Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection
shadowjade
Hi, all.
I work in a batch-driven shop with lot sizes between 8 and 10K pieces. Our final inspection/packaging involves 100% visual for assorted defects. I am looking to build in automation so when scrap for a given defect reaches a specific level (bogie), the inspector and myself are notified that additional measures are necessary.
I have the 2003 version of Z1.4 but, of course, many of the plans are dependent on sample size. When our sampling is 100%, these do not apply. Is there another table within the standard that I could refer to in determining the amount of defects that would trigger the alarm noted above?
Thanks!
Marc
Fully vaccinated are you?
Re: Applying ISO Z1.4 given known lot size and 100% visual inspection
Can any of you help with this? My appreciation in advance!
shadowjade
Further research into the application of an Acceptable Quality Level (AQL) has been a challenge as this value is based on sampling for attribute characteristics. AQL was originally defined by MIL-STD-105E. Given that we're already 100% visually inspecting these parts, AQL does not have much value. I have found little else insofar as a specification or standard to aid in making this determination as all are dependent upon either variable characteristics or sampling methodology. On that note, please see later in my description which follows that I reference AQL for guidance purposes in this issue.
I have looked to apply a percent non-conforming for any given defect which would require 200% inspection. Of the orders we had third-party inspected (at our cost) for a given attribute defect, we had previously picked out 1.20% of the combined total pieces at our final inspection operation. As 13 known parts exceeding specification were found by third-party sorting, 1.20% is too high a value to set as the threshold for 200% inspection/re-inspection.
In discussing this with a senior inspector and assuming an order quantity of > 10,001 pieces, 50 pieces scrap for the defect in question (as a threshold value) should necessitate 200% inspection or 0.5% (or an AQL of 0.5) in her opinion. This puts us between two Special Inspection levels, S-3 and S-4 per MIL-STD-105E. When accounting for > 10,001 piece order quantities, S-3 has an AQL of 0.65 and S-4 an AQL of 0.25. S-3 assumes a sample size of 20 and S-4 assumes a sample size of 50. Again, we are 100% visually inspecting these parts so the AQL does not really apply.
My proposal, therefore, is to require 200% of orders wherein defects/part scrapped under scrap codes for the defect in this matter (or others) go above 0.65% of the incoming quantity. This conforms with the 0.65 AQL inspection level S-3 and is closest to the inspector's opinion cited above. 0.65% is nearly half of the 1.20% as discussed above, as well. Pieces constituting the quantity required for re-inspection shall be out of the known specification we have referenced in this matter.
Unless someone else has something, this is what I'm proposing in order to move forward with this issue.
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
J US Manufacturer of Export Only Exempt Products applying for CFG 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
L What is the very first step to prepare for applying EASA POA? EASA and JAA Aviation Standards and Requirements 1
J Applying for 510K - What is a significant process change and what is not US Food and Drug Administration (FDA) 5
M Importing a Registered Class II Device, the Applying Our Label - Need New 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
somashekar Applying legal requirements in hazardous waste management. Miscellaneous Environmental Standards and EMS Related Discussions 1
P Applying Combined Tolerances of Two Scales - Balance Tolerance Question General Measurement Device and Calibration Topics 9
C Retroactively applying procedures in ISO 9001:2008 Quality Manager and Management Related Issues 6
A Applying VDA 6.2/6.3 in a Logistics Company VDA Standards - Germany's Automotive Standards 3
P Applying design and development with unknown outcomes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Interpreting and Applying 7.3.2 Design and Development Inputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Applying Correction Factors to Furnaces Manufacturing and Related Processes 5
W Applying ISO 9001 Clause 7.3 in Special Case - Oil Refinery ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P HR knows I'm looking and that I've been applying for jobs Career and Occupation Discussions 23
L Applying the Lean Concept in Quality Management Systems Lean in Manufacturing and Service Industries 7
optomist1 Profile of a Surface - Applying Profile of a Surface Geometric Control Symbols Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Applying Statistical Analysis Methods to Work Safety Occupational Health & Safety Management Standards 3
Y Applying Human Factors and Usability Engineering - FDA Guidance Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Q Applying Risk to the Medical Device Document Control Program Document Control Systems, Procedures, Forms and Templates 3
M Applying EN 62304 - Medical Device Software Architecture - Level of Detail IEC 62304 - Medical Device Software Life Cycle Processes 21
S Applying HAZOP and FMEA methods for HSE Hazard Identification in Construction Occupational Health & Safety Management Standards 3
M Consultant required for applying an ISO14001-2004 certification. ISO 14001:2015 Specific Discussions 14
H Problems with RABQSA - Applying for my Provisional Auditor (PA) status ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
J Applying Previous Failures to new PFMEA APQP and PPAP 2
W Applying for 510(k) Submission for Blood Glucose Monitor System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T Applying for FDA 510(k) for 21 CFR 892.2050 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
E Financial certification or disclosure statement for applying 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
E A question about small business qualification applying 510(k) for new product US Food and Drug Administration (FDA) 6
L API (American Petroleum Institute) Monogram - Applying and Removal Process Oil and Gas Industry Standards and Regulations 5
ScottK How to choose professional references when applying for a job? Career and Occupation Discussions 1
N Applying FMEA to all Pre-Production Processes FMEA and Control Plans 5
T Applying Lean Tools in Product Development Lean in Manufacturing and Service Industries 2
Y Accurately applying a specific clause to a Non Conformance Internal Auditing 10
A APQP and Food Products - Applying APQP to the production of a new kind of milk APQP and PPAP 3
M Applying AQL when 0 defects are acceptable AQL - Acceptable Quality Level 9
G Whats the difference in applying error factor and correction factor? General Measurement Device and Calibration Topics 1
T Applying Scanned Signatures to Documents for Signing Document Control Systems, Procedures, Forms and Templates 11
Q Applying SPC in a Computer Assembly Shop Statistical Analysis Tools, Techniques and SPC 7
C Too Deep? Applying APQP to a Major Component and to Suppliers IATF 16949 - Automotive Quality Systems Standard 4
B Applying the principles an practices of C/A - P/A? Corrective Action and children? Nonconformance and Corrective Action 7
Q Applying for internal job but you know 100% that you are not going to get the job Career and Occupation Discussions 10
S Applying principles of lean to a calibration lab? Lean in Manufacturing and Service Industries 8
T Comparison of EU and US GMPs - Differences applying CFR211 or the EU GMPs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
I Lean in the Tool and Die Industry (Job Shop) - Applying Lean in "one-off" production Lean in Manufacturing and Service Industries 6
U Applying Lessons Learned to other products Misc. Quality Assurance and Business Systems Related Topics 2
Tim Folkerts Applying FMEA to National-Level Issues FMEA and Control Plans 10
W Applying MTBF and MTTR to Maintenance Misc. Quality Assurance and Business Systems Related Topics 2
S Applying PPAP to Suppliers - TS 16949 Clause 7.3.6.3 Supplier Quality Assurance and other Supplier Issues 10
Q And now, let's add software development - Medical Devices - Applying ISO9001:2000 ISO 13485:2016 - Medical Device Quality Management Systems 12
