st edition interpretations summary, do you?
DinuStan
In Api 21st Edition is having very clear thoughts between PR1/PR2 table Requirement and Annex F requirement. In annex F there is no pr1 and annex f pr test is named as PR2F. So here after PR1/PR2 is only about table requirement. It will not meant about annex F requirement.
Dear Sir, i have a question related to PR1 validation requirements according to API 6A 21st edition. Considering that now is not mentioned in Annex F how is now the API 6A requirement for validation ? Is it according to manufacturer internal procedure ?
lanley liao How to understand correctly the requirements of API monogram products Oil and Gas Industry Standards and Regulations 0
lanley liao Are there guidelines for application of all API monogrammal product? Oil and Gas Industry Standards and Regulations 2
U API License Agreements Oil and Gas Industry Standards and Regulations 2
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
R American Petroleum Institute - Becoming an API Auditor Professional Certifications and Degrees 2
B There is an estimated date of release of API Q1 10th edition? Oil and Gas Industry Standards and Regulations 8
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
lanley liao How to understand this bulleted list from API 600 Oil and Gas Industry Standards and Regulations 0
lanley liao The validity of API Spec Q1 certificate Oil and Gas Industry Standards and Regulations 2
R [ASK] API Q1 Ninth Edition, Section 5.4.5 Oil and Gas Industry Standards and Regulations 4
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
S API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
S API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 10
S API spec Q1 9th edition - Castings & Forgings Oil and Gas Industry Standards and Regulations 4
N API spec Q1 9th edition Oil and Gas Industry Standards and Regulations 2
H Updating Quality Manual to API Q1 Service Industry Specific Topics 6
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
F Who can sit in/perform an API audit? Oil and Gas Industry Standards and Regulations 2
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
M API Spec. Q1, 8th Ed. Section 7.5.2 vs. Q1, 9th Ed. Section 5.7.1.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 10
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
A API Spec Q1 9th Edition # Re-audit - Disputing with API AARs Oil and Gas Industry Standards and Regulations 1
T API Q1 - Will I be able to maintain Q1 if I have products that fall under 6A Oil and Gas Industry Standards and Regulations 5
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
P API monogram mark requirements Oil and Gas Industry Standards and Regulations 1
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
K 820.200 Servicing Procedure - Our system (because there is an API involved) is classified as Class 3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
K Supplier re-evaluation (API Q1) Manufacturing and Related Processes 8
F List of approved API manufacturers or Formulations manufacturers US Food and Drug Administration (FDA) 0
G Start and main steps of API Q1 Certification Process Various Other Specifications, Standards, and related Requirements 5
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
S Can we integrate both ISO 9001:2015 and API Q1 Management System Standards Quality Management System (QMS) Manuals 11
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
R Interesting Discussion API Spec Q1 Addendum 2 Oil and Gas Industry Standards and Regulations 0
F API Spec Q1 Scope - Limiting the scope of certification Oil and Gas Industry Standards and Regulations 3
F API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits. Oil and Gas Industry Standards and Regulations 22
A API Q1 9th ed Addendum 2 - Vendor Assessment for critical products Oil and Gas Industry Standards and Regulations 18
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
F Extension of a stability study for an API Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
R API 4F - Clause 11.10.3 Bolt Pretensioning Oil and Gas Industry Standards and Regulations 1
N API Q2 clause 6.2.2.1 Auditing Outsourced Suppliers Oil and Gas Industry Standards and Regulations 5
