API Q1, Management of Change & Document Change Request
Hi,Nithindsilva4u, You should do a MOC if you were changing a QMS Procedure affecting product quality. otherwise, you should do a document change request. The MOC was stated clearly in section 5.11.2 of API Spec Q1, First paragraph----"The organization shall use the moc process for any of the following that may negatively impact the quality of the product:"
I hope it can help you.
nithindsilva4u - well, I would first go with document change notice program where I can identify that whether it will affecting on quality of product negatively or not. If it is than, next step is MOC and if it isn't than staright away no need of MOC. Document change notice program document is enough.
In your case you have to do both. MOC and Document change request.
badidi
hi, to change a document you should follow the procedure control of document it exposes the way to change or creat a document and the control of version
S Software Application for Management of Change (API 5.11) Other ISO and International Standards and European Regulations 3
S Can we integrate both ISO 9001:2015 and API Q1 Management System Standards Quality Management System (QMS) Manuals 11
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
J Add API Q1 & Q2 to Quality Management System Standards Oil and Gas Industry Standards and Regulations 1
K Vendor Management for an API Manufacturer? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
S Product Risk Assessment and Management Procedure per API Q1 9th Edition Oil and Gas Industry Standards and Regulations 8
I Contingency Plan that meets requirements of API Q1 Quality Management System Other ISO and International Standards and European Regulations 3
T API 4F & 7K license - Add Mexico location? Oil and Gas Industry Standards and Regulations 5
B Validating calibration certificate as per API Q1 General Measurement Device and Calibration Topics 9
B API 5L for Cold Drawn Pipes Oil and Gas Industry Standards and Regulations 2
G API 5DP Monogram Licensee Oil and Gas Industry Standards and Regulations 6
H API monogram 4F - Certification process Oil and Gas Industry Standards and Regulations 2
N API Q1 Audit Surveillance - Questions Oil and Gas Industry Standards and Regulations 2
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 17
J QTC Requirement as per API 6A-21st Edition Oil and Gas Industry Standards and Regulations 1
D What are the Activity deemed critical for the API 6D Ball Valve ? Oil and Gas Industry Standards and Regulations 4
B How to satisfy clause 5.7.1.5 process validation for valve production API 6D Oil and Gas Industry Standards and Regulations 13
Q API Spec Q1 9th Ed 4.4.2 Non-conformance Oil and Gas Industry Standards and Regulations 8
J API Q1 4.3.2.2 Personnel Competence for Internal Auditors Oil and Gas Industry Standards and Regulations 4
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
D How to testing of Pressure relief valve as per API 6D ? Oil and Gas Industry Standards and Regulations 1
J API Spec 6D 25th edition release date? Oil and Gas Industry Standards and Regulations 22
P API Q1 - Monogram Product & API 4F - Proof Load Test Oil and Gas Industry Standards and Regulations 3
T API SPEC Q1 Clause 5.6.1.2.C).2) First Article Oil and Gas Industry Standards and Regulations 16
L API Q1 Application Oil and Gas Industry Standards and Regulations 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
lanley liao Confusion between national standard and API related standard. Oil and Gas Industry Standards and Regulations 8
T API Q1 9th edition 5.4.3 c) and 5.4.3 d) Oil and Gas Industry Standards and Regulations 12
T Non API products need to comply to API Q1? Oil and Gas Industry Standards and Regulations 3
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
C API Q1 internal audit report Internal Auditing 3
lanley liao How to understand and master the requirements of each section in API monogram product. Oil and Gas Industry Standards and Regulations 5
T Internal NCR - API Q1 5.4.2b - API 16C Clause 4.1.3 Internal Auditing 9
lanley liao How to understand correctly the section of 5.11 MOC in API Spec Q1? Oil and Gas Industry Standards and Regulations 3
N NC on API Q2 Oil and Gas Industry Standards and Regulations 4
A API Monogram audit review process Oil and Gas Industry Standards and Regulations 5
lanley liao Are there guidelines for application of all API monogrammal product? Oil and Gas Industry Standards and Regulations 2
U API License Agreements Oil and Gas Industry Standards and Regulations 2
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
R American Petroleum Institute - Becoming an API Auditor Professional Certifications and Degrees 3
B Is there an estimated date of release of API Q1 10th edition? Oil and Gas Industry Standards and Regulations 22
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 19
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
lanley liao How to understand this bulleted list from API 600 Oil and Gas Industry Standards and Regulations 0
lanley liao The validity of API Spec Q1 certificate Oil and Gas Industry Standards and Regulations 2
R [ASK] API Q1 Ninth Edition, Section 5.4.5 Oil and Gas Industry Standards and Regulations 4
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 9
SANTHSH API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
SANTHSH API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 12
