API Q2 Specification - QMS (Oil & Gas Industry Aftermarket)
Del Foster
#11
I managed to meet briefly this week with a key indivdual at API to learn more about Q2 as well as what may be going on with EPA and their concerns about frac water chemicals and the practice of storing the back water in ponds rather than in containers, etc. I am a consultant and ISO 9001 lead auditor trying to help a client with new technology designed to treat frac water and eliminate those problems obtain Q2 registration. I too am interested in more discussion and planning for Q2. Count me in. Del Foster
I found and printed a copy of draft 16 of Q2 and noticed quite a few changes and differences between Q2 and Q1, most notably the requirement for 23 documented procedures, the absense of "control feature" and the focus on risk management, change management, and the call for a service quality plan. Any thoughts or ideas for a quality manual to meet Q2 certification by anyone?
Bud Weightman
#12
There are significant changes between Q1 and Q2 as Q1 currently stands. I recommend that you obtain a current copy of Q2, December 2011 edition since further changes were made as part of API's balloting process prior to publishing.
With regards to Q1: it is currently under a revision process and will be brought into line with the format and content of Q2 sometime this year. The obvious and major difference being Q1 is for manufacturing and Q2 is for service.
With regards to documenting a quality manual to Q2: (1) I recommend purchasing the current copy of Q2 so that the manual will be accurate. (2) be ready for possible changes to Q2; the industry is weighing in on the Q2 implementation practices.
The bottom line: it will be prudent to document a quality manual to Q2, but do so with the understanding that additional changes (most likely not substantive) may occur.
The Mutha
#13
We're a new startup in Oil & Gas manufacturing. We're working on getting our API 4F status now, but were told by our consulting group that we have to comply to Q1 status in order to be 4F certified. If we have to be Q1 compliant anyway, we might as well be Q1 certified. The consultant also stated that we'd better hurry with the Q1 as when Q2 goes into effect, the ability to apply strictly for Q1 goes away. If your company already has Q1 then the company would be grandfathered in and not have to jump to Q2. However, based on my research, given that we're a manufacturing company and do no servicing, we would only be bound to Q1 standards.
Am I understanding this correctly? If so, then I have to wonder as to the motives behind the consultant's recommendations...
Bud Weightman
#14
With regards to your API Spec. 4F needs. API Spec. 4F falls under API’s Monogram Program License Agreement. The API audit for Spec. 4F will also include conformity to API Spec. Q1 as part of the licensing process.
However, if you want to have a Spec. Q1 audit as an independent method of demonstating a certification of your management system, the API can also include that as part of their audit scope. No additional time will be required, but there are some nuances:
· An API License to 4F is just that; it is a license. While the audit includes API Spec. Q1 you will receive only the license if you successfully pass the audit.
o The renewal period for your license is 3 years.
· On API’s Application Form, you can choose to have a Management System Certification to:
o API Spec. Q1
o ISO 9001
o TS 29001
o OR, all three
· If you need an independent statement or your QMS conformity / a management system certification, then the conformity assessment rules apply. You will be audited every year.
For more information, the API identifies the pricing scheme in their application process.
With regards to Q1 and Q2:
· Q1 is for manufacturing and is a necessary part of the Monogram Program (e.g., 4F) licensing process. While Q1 is currently in the revision process, there is no intent to replace it with Q2.
· Q2 is for service related activities (e.g., associated with the well site).
Both of these standards will be controlled as separate programs under API’s auspices.
The requirements of these programs are complex; it may be a simple case of not understanding all the nuances and end use of the products / services.
At any rate, you may want to have an independent pre-assessment prior to going for your API audit.
ahhock
#15
Some additional info to share...
-If you are applying for solely API 4F Monogram license, you will be subject to audit once every 3 years. Compliance to API Spec Q1 is a requirement, however you are not required to go for the registration.
-If you choose to apply for both API 4F Monogram license plus the API Spec Q1 registration, you will be subject to annual audits. Along with the Spec Q1 registration, you can opt to be certified to both ISO/TS 29001 and ISO 9001 at the same time without additional cost since Spec Q1 covers all requirements of the above 2 standards.
cheers....
ahhock
#18
I think Stacey Hagen from Exxon gave a presentation on API Spec Q2 recently during the API pipelines conference. The presentation materials are available on API website. API website - Events & Training - Proceedings - Pipeline Proceedings .
Del Foster
#19
The latest information I have from API is that the Q2 final revision has been released and that the API QR will begin taking Q2 registration applications January 1, 2013. Del Foster
ahhock
#20
Yes, the specification has already been released and is available for purchase at IHS and Techstreet websites. I guess registration requirements and packages will also be announced by API later this year.
D API Specification Q1 for Pump Jack Oil and Gas Industry Standards and Regulations 1
T API 5CT PSL1 & PSL2 Levels - Specification for Casing and Tubing Oil and Gas Industry Standards and Regulations 5
Q API (American Petrolium Institute) Spec 6D - Specification for pipeline valves Oil and Gas Industry Standards and Regulations 2
R American Petroleum Institute - Becoming an API Auditor Professional Certifications and Degrees 2
B There is an estimated date of release of API Q1 10th edition? Oil and Gas Industry Standards and Regulations 8
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 15
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 5
lanley liao How to understand this bulleted list from API 600 Oil and Gas Industry Standards and Regulations 0
lanley liao The validity of API Spec Q1 certificate Oil and Gas Industry Standards and Regulations 2
R [ASK] API Q1 Ninth Edition, Section 5.4.5 Oil and Gas Industry Standards and Regulations 4
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
S API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
S API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 10
S API spec Q1 9th edition - Castings & Forgings Oil and Gas Industry Standards and Regulations 4
N API spec Q1 9th edition Oil and Gas Industry Standards and Regulations 2
H Updating Quality Manual to API Q1 Service Industry Specific Topics 4
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
F Who can sit in/perform an API audit? Oil and Gas Industry Standards and Regulations 2
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
M API Spec. Q1, 8th Ed. Section 7.5.2 vs. Q1, 9th Ed. Section 5.7.1.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 10
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 10
A API Spec Q1 9th Edition # Re-audit - Disputing with API AARs Oil and Gas Industry Standards and Regulations 1
T API Q1 - Will I be able to maintain Q1 if I have products that fall under 6A Oil and Gas Industry Standards and Regulations 5
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
P API monogram mark requirements Oil and Gas Industry Standards and Regulations 1
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
K 820.200 Servicing Procedure - Our system (because there is an API involved) is classified as Class 3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
K Supplier re-evaluation (API Q1) Manufacturing and Related Processes 8
F List of approved API manufacturers or Formulations manufacturers US Food and Drug Administration (FDA) 0
G Start and main steps of API Q1 Certification Process Various Other Specifications, Standards, and related Requirements 5
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
S Can we integrate both ISO 9001:2015 and API Q1 Management System Standards Quality Management System (QMS) Manuals 11
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
R Interesting Discussion API Spec Q1 Addendum 2 Oil and Gas Industry Standards and Regulations 0
F API Spec Q1 Scope - Limiting the scope of certification Oil and Gas Industry Standards and Regulations 3
F API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits. Oil and Gas Industry Standards and Regulations 22
A API Q1 9th ed Addendum 2 - Vendor Assessment for critical products Oil and Gas Industry Standards and Regulations 18
D API 6A Chokes - PR1 / PR2 Tests Oil and Gas Industry Standards and Regulations 12
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
F Extension of a stability study for an API Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
R API 4F - Clause 11.10.3 Bolt Pretensioning Oil and Gas Industry Standards and Regulations 1
N API Q2 clause 6.2.2.1 Auditing Outsourced Suppliers Oil and Gas Industry Standards and Regulations 5
M API Spec Q2 Design and Development Requirements for Service Providers Oil and Gas Industry Standards and Regulations 11
