API Q1 Audit Surveillance - Questions
Hi Colleagues,
We are a manufacturer for API 5LD clad products with API Q1 certification. Post our last external audit by API we haven't manufactured any monogrammed products (API 5LD). However we have manufactured monogrammable products partially complying to API 5LD. So in preparation to next surveillance audit do we have to manufacture a demo product and test in line with requirements of API 5LD or partially compliant reports will be suffice for the audit?
Hi,Nith.indsilva4u,
Although your question is a little vague, i can understand your meaning. You actually would like to ask a question that how to demonstrate your manufacturing capability for API 5LD monogrammed products in the next surveillance. You can produce parts of API 5LD that are used to be in stock and make a prototype to indicate your manufacturing capability to your auditor.
jmech
Producing demo product just for the audit is often frowned upon by API. If you are still making product similar to monogrammable product, that is likely enough to demonstrate capability. You can contact API prior to your audit to clarify the situation if you are unsure.
A API Q1 9th Edition Surveillance Audit - Quality Policy Oil and Gas Industry Standards and Regulations 2
F API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits. Oil and Gas Industry Standards and Regulations 22
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 17
C API Q1 internal audit report Internal Auditing 3
A API Monogram audit review process Oil and Gas Industry Standards and Regulations 5
F Who can sit in/perform an API audit? Oil and Gas Industry Standards and Regulations 2
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 25
A API Spec Q1 9th Edition # Re-audit - Disputing with API AARs Oil and Gas Industry Standards and Regulations 1
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
R Closing out an API/ISO QMS Audit Nonconformance - Magnetic Particle Examination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Internal Audit checklist as per API Q1 ninth edition wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C API Q1 9th Edition Internal Audit Checklist /Report Oil and Gas Industry Standards and Regulations 22
H API Spec Q1 7.5.2 & 7.5.2.1 - Audit Nonconformance Help Oil and Gas Industry Standards and Regulations 15
K Is use of API's Audit Report format for Internal Audit OK or is it an Overkill? Oil and Gas Industry Standards and Regulations 7
D Preparing a Design Package for API 6A Valves for the Monogram audit Oil and Gas Industry Standards and Regulations 13
M API SPEC Q1 9th edition NCR Oil and Gas Industry Standards and Regulations 3
M API Q1 9th edition NCR Oil and Gas Industry Standards and Regulations 9
A Metadata For Drugs, API's, Regulatory & Clinical Documents and Dossier Service Industry Specific Topics 2
J API Q2 clause 5.4.3 b) Oil and Gas Industry Standards and Regulations 3
P Product Quality Review API-GMP Manufacturing and Related Processes 0
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
J API Spec Q1 9th Ed. Oil and Gas Industry Standards and Regulations 4
B Evaluation of suppliers API Spec Q1 5.6.1.2c Oil and Gas Industry Standards and Regulations 2
T API 4F & 7K license - Add Mexico location? Oil and Gas Industry Standards and Regulations 5
B Validating calibration certificate as per API Q1 General Measurement Device and Calibration Topics 9
B API 5L for Cold Drawn Pipes Oil and Gas Industry Standards and Regulations 2
G API 5DP Monogram Licensee Oil and Gas Industry Standards and Regulations 6
H API monogram 4F - Certification process Oil and Gas Industry Standards and Regulations 2
N API Q1, Management of Change & Document Change Request Oil and Gas Industry Standards and Regulations 4
J QTC Requirement as per API 6A-21st Edition Oil and Gas Industry Standards and Regulations 1
D What are the Activity deemed critical for the API 6D Ball Valve ? Oil and Gas Industry Standards and Regulations 4
B How to satisfy clause 5.7.1.5 process validation for valve production API 6D Oil and Gas Industry Standards and Regulations 13
Q API Spec Q1 9th Ed 4.4.2 Non-conformance Oil and Gas Industry Standards and Regulations 8
J API Q1 4.3.2.2 Personnel Competence for Internal Auditors Oil and Gas Industry Standards and Regulations 4
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
D How to testing of Pressure relief valve as per API 6D ? Oil and Gas Industry Standards and Regulations 1
J API Spec 6D 25th edition release date? Oil and Gas Industry Standards and Regulations 23
P API Q1 - Monogram Product & API 4F - Proof Load Test Oil and Gas Industry Standards and Regulations 3
T API SPEC Q1 Clause 5.6.1.2.C).2) First Article Oil and Gas Industry Standards and Regulations 16
L API Q1 Application Oil and Gas Industry Standards and Regulations 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
lanley liao Confusion between national standard and API related standard. Oil and Gas Industry Standards and Regulations 8
T API Q1 9th edition 5.4.3 c) and 5.4.3 d) Oil and Gas Industry Standards and Regulations 13
T Non API products need to comply to API Q1? Oil and Gas Industry Standards and Regulations 3
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
lanley liao How to understand and master the requirements of each section in API monogram product. Oil and Gas Industry Standards and Regulations 5
T Internal NCR - API Q1 5.4.2b - API 16C Clause 4.1.3 Internal Auditing 9
lanley liao How to understand correctly the section of 5.11 MOC in API Spec Q1? Oil and Gas Industry Standards and Regulations 3
N NC on API Q2 Oil and Gas Industry Standards and Regulations 4
