API Q1 Clause 7.1.1 Planning of Product Realisation
claire_deen
Hi guys,
I am totally lost here. It is the supplemental section that states:
when product requirements are provided from external sources the organisation shall define the methods and shall establish control features used to translate these requirements into the product realisation process.
What on earth? The place I'm doing my masters project for get their specifications and pipes from the client and then carry out the welding etc needed for that. Can anyone shed any light on this please?
Thank you
Claire :thanx:
Duke Okes
So if you're working to external product specifications you have to have a process for reviewing them and creating appropriate internal controls, which might include your own specs, work instructions, data analysis, etc. to control the process to ensure the external specs will be met. Frankly it seems redundant, because you have to do the same for internal specs, but I assume in the petroleum industry a lot more of the specs are from outside (e.g., industry standards).
N
nyasar
This clause makes me confused also.
In this supplemental requirement they say, in brief, 'translate these requirements which are provided external sources, into the product realization process.'
Has this supplemental requirement pointed at requirements specified by the customer (7.2.1-a) and statutory and regulatory requirements (7.2.1.c) or something more than or different from this?
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
R API 4F - Clause 11.10.3 Bolt Pretensioning Oil and Gas Industry Standards and Regulations 1
N API Q2 clause 6.2.2.1 Auditing Outsourced Suppliers Oil and Gas Industry Standards and Regulations 5
L Validation Processes of Production & Servicing - API Q1 clause 5.7.1.5 Oil and Gas Industry Standards and Regulations 2
C API Q1 8th ed Clause 7.4 Purchasing - 7.4.1.1 Purchasing Process (supplemental) Oil and Gas Industry Standards and Regulations 9
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 10
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 10
D API Spec Q1 9th Edition # Re-audit - Disputing with API AARs Oil and Gas Industry Standards and Regulations 2
T API Q1 - Will I be able to maintain Q1 if I have products that fall under 6A Oil and Gas Industry Standards and Regulations 5
P API monogram mark requirements Oil and Gas Industry Standards and Regulations 1
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
K 820.200 Servicing Procedure - Our system (because there is an API involved) is classified as Class 3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
K Supplier re-evaluation (API Q1) Manufacturing and Related Processes 8
F List of approved API manufacturers or Formulations manufacturers US Food and Drug Administration (FDA) 0
D API Q1 Supplement Audit Format Internal Auditing 0
G Start and main steps of API Q1 Certification Process Various Other Specifications, Standards, and related Requirements 5
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
S Can we integrate both ISO 9001:2015 and API Q1 Management System Standards Quality Management System (QMS) Manuals 11
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
R Interesting Discussion API Spec Q1 Addendum 2 Oil and Gas Industry Standards and Regulations 0
F API Spec Q1 Scope - Limiting the scope of certification Oil and Gas Industry Standards and Regulations 3
F API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits. Oil and Gas Industry Standards and Regulations 23
A API Q1 9th ed Addendum 2 - Vendor Assessment for critical products Oil and Gas Industry Standards and Regulations 16
DinuStan API 6A Chokes - PR1 / PR2 Tests Oil and Gas Industry Standards and Regulations 11
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
F Extension of a stability study for an API Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
M API Spec Q2 Design and Development Requirements for Service Providers Oil and Gas Industry Standards and Regulations 11
R Closing out an API/ISO QMS Audit Nonconformance - Magnetic Particle Examination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D API 5CT Compliant Quality Plan for Manufacturing Manufacturing and Related Processes 0
M API 6D-2014 24th Ed. Pto 6.10 - Heat Treatment Equipment Qualifications Oil and Gas Industry Standards and Regulations 4
M API Monogram License for a Small Machine Shop Oil and Gas Industry Standards and Regulations 1
A Integrating API Spec Q1 with ISO 9001:2015 Oil and Gas Industry Standards and Regulations 18
O Cleaning API Rotary Shoulder Connections Working Mates exposed to Outside Weather General Measurement Device and Calibration Topics 1
F Quality Manual Updates - ISO 9001:2015 and API Q1 9th Editition Quality Management System (QMS) Manuals 14
M API Q1 Certification Activation - Waiting, Waiting, and Waiting... Oil and Gas Industry Standards and Regulations 3
S API SPEC 7-1, 7-2 and 5 CT implementation Oil and Gas Industry Standards and Regulations 3
K API Monogram Procedure example wanted Oil and Gas Industry Standards and Regulations 2
V Pre-dispensed API material received in predetermined quantities & given to production Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
J API Q1 5.6.1.2 (iii) Identifying how the supplied product conforms Oil and Gas Industry Standards and Regulations 1
J Add API Q1 & Q2 to Quality Management System Standards Oil and Gas Industry Standards and Regulations 1
S API Q1 Approved Training & Professional Certification Sources Oil and Gas Industry Standards and Regulations 5
K Vendor Management for an API Manufacturer? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
J Charpy impact test - Mill cert for API 13CrL80 coupling stock material with is PLS 2 Oil and Gas Industry Standards and Regulations 1
D Control of Nonconforming product (5.10 API Q1) Oil and Gas Industry Standards and Regulations 3
J API Q1 Certification for Design and Development company Oil and Gas Industry Standards and Regulations 3
G API Q1 compliant Service Procedure example wanted Oil and Gas Industry Standards and Regulations 1
A API (American Petroleum Institute) Design Package Content Requirements Oil and Gas Industry Standards and Regulations 1
