API Q1 Validation in Europe
mkerton0120
Hi :bigwave:
Does anyone know of a european API inspector/representative that can validate/mongram a QMS system to API Q1 ninth edition. The QMS system is being set up at a UK division. I have looked at the API web site and just about all other continents are covered but no mention of Europe! Any assistance/contacts appreciated.
Rgds
mark
Sajith
mkerton0120
Sajith
thanks for info, ive already got the conformity matrix and the QMS is looking good, but we all know what auditors are capable of;).
Rgds
Mark
DP561
Mark,
I'm new here and in the UK. Did you get any more info with regards to your question. Have you had an audit yet?
mkerton0120
Hi DP561
welcome to the uk! I am in the same situation as yourself. Q1 managment system to put in place from nothing, procedures, manual,training etc. i am also going for API 6A monogramming at the same time along with other specs in the future. I have not had an audit as yet as i am working alone! I planned for 3 months to do the procedures but looks like im going to run approx 3 weeks late due to other factors.
I have had contact from API directly who will audit your system, cost is dependant on the size of the company API Q1 also includes ISO 9001. There are auditors in the UK that will help you prepare but it will cost you.
API have been really helpful. If you complete your conformity matrix when your ready and send it to them they can advise. The conformity matrix is a really good tool to use to keep you on the right track.
I believe they are more rigorous now than compared to the past but it is in their interest also to point you in the right direction. My advice is get in touch with API directly for a quote and they will assist you all they can.
Rgds
mark
DP561
Hi Mark,
Thanks for your fast reply. I've started keeping this forum open all day as it is such a good source of info.
I'm brand new to this area, my company employed the services of a consultant last year who produced 'something' in line with the API 8th edition (even though the 9th edition was published). Needless to say, I archived everything and started from scratch.
We have registered with API and have bought the 9th edition and I am slowly going through it now. I say slowly as the 'jargon' is all new to me.
I downloaded a copy of the conformity matrix and intend to start using it. When I am ready with everything and send it off to API, will they advise on any areas that need more work prior to them organising an audit, or do they just arrange an audit without any feedback on the matrix?
Regards,
Dave.
mkerton0120
DP561
API will review your matrix and advise as they request you send a copy of the completed matrix prior to the auditing.
I found it much easier to base my quality manual by section so it is much easier to cross check against the conformity matrix.
for example : My Quality plan for control of documents is given the number QP 423 which refers to section 4.2.3 of API Q1, and the forms and work instruction also refers to this number ie F -423-001 etc. This make life a lot easier when tracking your documents at the start.
Theres also a lot of assistance on this forum just alter your search criteria and i found lots of good advice.
Rgds
Mark
lawcch
hi, everyone
It is a tough job if you want to start from a stretch. I am a consultant helping a company with the facility to get API 6A/ 6D.
There are many things you need to know and implement before you can start to do the API monogram audit, you need to have a QMS compliant to API Q1 system in place and fully implemented for at least 4 months. therefore, it is recommended that you need more time and efforts to do the API Monogram Licensee program as it requires organisation to have QMS based on API Q1 standard to be fully implemented. Then we can look at the detail requirements as per applicable API Spec. product standard or service standard.
You need to have all the relevant records as specified in API Q1 and API Spec 6A/6D.
Therefore, you need to know the real technical stuff here before you can implement the whole system as an overview.
creating master list for almost all the records and SOP documents or Quality Manual make life easier for reference and control.
your records can be in electronic copies and not only in hard copies.
All records related to QA/ QC must be signed off and dated. You have to define who is preparing , reviewed and approved.
Where possible, you must have a overall processes work flow in flow charting diagram to reflect all the 4 elements within the QMS processes: Management responsibility and leadership, resources management, product realisation (or valve manufacturing / valve maintenance servicing processes and Monitoring, measurement and improvement.
regard, Lawrence
Sajith
Rgds
Mark
hello can you help me to fill API Q 1 Conformity matrix?
I need help about this its first time for me
If you have complete form it can be help me
thanks in advance
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
L Validation Processes of Production & Servicing - API Q1 clause 5.7.1.5 Oil and Gas Industry Standards and Regulations 2
D Process Validation Protocol (API) as per new FDA Guidelines Qualification and Validation (including 21 CFR Part 11) 18
T Validation of water system in API (Active Pharmaceutical Ingredients) unit Qualification and Validation (including 21 CFR Part 11) 5
lanley liao How to understand correctly the requirements of API monogram products Oil and Gas Industry Standards and Regulations 0
lanley liao Are there guidelines for application of all API monogrammal product? Oil and Gas Industry Standards and Regulations 2
U API License Agreements Oil and Gas Industry Standards and Regulations 2
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
R American Petroleum Institute - Becoming an API Auditor Professional Certifications and Degrees 2
B There is an estimated date of release of API Q1 10th edition? Oil and Gas Industry Standards and Regulations 8
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
lanley liao How to understand this bulleted list from API 600 Oil and Gas Industry Standards and Regulations 0
lanley liao The validity of API Spec Q1 certificate Oil and Gas Industry Standards and Regulations 2
R [ASK] API Q1 Ninth Edition, Section 5.4.5 Oil and Gas Industry Standards and Regulations 4
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
S API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
S API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 10
S API spec Q1 9th edition - Castings & Forgings Oil and Gas Industry Standards and Regulations 4
N API spec Q1 9th edition Oil and Gas Industry Standards and Regulations 2
H Updating Quality Manual to API Q1 Service Industry Specific Topics 6
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
F Who can sit in/perform an API audit? Oil and Gas Industry Standards and Regulations 2
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
M API Spec. Q1, 8th Ed. Section 7.5.2 vs. Q1, 9th Ed. Section 5.7.1.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 10
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
A API Spec Q1 9th Edition # Re-audit - Disputing with API AARs Oil and Gas Industry Standards and Regulations 1
T API Q1 - Will I be able to maintain Q1 if I have products that fall under 6A Oil and Gas Industry Standards and Regulations 5
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
P API monogram mark requirements Oil and Gas Industry Standards and Regulations 1
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
K 820.200 Servicing Procedure - Our system (because there is an API involved) is classified as Class 3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
K Supplier re-evaluation (API Q1) Manufacturing and Related Processes 8
F List of approved API manufacturers or Formulations manufacturers US Food and Drug Administration (FDA) 0
G Start and main steps of API Q1 Certification Process Various Other Specifications, Standards, and related Requirements 5
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
S Can we integrate both ISO 9001:2015 and API Q1 Management System Standards Quality Management System (QMS) Manuals 11
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
R Interesting Discussion API Spec Q1 Addendum 2 Oil and Gas Industry Standards and Regulations 0
F API Spec Q1 Scope - Limiting the scope of certification Oil and Gas Industry Standards and Regulations 3
F API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits. Oil and Gas Industry Standards and Regulations 22
A API Q1 9th ed Addendum 2 - Vendor Assessment for critical products Oil and Gas Industry Standards and Regulations 18
D API 6A Chokes - PR1 / PR2 Tests Oil and Gas Industry Standards and Regulations 12
