API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits.
dears Mates,
looking for complete covered answer for that recently founded by Auditor. for that corrective action
Internal Audit Plan for 2018 doesn’t contain nonconformity nor criticality from the last Internal Audit.
audit planing need to have ( area need more than one audit ) and including third parity at your audit plan.
Nonconformance/Concern Description Internal Audit Plan for 2018 doesn’t contain nonconformities nor criticality from the last Internal Audit.
Jean_B
In short: It doesn't have to show that explicitly. It simply needs to "take into consideration the importance of processes concerned, ..., results of previous audits". (The only records required are: implementation of the audit programme (not establishing or determining, the standard even says implement is only Do from PDCA) & audit results.)
There is no requirement to have explicit records of this specific fact (incompetent/lazy auditors expect all needed evidence or compliance to be written down to make it easy for them) as a competent auditor should be able to determine this from context: e.g. when the last three years a process has had NC's it should not be skipped next year, yet if it has always performed well they should not fault you for spending audit resources wisely (unless there is a particular safety risk you should always keep tabs which doesn't go away with it running well for an extended time, e.g. medical devices sterilization process).
If your audit programming/planning process states it takes "importance of processes concerned, ..., results of previous audits" into consideration, selects the risky processes (e.g. pareto always risky or bad performance, a bit lower frequency for the middle risk, for-cause on the negligible risk ones) and subsequently focuses on those nothing is a-miss (if you do execute this). This is the parsimonious solution.
The rationale is you'd be looking for higher quality information on risky items from the audits versus a lot of lower quality information on all items, even the ones you've got a handle on through regular process monitoring.
Technically (nearly) nobody audits all processes (even work instructions cover processes, just in more detail, and how often have you seen auditors expect audits on all of those?), and if they do a portion of these will be of a superfluous nature. Note that based on normative requirements it is only the automotive QMS that requires you to audit all processes of your QMS within a certain period, thus there it is interpreted to mean prioritization of which to do first/often. If you have an additional regulatory oversight organization checking you might be in for double trouble as regulations can get iffy on wording and switching away from them is more difficult than switching away from an incompetent certification provider with no other sticks to hit you with.
What is an internal audit plan? Is this part of your own procedure for internal audits? Can you confirm which auditor wrote this?
M API SPEC Q1 9th edition NCR Oil and Gas Industry Standards and Regulations 3
J API Spec Q1 9th Ed. Oil and Gas Industry Standards and Regulations 4
Q API Spec Q1 9th Ed 4.4.2 Non-conformance Oil and Gas Industry Standards and Regulations 8
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
SANTHSH API spec Q1 9th edition - Castings & Forgings Oil and Gas Industry Standards and Regulations 4
N API spec Q1 9th edition Oil and Gas Industry Standards and Regulations 2
M API Spec. Q1, 8th Ed. Section 7.5.2 vs. Q1, 9th Ed. Section 5.7.1.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 25
A API Spec Q1 9th Edition # Re-audit - Disputing with API AARs Oil and Gas Industry Standards and Regulations 1
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
B Evaluation of suppliers API Spec Q1 5.6.1.2c Oil and Gas Industry Standards and Regulations 2
J API Spec 6D 25th edition release date? Oil and Gas Industry Standards and Regulations 23
T API SPEC Q1 Clause 5.6.1.2.C).2) First Article Oil and Gas Industry Standards and Regulations 16
lanley liao How to understand correctly the section of 5.11 MOC in API Spec Q1? Oil and Gas Industry Standards and Regulations 3
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 19
lanley liao The validity of API Spec Q1 certificate Oil and Gas Industry Standards and Regulations 2
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 9
SANTHSH API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
SANTHSH API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 12
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
R Interesting Discussion API Spec Q1 Addendum 2 Oil and Gas Industry Standards and Regulations 0
F API Spec Q1 Scope - Limiting the scope of certification Oil and Gas Industry Standards and Regulations 3
Moumen H API Spec Q2 Design and Development Requirements for Service Providers Oil and Gas Industry Standards and Regulations 11
A Integrating API Spec Q1 with ISO 9001:2015 Oil and Gas Industry Standards and Regulations 18
S API SPEC 7-1, 7-2 and 5 CT implementation Oil and Gas Industry Standards and Regulations 3
H API Spec Q1 7.5.2 & 7.5.2.1 - Audit Nonconformance Help Oil and Gas Industry Standards and Regulations 15
S Sample Quality Manual which complies with API Spec Q1 Ninth Edition Oil and Gas Industry Standards and Regulations 18
P New to API Spec 7-1 (Rotary Drill Stem Elements) Oil and Gas Industry Standards and Regulations 6
C TS 29001/API spec Q1- help needed Oil and Gas Industry Standards and Regulations 1
H API (American Petroleum Institute) Spec Q1 Manual - Looking for samples Oil and Gas Industry Standards and Regulations 4
Q API (American Petrolium Institute) Spec 6D - Specification for pipeline valves Oil and Gas Industry Standards and Regulations 2
B Validation of design for valve api 6d 25 edition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
D API Q1 clause (1.0) Scope Oil and Gas Industry Standards and Regulations 1
D API Q1 clause (5.6.3) Verification of Purchased Products or Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Hi , everyone i need a procedure for validation of design prototype api 6d (valve manufacturing) Oil and Gas Industry Standards and Regulations 0
I API Q1 5.7.1.5.a and API 6A10.4.2.12.2 AAR in API audit Oil and Gas Industry Standards and Regulations 0
M API Q1 9th edition NCR Oil and Gas Industry Standards and Regulations 9
A Metadata For Drugs, API's, Regulatory & Clinical Documents and Dossier Service Industry Specific Topics 2
J API Q2 clause 5.4.3 b) Oil and Gas Industry Standards and Regulations 3
P Product Quality Review API-GMP Manufacturing and Related Processes 0
A API Q1 9th Edition Surveillance Audit - Quality Policy Oil and Gas Industry Standards and Regulations 2
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
T API 4F & 7K license - Add Mexico location? Oil and Gas Industry Standards and Regulations 5
B Validating calibration certificate as per API Q1 General Measurement Device and Calibration Topics 9
