API spec Q1 9th edition
I need some clarity on initial evaluation of critical supplier as defined in API Spec Q1 clause 5.6.1.2.c3 which says "identifying how the supplied product, component, .... conforms to stated requirements when limited by proprietary, legal, and/or contractual arrangements".
Does this mean verification of supply received at purchaser works against a purchase order, not Trial order, placed on the supplier?
jmech
No. What you're describing would fall under 5.6.1.2.c2, which is a bit confusing because it refers to first article inspection, but can be used for inspection of any order (trial, prototype, or regular) - see the "first article" definition in 3.1.11.
5.6.1.2.c3 is intended for situations where 5.6.1.2.c1 and 5.6.1.2.c2 can't be met. For example, for a proprietary thread from a vendor where an on-site evaluation is not allowed by your contract (and you can't do a meaningful inspection because the thread is proprietary), you have to state how the thread "conforms to stated requirements". Essentially, provide some justification for why you should trust that it conforms.
Thanks a lot
S API spec Q1 9th edition - Castings & Forgings Oil and Gas Industry Standards and Regulations 4
M API Spec. Q1, 8th Ed. Section 7.5.2 vs. Q1, 9th Ed. Section 5.7.1.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 10
A API Spec Q1 9th Edition # Re-audit - Disputing with API AARs Oil and Gas Industry Standards and Regulations 1
F API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits. Oil and Gas Industry Standards and Regulations 22
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 17
lanley liao The validity of API Spec Q1 certificate Oil and Gas Industry Standards and Regulations 2
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
S API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
S API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 10
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
R Interesting Discussion API Spec Q1 Addendum 2 Oil and Gas Industry Standards and Regulations 0
F API Spec Q1 Scope - Limiting the scope of certification Oil and Gas Industry Standards and Regulations 3
Moumen H API Spec Q2 Design and Development Requirements for Service Providers Oil and Gas Industry Standards and Regulations 11
A Integrating API Spec Q1 with ISO 9001:2015 Oil and Gas Industry Standards and Regulations 18
S API SPEC 7-1, 7-2 and 5 CT implementation Oil and Gas Industry Standards and Regulations 3
H API Spec Q1 7.5.2 & 7.5.2.1 - Audit Nonconformance Help Oil and Gas Industry Standards and Regulations 15
S Sample Quality Manual which complies with API Spec Q1 Ninth Edition Oil and Gas Industry Standards and Regulations 17
P New to API Spec 7-1 (Rotary Drill Stem Elements) Oil and Gas Industry Standards and Regulations 6
C TS 29001/API spec Q1- help needed Oil and Gas Industry Standards and Regulations 1
H API (American Petroleum Institute) Spec Q1 Manual - Looking for samples Oil and Gas Industry Standards and Regulations 4
Q API (American Petrolium Institute) Spec 6D - Specification for pipeline valves Oil and Gas Industry Standards and Regulations 2
lanley liao How to understand correctly the requirements of API monogram products Oil and Gas Industry Standards and Regulations 0
lanley liao Are there guidelines for application of all API monogrammal product? Oil and Gas Industry Standards and Regulations 2
U API License Agreements Oil and Gas Industry Standards and Regulations 2
R American Petroleum Institute - Becoming an API Auditor Professional Certifications and Degrees 2
B There is an estimated date of release of API Q1 10th edition? Oil and Gas Industry Standards and Regulations 8
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
lanley liao How to understand this bulleted list from API 600 Oil and Gas Industry Standards and Regulations 0
R [ASK] API Q1 Ninth Edition, Section 5.4.5 Oil and Gas Industry Standards and Regulations 4
H Updating Quality Manual to API Q1 Service Industry Specific Topics 6
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
F Who can sit in/perform an API audit? Oil and Gas Industry Standards and Regulations 2
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
D API 6A Certification Question Oil and Gas Industry Standards and Regulations 4
C New to Site - Request Help with API Q2 Implementation Oil and Gas Industry Standards and Regulations 9
T API Q1 - Will I be able to maintain Q1 if I have products that fall under 6A Oil and Gas Industry Standards and Regulations 5
P API monogram mark requirements Oil and Gas Industry Standards and Regulations 1
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
K 820.200 Servicing Procedure - Our system (because there is an API involved) is classified as Class 3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
