API (American Petroleum Institute) Monogram - Applying and Removal Process
L
lilly35
can anyone show me a template on applying and removal process of a monogram. trying to write a procedure but stuck on the removal process of it.thank you
bluepagen
Procedures for applying and removing the API Monogram can be very short or very long, depending on the amount of information given on other specifications or drawings. You can indicate for applying, the person(s) (QC Supervisor, Machinists, Assembler, Stamper) will apply the API Monogram as indicated in (the specific place per the product specification and your drawings or specifications). You should say that it will only be applied when acceptance criteria has been reviewed and met through inspection and testing, and that it will only be applied at your physical address. Say who holds the stamp, and that it is protected.
For removal, indicate again "who" will remove the stamp when the product is found to be out of conformance to acceptance criteria, and describe the method of removal (like grinding).
P
Peach21
Can I have the template? I couldn't find from the link. Appreciate for the help.
Thank you very much.
R American Petroleum Institute - Becoming an API Auditor Professional Certifications and Degrees 2
A API (American Petroleum Institute) Design Package Content Requirements Oil and Gas Industry Standards and Regulations 1
B American Petroleum Institute's API Q1 Standard NINTH Edition Oil and Gas Industry Standards and Regulations 21
O API (American Petroleum Institute) Q1 - Anyone familiar with this standard? Oil and Gas Industry Standards and Regulations 16
H API (American Petroleum Institute) Spec Q1 Manual - Looking for samples Oil and Gas Industry Standards and Regulations 4
Q API (American Petrolium Institute) Spec 6D - Specification for pipeline valves Oil and Gas Industry Standards and Regulations 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
lanley liao Confusion between national standard and API related standard. Oil and Gas Industry Standards and Regulations 8
Thee Bouyyy API Q1 9th edition 5.4.3 c) and 5.4.3 d) Oil and Gas Industry Standards and Regulations 8
T Non API products need to comply to API Q1? Oil and Gas Industry Standards and Regulations 3
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
C API Q1 internal audit report Internal Auditing 3
lanley liao How to understand and master the requirements of each section in API monogram product. Oil and Gas Industry Standards and Regulations 5
Thee Bouyyy Internal NCR - API Q1 5.4.2b - API 16C Clause 4.1.3 Internal Auditing 9
lanley liao How to understand correctly the section of 5.11 MOC in API Spec Q1? Oil and Gas Industry Standards and Regulations 3
N NC on API Q2 Oil and Gas Industry Standards and Regulations 4
A API Monogram audit review process Oil and Gas Industry Standards and Regulations 5
lanley liao Are there guidelines for application of all API monogrammal product? Oil and Gas Industry Standards and Regulations 2
U API License Agreements Oil and Gas Industry Standards and Regulations 2
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
B There is an estimated date of release of API Q1 10th edition? Oil and Gas Industry Standards and Regulations 14
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
lanley liao How to understand this bulleted list from API 600 Oil and Gas Industry Standards and Regulations 0
lanley liao The validity of API Spec Q1 certificate Oil and Gas Industry Standards and Regulations 2
R [ASK] API Q1 Ninth Edition, Section 5.4.5 Oil and Gas Industry Standards and Regulations 4
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
S API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
S API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 10
S API spec Q1 9th edition - Castings & Forgings Oil and Gas Industry Standards and Regulations 4
N API spec Q1 9th edition Oil and Gas Industry Standards and Regulations 2
H Updating Quality Manual to API Q1 Service Industry Specific Topics 6
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
F Who can sit in/perform an API audit? Oil and Gas Industry Standards and Regulations 2
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
M API Spec. Q1, 8th Ed. Section 7.5.2 vs. Q1, 9th Ed. Section 5.7.1.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 25
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
A API Spec Q1 9th Edition # Re-audit - Disputing with API AARs Oil and Gas Industry Standards and Regulations 1
T API Q1 - Will I be able to maintain Q1 if I have products that fall under 6A Oil and Gas Industry Standards and Regulations 5
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
P API monogram mark requirements Oil and Gas Industry Standards and Regulations 1
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
K 820.200 Servicing Procedure - Our system (because there is an API involved) is classified as Class 3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
