Taudi Afiat
Hi All, Just open discussion here.
Our organization has been recently audited by API for Surveillance. The auditor took a note implementation of clause 5.6.1.2.C).2). In our organization, we implement incoming receiving inspection and review mill cert of raw material from supplier, then we consider that this activity meet requirement clause 5.6.1.2.C).2). we didn't send out test piece to check the chemical and mechanical composition as the supplier is certified API 5CT.
However, the auditor interpreted the clause 5.6.1.2.C).2) that first article shall be performed by sending out test piece to check the chemical and mechanical composition.
How do you think about the clause?
What kind of activity do you think to satisfy this requirement?
