Application / Use of Hypothesis Testing in any Six Sigma Black Belt Project
AMIT BALLAL
Hi all !!
Can anyone share the use of hypothesis testing in any six sigma black belt project with some simple examples?
I am little confused about how I can use hypothesis testing in a project, this will help me to get some clarity. :confused:
Any help will be appreciated.
Thanks,
Amit
There are an almost unlimited number of ways to use hypothesis testing. A simple example is making a modification to a fixture (or a new design for a fixture). Then comparing the variation of the modified/new fixture to that of the old fixture using a test for equal variances. If significant, the test would validate that the improvement is real.
Curtis317
If you have MiniTab you can get into the help files and learn how to use it. It is also a great to review the materials if you have done any of the statistical tools in a while.
julsbear
You can use hypothesis testing to confirm that your change has indeed resulted in an improvement over the existing system. You can test if the mean has improved or if the variance has improved. If you can show improvement in both, you may have hit the jackpot.:2cents:
it may be more helpful for you if you could explain what your project is or what type of project you will be assigned.
AMIT BALLAL
Thanks to all for help!!!
I have taken the Project of Improving Training Effectiveness, problem considered is trainings given are not effective / trainings given are not effectively utilized.
Can you suggest how to use hypothesis for this project / training process ?
Thanks,
Amit
You could run Before/After tests for comprehension and/or observe for desired behavior changes. These could be tested for significance using the paired t-test.
Miner has a good example. I have used the paired t test frequently when assessing whether or not a particular training approach worked - at least long enough to take the test.
what makes the paired t test appropriate is that each individual will come to the training at different levels of knowledge and/or skill. so their 'improvement' difference will be different (think about a group of people who decide to lose weight).
The longer term effectiveness of any training in changing behaviors and ultimately results is probably better assessed with a control chart than a hypothesis test.
As with any improvement project, the statistical test of significance that you use are of far less importance than how you determine the cause(s) of poor performance, how you incorporate good science into determining the solutions and how you structure the experiments to determine if the solutions will work...
AMIT BALLAL
Thank you all for quick response & help provided.
I'll utilize the help provided & will share my experience with you.
Thanks,
Amit :thanx:
P Application of 60601-1 and 60601-2-2 to a hand-held laparoscopic unstrument with motorisation in the handle IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D CFG application issues Other US Medical Device Regulations 0
T Monolithic medical application ISO 13485:2016 - Medical Device Quality Management Systems 1
D GR&R for Torque application Manufacturing and Related Processes 6
J Has the facility been inspected? question in Certificate to Foreign Government application Other US Medical Device Regulations 0
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Can you import medical device not FDA approved into the USA under an IND application? US Food and Drug Administration (FDA) 2
E Do I need test reports for all standards mentioned in my 510k application? Other Medical Device Related Standards 8
S Taiwan QSD application Other Medical Device Regulations World-Wide 1
shimonv Where do you place Human Factors report in a 510(k) application? Other US Medical Device Regulations 3
Jessesun The application of ozone sterilization in medical treatment US Food and Drug Administration (FDA) 0
L API Q1 Application Oil and Gas Industry Standards and Regulations 2
I Software (SaMD) mobile application verification testing: objective evidence Medical Information Technology, Medical Software and Health Informatics 6
D Dental application - medical product or not? Other US Medical Device Regulations 8
T Including a class 1 camera in the 510k application of class 2 therapeutic technology? US Food and Drug Administration (FDA) 18
shimonv Can you submit a traditional application for a class I device? Other US Medical Device Regulations 7
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
T Google Fit Health datas and Medical devices Application Medical Information Technology, Medical Software and Health Informatics 2
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
lanley liao Are there guidelines for application of all API monogrammal product? Oil and Gas Industry Standards and Regulations 2
G Application to Chartered Quality Institute - MCQI ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
M Surgical angle measurement guide device with an application software Medical Device and FDA Regulations and Standards News 4
Sidney Vianna IATF 16949 News Update on the IATF CARA Project (“Common Audit Report Application”) - 12/2020 IATF 16949 - Automotive Quality Systems Standard 1
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
U GMDN CODES application ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Monolithic application and medical devices ISO 13485:2016 - Medical Device Quality Management Systems 2
R CAMBODIA - Application of AMDD Other Medical Device Regulations World-Wide 3
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 4
C New Class III medical device application for Health Canada Canada Medical Device Regulations 6
T Commission proposal being drawn up for postponement for date of application of MDR (2017/745) EU Medical Device Regulations 7
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
J Are DAM tools, Mobile application, clinical dashboard, etc. considered accessories to medical device or supportive functions? Manufacturing and Related Processes 4
J Application of mains voltage on SIP/SOP connectors of medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
L External power supplies: How close does the safety report have to match the end-use application? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P SOUP anomaly evaluation for MMA (Mobile Medical Application) IEC 62304 clause 7.1.3 IEC 62304 - Medical Device Software Life Cycle Processes 6
M Informational TGA presentation: How to submit an effective good manufacturing practice clearance application Medical Device and FDA Regulations and Standards News 0
Cats Clause ISO 9001:2015 Monitoring and measuring resources. Application a service industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Z Role of economic operators (EO) post the EU MDR Date of application in May 2020 EU Medical Device Regulations 1
P Scope of application for IEC 60601-1-11 Medical electrical equipment — Part 1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Informational EU – Application of transitional provisions concerning validity of certificates issued in accordance to Directives 90/385/EEC and 93/42/EEC Medical Device and FDA Regulations and Standards News 2
Dobby1979 FDA Biomarker Qualification Program - Has anyone prepared an application? Medical Device and FDA Regulations and Standards News 0
A Validating my own application developed with Agile Qualification and Validation (including 21 CFR Part 11) 5
M Informational EU – Guidance document Implant Card relating to the application of Article 18 Regulation (EU) 2017/745 of the European Parliament and of the Council o Medical Device and FDA Regulations and Standards News 2
Sidney Vianna Informational ISO 18091 - Guidelines for the application of ISO 9001 in local government Other ISO and International Standards and European Regulations 1
S Internal Audit Checklist for Application/Software development IEC 27001 - Information Security Management Systems (ISMS) 1
M Informational MDCG 2019-2 Guidance on application of UDI rules to device-part of products referred to in Article 1(8), 1(9) and 1(10) of Regulation 745/2017 Medical Device and FDA Regulations and Standards News 0
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
M Medical Device News NB-Med and Team-NB have jointly edited a white paper entitled “White Paper – One Year of Application” Medical Device and FDA Regulations and Standards News 0
S IATF 16949 9.1.1.3 Application of statistical concepts - Our technicians are quizzed for statistical knowledge IATF 16949 - Automotive Quality Systems Standard 3
