Application of AS9100 clause 7.5.1.1 - Tooling Supplier
V
valiantq1
In regards to AS9100 clause 7.5.1.1 states in part The organization shall use a representative item from the first production run of a new part or assembly to verify that the production processes, production documentation and tooling are capable of producing parts and assemblies that meet requirements.
The question I have is that we received a minor non-conformance as we do not do First Article Inspections. We build custom support tooling for the airspace industry and nothing is mass produced nor do we build anything that is a fly away part. The type of tool's we build are drill jigs, layup mandrels, Assembly jigs, work platforms etc. Is it necessary for us to do a first article inspection??
We currently do 100% inspection and also collect material certs for all jobs build and any special processes are only given to suppliers on our approved vendor list and we flow down all requirements.
I am just trying to see if I have a leg to stand on as I do not feel based on the type of tooling we do that this is needed and this is more geared to production runs. My major concern is loosing jobs due to the additional cost associated with this.
Any help would greatly be appreciated.
Sidney Vianna
Post Responsibly
Re: AS9100 clause 7.5.1.1
Your challenge arises from a misapplication of the standard, in my estimation. Chances are, your organization was requested to comply and attain certification to AS9100 by a misguided customer.
The original intent of AS9100 was to be used in the aerospace supply chain of flight hardware. The scope of AS9100 was broadened to allow Defense and Space organizations to tweak the standard so they could also deploy it in their respective supply base. But, in my opinion, it does not make any sense whatsoever to expect a tooling supplier to comply with AS9100. You would be much better served by following ISO 9001, instead.
If you consider the case of unique spacecrafts, such as satellites that are, many times, one offs, the concept of FAI would not make any sense whatsoever. That is one of the reasons the requirement was relocated from section 8 (in AS9100B) to section 7 (in AS9100C), so a potential exclusion claim can be made. Have a look at the appropriate paragraph in the IAQG AS9100C Changes and Rationale document. Contact your CB and see if they would be agreeable to consider 7.5.1.1 a justifiable exclusion in your case. In case they don't, you can attempt to have a dialogue with the AS9100C SDR person, identified here.
Good luck.
PS I mislinked the document. Check also http://www.sae.org/iaqg/projects/9100changes.pdf
Big Jim
You are caught in the middle of a somewhat controversial and often misunderstood requirement.
What is awkward is that many believe that 7.5.1.1 means that you have to adhere to the requirements of AS9102 which is specifically about first article inspection. Just for your own enlightenment, you should get a copy and read it so you understand what is required when you do have a customer that requires first article per AS9102. It would also be wise to see what is there so you understand the connotation that rides along with the term "First Article".
Please note that AS9100C does not require that you adhere to AS9102. Instead it provides its own definition of first article, a definition that falls way short of what is in AS9102.
For convenience sake, many companies use the forms provided with AS9102, but this is not a requirement of AS9100C. Sometimes it is a customer requirement though. Some auditors seem to believe that if they don't see those forms, or at least something very similar, that you are not practicing first article and are not adhering to the requirements of clause 7.5.1.1, while it is possible that you may be doing so.
Clause 7.5.1.1 does not require that you have a written procedure for the topic, nor does it have a requirement for maintaining records. It doesn't even require that you call this activity "first article". A very difficult thing for many auditors to get over is the mistaken belief from days long past that they need to see some sort of paperwork for every clause to prove that you are living to it. That is not true, and when you don't have any such documentation for clauses that don't need it, the auditor needs to determine your actual practice from observation and interview. Did this happen? Did the auditor simply see the lack of paperwork or did he attempt to determine your actual practice of meeting clause 7.5.1.1?
Can you demonstrate, from the records you do keep, including what is needed for clause 8.2.4 (monitoring and measurement of product), and from your actual practice, that you do perform something that meets the requirements of 7.5.1.1?
If you haven't truly thought it through so your intent to meet 7.5.1.1 is either weak or nonexistent, this could be a legitimate nonconformance. If you have thought it through, and you do meet the requirement use a representative sample of the first production run (a sample of one of a production run is 100% inspection is it not?) to verify that the process, documentation, and tooling are capable of making the part to specification, then you have met the requirement of 7.5.1.1.
Pay attention to the note at the end of 7.5.1.1: This ACTIVITY is often referred to as first article inspection" (emphasis added). ACTIVITY, not SET OF DOCUMENTATION. May I repeat that this activity doesn't need to be called "first inspection".
So if you believe you met the requirement then protest the finding. If you believe that you may not have thought it through well enough to claim that you have met the requirement, accept it, resolve it, and move on with life.
Big Jim
Good luck.
Sidney's excellent response came while I was posting so read my first response with that in mind.
I do believe that excluding 7.5.1.1 could be a good answer and is worth pursuing.
As to which standard to be registered to, I wish it were as simple as Sidney has indicated. I call on shops in similar situations to those of the OP. One of them chose to seek AS9100 registration because their customers preferred it (and were awarded contracts based on it). It is a little hard to argue that they should have settled for ISO 9001 when their bottom line clearly shows that AS9100 was beneficial to their fiscal health. Still another one is ISO 9001 certified and is so deeply embedded in the supply chain that it would be hard to image that AS9100 would provide any monetary advantage. Every circumstance is different and has to be evaluated by the organization themselves. There are many companies that I call on that are AS9100 because of customer demand that really would probably be better suited to ISO 9001, but would not be able to exist if they were.
chinadaddy02
Actually my company is the same line of work as valiantq1, we also provide tooling for aerospace. We received our AS9100 cert last year (thanks to Elsmar Cove posts).
That was a big question for us - how can we answer 7.5.1.1 when we do not create parts, just tooling?
What we ended up doing is creating a finalized checklist in which we list all the other checklists and inspections necessary to finish a project. Appropriate signatures of personnel responsible for the other checklists are on the finalized checklist when completed. The finalized checklist and the records for the project are then bound together. In this way we can say that the work has been done and shown to be within specifications.
Hope this helps.
F Selective Application of AS9100 by Requirement AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
J Application of AS9100 Rev.C AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
C New Class III medical device application for Health Canada Canada Medical Device Regulations 6
T Commission proposal being drawn up for postponement for date of application of MDR (2017/745) EU Medical Device Regulations 7
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
J Are DAM tools, Mobile application, clinical dashboard, etc. considered accessories to medical device or supportive functions? Manufacturing and Related Processes 4
J Application of mains voltage on SIP/SOP connectors of medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
L External power supplies: How close does the safety report have to match the end-use application? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Informational TGA presentation: How to submit an effective good manufacturing practice clearance application Medical Device and FDA Regulations and Standards News 0
Z Role of economic operators (EO) post the EU MDR Date of application in May 2020 EU Medical Device Regulations 1
P Scope of application for IEC 60601-1-11 Medical electrical equipment — Part 1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Informational EU – Application of transitional provisions concerning validity of certificates issued in accordance to Directives 90/385/EEC and 93/42/EEC Medical Device and FDA Regulations and Standards News 2
D FDA Biomarker Qualification Program - Has anyone prepared an application? Medical Device and FDA Regulations and Standards News 0
A Validating my own application developed with Agile Qualification and Validation (including 21 CFR Part 11) 5
M Informational EU – Guidance document Implant Card relating to the application of Article 18 Regulation (EU) 2017/745 of the European Parliament and of the Council o Medical Device and FDA Regulations and Standards News 2
Sidney Vianna Informational ISO 18091 - Guidelines for the application of ISO 9001 in local government Other ISO and International Standards and European Regulations 1
S Internal Audit Checklist for Application/Software development IEC 27001 - Information Security Management Systems (ISMS) 1
M Informational MDCG 2019-2 Guidance on application of UDI rules to device-part of products referred to in Article 1(8), 1(9) and 1(10) of Regulation 745/2017 Medical Device and FDA Regulations and Standards News 0
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
M Medical Device News NB-Med and Team-NB have jointly edited a white paper entitled “White Paper – One Year of Application” Medical Device and FDA Regulations and Standards News 0
S IATF 16949 9.1.1.3 Application of statistical concepts - Our technicians are quizzed for statistical knowledge IATF 16949 - Automotive Quality Systems Standard 3
supadrai Informational Japan Minor Change Notification Application Form - Found it? Japan Medical Device Regulations 0
M Some possible misunderstandings on the application of ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
K Need feedback: FMEA Web Application FMEA and Control Plans 5
I FAR Part 43 and Application to 17025 Accredited Cal Lab Federal Aviation Administration (FAA) Standards and Requirements 2
B Request for Information; Application for Accreditation Japan Medical Device Regulations 0
Y Application of IEC/EN 62304 at an advanced stage of software development IEC 62304 - Medical Device Software Life Cycle Processes 4
M What is considered an "Audit Day" for OASIS AEA application? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
Ajit Basrur CDRH Premarket Approval Application Critical to Quality Pilot Program US Food and Drug Administration (FDA) 0
Sidney Vianna Blockchain Technology - Any examples of practical application? The Reading Room 21
V Delete Restrictions to be enabled AT BOTH Operating System & Application Levels Qualification and Validation (including 21 CFR Part 11) 1
R Is it legal to attend a trade show while you have a 510(k) application pending? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D Zinc Oxide as a Topical Application EU Medical Device Regulations 4
C Application of ISO 9001:2015 Clause Interpretations for Service Industries Service Industry Specific Topics 2
A IRCA Application Form Fill - Guidance ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 22
V Application and differences of OC Curve and Acceptance Sampling Statistical Analysis Tools, Techniques and SPC 2
P Employment Application Form - Controlled or Not? Document Control Systems, Procedures, Forms and Templates 3
JoCam Format of Health Canada pre-market licence application Canada Medical Device Regulations 3
Sidney Vianna Informational ISO/TS 9002 - Guidelines for the application of ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J The application of Design Controls to IVDs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C Flow meter for medical device application Other Medical Device Related Standards 2
Colin Application of ISO 13485 to a Medical Device distributor ISO 13485:2016 - Medical Device Quality Management Systems 5
B Inquiry for Class II medical device licence amendment application Canada Medical Device Regulations 1
C Mobile Application which collects Physiological Data from a Medical Device Other Medical Device and Orthopedic Related Topics 1
M IMDRF document - Application of QMS to SaMD ISO 13485:2016 - Medical Device Quality Management Systems 2
Q The ability of computer software to satisfy the intended application ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Application / Use of Hypothesis Testing in any Six Sigma Black Belt Project Six Sigma 8
B Processing Time for a new Health Canada Class II Medical Device Licence Application Canada Medical Device Regulations 3
