Applying AQL when 0 defects are acceptable
MEDQA
Hello - I'm looking to justify / validate a chosen inspection qty due to a Corrective Action. I'm not sure AQL is the appropriate method as we can't accept any qty of defects. Will try to explain the situation below, keep in mind I'm new to this wonderful stuff.
A sales rep received 4 defective parts, so we 100% inspected current inventory, 17 of 135 parts (13%) were found to be defective.
Testing and sorting methods were developed along w/ Root Cause and Corrective Action. Along with new sorting / inspection measures, parts were 100% inspected before sterilization, we want to do a final inspection on a sampleling of parts when they return, if all goes well alleviate the need to 100% inpect again.
My initial thought was that if we inspect 13% of the 466 pcs and get 0 defects we are okay. If any defects are found we should 100% the balance?
Note - as per AQL, defect seems to be Critical / Major with no harm to person, the part will simply not function.
Any direction would be greatly appreciated.
Caster
An Early Cover
Welcome
Did you see the list of associated threads below?
Check into a C=0 sampling plan discussion thread for some ideas.
No sampling plan will guarantee zero defects, for true zero defects you will need strong poka yoke (search the Cove.
In fact 100%, 200% or 500% inspection will not guarantee zero defects....
And just for completeness SPC will not guarantee zero defects, not even the 6 Sigma folk would go that far
If you really need zero, bring on the poka yokes....
Was this any help?
MEDQA
Hello - I'm also not sure how to decide on the Acceptance Quality Limit, I read that most medical devices would use .040, .065 or 1.0 related to a major defect. I reviewed a 0 acceptance Number Sample Plan which shows that we would need to pull 315 pcs @.040 or 100%.
The subject will be up for discussion at a meeting, & will most likely be decided by upper management. I just wanted to offer any input possible for what qty would be appropriate as per ISO 13485 etc.
Reason for not wanted to 100% after sterilization is that the inspection process at this point subjects the parts to acquiring another problem.
Al Rosen
If your parts were good before sterilization, what in the process caused the defects? Fix the process, don't inspect after sterilization.
MEDQA
The Non conformance shares the root cause of a process problem which we believe to be fixed and supplier recall which has been sorted. Checking parts after sterilization will be part of our validation.
The parts found to be defective in the initial sort and received by the sales rep, were also 100% inspected before sterilization....
Q
qualitytrec
Welcome to the cove. To try to answer your question I would need more info. What is your lot/batch size. Sampling plans are based on lot size or total number of pieces. I am with the others who suggested putting error prevention in place. Poka-yoke is important for zero defects because the issue needs to be taken care of in the process.
Quality 101 is if you make defectives you will ship defectives.
Mark
MEDQA
Lot size is 466 pcs.
Just to clarify, there were 2 potential root causes, supplier recall or a process issue. Defects could be the result of 1 or both.
Al Rosen
What do you mean by one of the potential root causes being a supplier recall?
MEDQA
Hello -
The supplier issued a recall months ago for non conforming material which was not communicated internally by the responsible party (who is no longer with us). We learned of the recall when we started the internal investigation to determine the root cause of the non functioning part the sales rep received. In the investigation we found a step in the process that had the potential to cause a similar defect as the supplier's non conforming material.
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
J US Manufacturer of Export Only Exempt Products applying for CFG 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
L What is the very first step to prepare for applying EASA POA? EASA and JAA Aviation Standards and Requirements 1
J Applying for 510K - What is a significant process change and what is not US Food and Drug Administration (FDA) 5
M Importing a Registered Class II Device, the Applying Our Label - Need New 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
somashekar Applying legal requirements in hazardous waste management. Miscellaneous Environmental Standards and EMS Related Discussions 1
P Applying Combined Tolerances of Two Scales - Balance Tolerance Question General Measurement Device and Calibration Topics 9
C Retroactively applying procedures in ISO 9001:2008 Quality Manager and Management Related Issues 6
A Applying VDA 6.2/6.3 in a Logistics Company VDA Standards - Germany's Automotive Standards 3
P Applying design and development with unknown outcomes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Interpreting and Applying 7.3.2 Design and Development Inputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Applying Correction Factors to Furnaces Manufacturing and Related Processes 5
W Applying ISO 9001 Clause 7.3 in Special Case - Oil Refinery ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P HR knows I'm looking and that I've been applying for jobs Career and Occupation Discussions 23
L Applying the Lean Concept in Quality Management Systems Lean in Manufacturing and Service Industries 7
optomist1 Profile of a Surface - Applying Profile of a Surface Geometric Control Symbols Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Applying Statistical Analysis Methods to Work Safety Occupational Health & Safety Management Standards 3
Y Applying Human Factors and Usability Engineering - FDA Guidance Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Q Applying Risk to the Medical Device Document Control Program Document Control Systems, Procedures, Forms and Templates 3
M Applying EN 62304 - Medical Device Software Architecture - Level of Detail IEC 62304 - Medical Device Software Life Cycle Processes 21
S Applying HAZOP and FMEA methods for HSE Hazard Identification in Construction Occupational Health & Safety Management Standards 3
M Consultant required for applying an ISO14001-2004 certification. ISO 14001:2015 Specific Discussions 14
H Problems with RABQSA - Applying for my Provisional Auditor (PA) status ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
J Applying Previous Failures to new PFMEA APQP and PPAP 2
W Applying for 510(k) Submission for Blood Glucose Monitor System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T Applying for FDA 510(k) for 21 CFR 892.2050 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
E Financial certification or disclosure statement for applying 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
E A question about small business qualification applying 510(k) for new product US Food and Drug Administration (FDA) 6
L API (American Petroleum Institute) Monogram - Applying and Removal Process Oil and Gas Industry Standards and Regulations 5
ScottK How to choose professional references when applying for a job? Career and Occupation Discussions 1
N Applying FMEA to all Pre-Production Processes FMEA and Control Plans 5
T Applying Lean Tools in Product Development Lean in Manufacturing and Service Industries 2
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
Y Accurately applying a specific clause to a Non Conformance Internal Auditing 10
A APQP and Food Products - Applying APQP to the production of a new kind of milk APQP and PPAP 3
G Whats the difference in applying error factor and correction factor? General Measurement Device and Calibration Topics 1
T Applying Scanned Signatures to Documents for Signing Document Control Systems, Procedures, Forms and Templates 11
Q Applying SPC in a Computer Assembly Shop Statistical Analysis Tools, Techniques and SPC 7
C Too Deep? Applying APQP to a Major Component and to Suppliers IATF 16949 - Automotive Quality Systems Standard 4
B Applying the principles an practices of C/A - P/A? Corrective Action and children? Nonconformance and Corrective Action 7
Q Applying for internal job but you know 100% that you are not going to get the job Career and Occupation Discussions 10
S Applying principles of lean to a calibration lab? Lean in Manufacturing and Service Industries 8
T Comparison of EU and US GMPs - Differences applying CFR211 or the EU GMPs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
I Lean in the Tool and Die Industry (Job Shop) - Applying Lean in "one-off" production Lean in Manufacturing and Service Industries 6
U Applying Lessons Learned to other products Misc. Quality Assurance and Business Systems Related Topics 2
Tim Folkerts Applying FMEA to National-Level Issues FMEA and Control Plans 10
W Applying MTBF and MTTR to Maintenance Misc. Quality Assurance and Business Systems Related Topics 2
S Applying PPAP to Suppliers - TS 16949 Clause 7.3.6.3 Supplier Quality Assurance and other Supplier Issues 10
Q And now, let's add software development - Medical Devices - Applying ISO9001:2000 ISO 13485:2016 - Medical Device Quality Management Systems 12
