API SPEC Q1 Clause 5.6.1.2.C).2) First Article
Hi All, Just open discussion here.
Our organization has been recently audited by API for Surveillance. The auditor took a note implementation of clause 5.6.1.2.C).2). In our organization, we implement incoming receiving inspection and review mill cert of raw material from supplier, then we consider that this activity meet requirement clause 5.6.1.2.C).2). we didn't send out test piece to check the chemical and mechanical composition as the supplier is certified API 5CT.
However, the auditor interpreted the clause 5.6.1.2.C).2) that first article shall be performed by sending out test piece to check the chemical and mechanical composition.
How do you think about the clause?
What kind of activity do you think to satisfy this requirement?
Dear taudi, is this case become nonconformance from auditor?
because the explanation from clause 5.6.1.2.C).2) refer to term and definition 3.1.11 first article (representative sample of a product, component, or output from a process used to verify that prescribed activities have satisfied the requirements as specified by the organization).
Thee Bouyyy
Multiple Personalities
Yes, I agreed with the auditor findings and interpretation of 5.6.1.2 C) 2.
First article definition itself in API Q1 Standard (3.1.11) says that, "Representative sample of product, component or output from a process used to verify that prescribed activities have satisfied the requirements as specified by the organization."
So, you have to send test piece to check chemical and mechanical composition.
Now, As you said that you implemented incoming receiving inspection and review mill cert of raw material from supplier. I just wanted to know that are you manufacturer or supplier or what?
lanley liao
I agree with Prayudha and Thee. but We think that the words of Taudi were also right. The key point of this question is that the item 1),2) and 3) in API Q1 5.6.1.2 C) were optional. At first, you should check the Procurement Control Procedure to how to address it. The evidence implemented should conform with requirements specified, if no, you should modify your corresponding document; if yes, you should show your evidence with the API reviewing committee for appealing this NC. Sometimes, we also can verify that the raw material meets the requirements specified by the customer through the MTR and incoming receiving inspection results of raw materials. The last evidence was depended on the company itself.
Thanks Lanley
Since supplier has been certified by API 5CT and audited by API. We previously considered that we didn't need to send test piece to check chemical and mechanical composition. So, we verified raw material through MTR.
SANTHSH API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 12
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
Q API Spec Q1 9th Ed 4.4.2 Non-conformance Oil and Gas Industry Standards and Regulations 8
J API Spec 6D 25th edition release date? Oil and Gas Industry Standards and Regulations 20
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
lanley liao How to understand correctly the section of 5.11 MOC in API Spec Q1? Oil and Gas Industry Standards and Regulations 3
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 19
lanley liao The validity of API Spec Q1 certificate Oil and Gas Industry Standards and Regulations 2
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
SANTHSH API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
SANTHSH API spec Q1 9th edition - Castings & Forgings Oil and Gas Industry Standards and Regulations 4
N API spec Q1 9th edition Oil and Gas Industry Standards and Regulations 2
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
M API Spec. Q1, 8th Ed. Section 7.5.2 vs. Q1, 9th Ed. Section 5.7.1.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 25
A API Spec Q1 9th Edition # Re-audit - Disputing with API AARs Oil and Gas Industry Standards and Regulations 1
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
R Interesting Discussion API Spec Q1 Addendum 2 Oil and Gas Industry Standards and Regulations 0
F API Spec Q1 Scope - Limiting the scope of certification Oil and Gas Industry Standards and Regulations 3
F API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits. Oil and Gas Industry Standards and Regulations 22
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
Moumen H API Spec Q2 Design and Development Requirements for Service Providers Oil and Gas Industry Standards and Regulations 11
A Integrating API Spec Q1 with ISO 9001:2015 Oil and Gas Industry Standards and Regulations 18
S API SPEC 7-1, 7-2 and 5 CT implementation Oil and Gas Industry Standards and Regulations 3
H API Spec Q1 7.5.2 & 7.5.2.1 - Audit Nonconformance Help Oil and Gas Industry Standards and Regulations 15
S Sample Quality Manual which complies with API Spec Q1 Ninth Edition Oil and Gas Industry Standards and Regulations 18
P New to API Spec 7-1 (Rotary Drill Stem Elements) Oil and Gas Industry Standards and Regulations 6
C TS 29001/API spec Q1- help needed Oil and Gas Industry Standards and Regulations 1
H API (American Petroleum Institute) Spec Q1 Manual - Looking for samples Oil and Gas Industry Standards and Regulations 4
Q API (American Petrolium Institute) Spec 6D - Specification for pipeline valves Oil and Gas Industry Standards and Regulations 2
N API Q1, Management of Change & Document Change Request Oil and Gas Industry Standards and Regulations 1
N API Q1 Audit Surveillance - Questions Oil and Gas Industry Standards and Regulations 2
J Help to understand and response to API AAR during the re-certification audit Oil and Gas Industry Standards and Regulations 17
J QTC Requirement as per API 6A-21st Edition Oil and Gas Industry Standards and Regulations 1
D What are the Activity deemed critical for the API 6D Ball Valve ? Oil and Gas Industry Standards and Regulations 4
B How to satisfy clause 5.7.1.5 process validation for valve production API 6D Oil and Gas Industry Standards and Regulations 13
J API Q1 4.3.2.2 Personnel Competence for Internal Auditors Oil and Gas Industry Standards and Regulations 4
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 4
D How to testing of Pressure relief valve as per API 6D ? Oil and Gas Industry Standards and Regulations 1
P API Q1 - Monogram Product & API 4F - Proof Load Test Oil and Gas Industry Standards and Regulations 3
L API Q1 Application Oil and Gas Industry Standards and Regulations 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
lanley liao Confusion between national standard and API related standard. Oil and Gas Industry Standards and Regulations 8
Thee Bouyyy API Q1 9th edition 5.4.3 c) and 5.4.3 d) Oil and Gas Industry Standards and Regulations 10
T Non API products need to comply to API Q1? Oil and Gas Industry Standards and Regulations 3
C API Q1 internal audit report Internal Auditing 3
