API Q1 - 5.7.1.5 - Validation of Processes for Production and Servicing
Hello everyone,
Would like to know the best way to validate the processes as NDE (MPI and PT) and PWHT. Also advise if supplier is performing NDE at our premises how to validate that process?
Appreciate your views on these.
Regards,
Jay
Rene Minassian
Do it right the first time....
Hi Jay,
from my point of view the best way is to validate the process as described in the relevant norm or standard and there reference blocks defined by the norm or standard e.g. MT = Pie Gauge or Berthold. Or, if you have, a part you manufacture where you know you have failure which you like to identify. Those parts can be tested under the circumstances described in the procedure e.g. Ampere, Distance, Light, etc. etc. and if the failure are identified, fine, = validated. The same for the NDE service company.
jmech
I agree with Rene. As well, for NDE validation, you can find more detail in API 20D (although you would only be required to follow 20D if it is required by the product spec).
For PWHT validation, this is normally done together with the welding qualification. Weld and PWHT in accordance with the WPS, then test to validate that you achieved all the required properties (strength, hardness, etc.). If it passed, you've validated your WPS including the PWHT. Maintain the PQR with the test results as evidence.
Dear Jmech, We have used Pie Gauge but Auditor raised the Finding (Our Product Spec is API 6A which states API 20D or other applicable standard) as i am not sure whether Pie Gauge is acceptable by any standard referance. Also can you suggest for PT Validation also as we use Aluminium Block with Known defects. Thanks
Rene Minassian
Hi Jayendra, as far as I know, API 6A and API 20D do not require something specific. they refere to the common non destructive norms such as ASTM E 709 but may require a fluorescent inspection method or having spcific accaptance criteria. If we go in detail, the Pie Gauge would not be enough to validate. Off course you need a seperate validation of your fluid or suspension, magnitization, lightning (lx), etc. however, in the end the System is validated with the pie gauge having all elements verified on its own. Pie gauge allown would not enough.
W.r.t. penetrant testing, please find attached reference block we use to validate the test with. When testing youre product, you do exact the same with the reference block. This have never doubt in an Audit.
L Validation Processes of Production & Servicing - API Q1 clause 5.7.1.5 Oil and Gas Industry Standards and Regulations 2
B Validation of design for valve api 6d 25 edition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
B Hi , everyone i need a procedure for validation of design prototype api 6d (valve manufacturing) Oil and Gas Industry Standards and Regulations 1
B How to satisfy clause 5.7.1.5 process validation for valve production API 6D Oil and Gas Industry Standards and Regulations 13
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
M API Q1 Validation in Europe Oil and Gas Industry Standards and Regulations 8
D Process Validation Protocol (API) as per new FDA Guidelines Qualification and Validation (including 21 CFR Part 11) 18
T Validation of water system in API (Active Pharmaceutical Ingredients) unit Qualification and Validation (including 21 CFR Part 11) 5
J Response time from API for review of responses to audit findings Oil and Gas Industry Standards and Regulations 7
R Marking on API 20E bolts Oil and Gas Industry Standards and Regulations 1
J API 5CT - NDE for Accessory Material - Section 10.15.11 Oil and Gas Industry Standards and Regulations 2
J API Q1 - 5.6.1.2 (b) - Initial Supplier Evaluation—Critical Purchases Oil and Gas Industry Standards and Regulations 1
D API Q1 clause (1.0) Scope Oil and Gas Industry Standards and Regulations 1
D API Q1 clause (5.6.3) Verification of Purchased Products or Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I API Q1 5.7.1.5.a and API 6A10.4.2.12.2 AAR in API audit Oil and Gas Industry Standards and Regulations 0
M API SPEC Q1 9th edition NCR Oil and Gas Industry Standards and Regulations 3
M API Q1 9th edition NCR Oil and Gas Industry Standards and Regulations 10
A Metadata For Drugs, API's, Regulatory & Clinical Documents and Dossier Service Industry Specific Topics 2
J API Q2 clause 5.4.3 b) Oil and Gas Industry Standards and Regulations 3
P Product Quality Review API-GMP Manufacturing and Related Processes 0
A API Q1 9th Edition Surveillance Audit - Quality Policy Oil and Gas Industry Standards and Regulations 2
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
J API Spec Q1 9th Ed. Oil and Gas Industry Standards and Regulations 4
B Evaluation of suppliers API Spec Q1 5.6.1.2c Oil and Gas Industry Standards and Regulations 2
T API 4F & 7K license - Add Mexico location? Oil and Gas Industry Standards and Regulations 5
B Validating calibration certificate as per API Q1 General Measurement Device and Calibration Topics 9
B API 5L for Cold Drawn Pipes Oil and Gas Industry Standards and Regulations 2
G API 5DP Monogram Licensee Oil and Gas Industry Standards and Regulations 6
H API monogram 4F - Certification process Oil and Gas Industry Standards and Regulations 2
N API Q1, Management of Change & Document Change Request Oil and Gas Industry Standards and Regulations 4
N API Q1 Audit Surveillance - Questions Oil and Gas Industry Standards and Regulations 2
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 17
J QTC Requirement as per API 6A-21st Edition Oil and Gas Industry Standards and Regulations 1
D What are the Activity deemed critical for the API 6D Ball Valve ? Oil and Gas Industry Standards and Regulations 4
Q API Spec Q1 9th Ed 4.4.2 Non-conformance Oil and Gas Industry Standards and Regulations 8
J API Q1 4.3.2.2 Personnel Competence for Internal Auditors Oil and Gas Industry Standards and Regulations 5
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
D How to testing of Pressure relief valve as per API 6D ? Oil and Gas Industry Standards and Regulations 1
J API Spec 6D 25th edition release date? Oil and Gas Industry Standards and Regulations 23
P API Q1 - Monogram Product & API 4F - Proof Load Test Oil and Gas Industry Standards and Regulations 3
T API SPEC Q1 Clause 5.6.1.2.C).2) First Article Oil and Gas Industry Standards and Regulations 16
L API Q1 Application Oil and Gas Industry Standards and Regulations 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
lanley liao Confusion between national standard and API related standard. Oil and Gas Industry Standards and Regulations 8
T API Q1 9th edition 5.4.3 c) and 5.4.3 d) Oil and Gas Industry Standards and Regulations 13
T Non API products need to comply to API Q1? Oil and Gas Industry Standards and Regulations 3
C API Q1 internal audit report Internal Auditing 3
lanley liao How to understand and master the requirements of each section in API monogram product. Oil and Gas Industry Standards and Regulations 5
