Applying Correction Factors to Furnaces
N
Nmark78
Hello Everyone:
I am slightly new to the quality world and would like to ask for some help in interpreting the application of correction factors. For basic example, if my TC cert stated the following
Test temp---- Actual temp----- correction factor
1000 F ---------1005 F...................( -5 F)
If I wanted to run a furnace a true temperature of 1000°F I would need to set my furnace for 995°F correct? (assuming the TC in question is the only sensor with a correction factor) My theory behind this is that although my TC says its running at 1000°F it is actually running the furnace at 1005°F so I would need to add my correction factor (-5°F) to my set point (now 995°F)to obtain a true temperature of 1000°F. Am I on the right path?
I am having difficulties finding any examples to support this or any other methods for applying correction factors. Is anyone aware of any resources for this topic with examples?
Thanks for any help or advice you can provide.
ssz102
why test temp and actually temp are different?
did you analysis the root cause? is environment or machine or other factor?
illation may not be correct i think
Sorin
Hello Everyone:
In order to avoid mistakes, you need to correct not your set point but the instrument showing the temperature from your thermocouple.
In your case the thermocouple have a correction factor of -5 F. So you need to set your instrument at -5 for that range of temperature.
Also, you need to document the change (log).
Another possibility would be for your operator to set the correction factor avery single time they are performing an HT at that range of temperature.
Either way, you need to log and document.
P.S. My reply is from a AMS2750 / Nadcap point of view.
AC7102 rev F
10.8.6 Offsetting
Note: Offsetting may be applied either by internal electronic adjustment or by manual offset of the set point as long as the method is clearly documented and followed, and complies with the specific customer requirements.
10.8.6.1 Is there a procedure that specifies the use of offsets?
10.8.6.2 Is the procedure in accordance with AMS 2750, or more stringent customer requirements?
10.8.6.3 Do records indicate that the procedure is followed?
10.8.6.4 Are manual offset tables clearly posted and visible to the operator?
10.8.6.5 Are electronic offsets documented and available to calibration technicians?
10.8.6.6 Does documentation exist to verify that the offsets were applied?
andygr
Hello Everyone:
As indicated by Sorin AMS 2750 is the "bible" for Nadcap pyrometry. here is a link to good training class on pyrometry http://www.equalearn.com/learncente...48B-8392-3E93785CE9E8&DCT=1&id=178409&page=15
By using the 995 deg F set point you are using a manual correction factor to ensure that you acceive the required 1000 deg F temperature in reality based on the System Accuracy Test (SAT) data you provided.
G Whats the difference in applying error factor and correction factor? General Measurement Device and Calibration Topics 1
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
J US Manufacturer of Export Only Exempt Products applying for CFG 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
L What is the very first step to prepare for applying EASA POA? EASA and JAA Aviation Standards and Requirements 1
J Applying for 510K - What is a significant process change and what is not US Food and Drug Administration (FDA) 5
M Importing a Registered Class II Device, the Applying Our Label - Need New 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
somashekar Applying legal requirements in hazardous waste management. Miscellaneous Environmental Standards and EMS Related Discussions 1
P Applying Combined Tolerances of Two Scales - Balance Tolerance Question General Measurement Device and Calibration Topics 9
C Retroactively applying procedures in ISO 9001:2008 Quality Manager and Management Related Issues 6
A Applying VDA 6.2/6.3 in a Logistics Company VDA Standards - Germany's Automotive Standards 3
P Applying design and development with unknown outcomes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Interpreting and Applying 7.3.2 Design and Development Inputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Applying ISO 9001 Clause 7.3 in Special Case - Oil Refinery ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P HR knows I'm looking and that I've been applying for jobs Career and Occupation Discussions 23
L Applying the Lean Concept in Quality Management Systems Lean in Manufacturing and Service Industries 7
optomist1 Profile of a Surface - Applying Profile of a Surface Geometric Control Symbols Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Applying Statistical Analysis Methods to Work Safety Occupational Health & Safety Management Standards 3
Y Applying Human Factors and Usability Engineering - FDA Guidance Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Q Applying Risk to the Medical Device Document Control Program Document Control Systems, Procedures, Forms and Templates 3
M Applying EN 62304 - Medical Device Software Architecture - Level of Detail IEC 62304 - Medical Device Software Life Cycle Processes 21
S Applying HAZOP and FMEA methods for HSE Hazard Identification in Construction Occupational Health & Safety Management Standards 3
M Consultant required for applying an ISO14001-2004 certification. ISO 14001:2015 Specific Discussions 14
H Problems with RABQSA - Applying for my Provisional Auditor (PA) status ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
J Applying Previous Failures to new PFMEA APQP and PPAP 2
W Applying for 510(k) Submission for Blood Glucose Monitor System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T Applying for FDA 510(k) for 21 CFR 892.2050 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
E Financial certification or disclosure statement for applying 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
E A question about small business qualification applying 510(k) for new product US Food and Drug Administration (FDA) 6
L API (American Petroleum Institute) Monogram - Applying and Removal Process Oil and Gas Industry Standards and Regulations 5
ScottK How to choose professional references when applying for a job? Career and Occupation Discussions 1
N Applying FMEA to all Pre-Production Processes FMEA and Control Plans 5
T Applying Lean Tools in Product Development Lean in Manufacturing and Service Industries 2
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
Y Accurately applying a specific clause to a Non Conformance Internal Auditing 10
A APQP and Food Products - Applying APQP to the production of a new kind of milk APQP and PPAP 3
M Applying AQL when 0 defects are acceptable AQL - Acceptable Quality Level 9
T Applying Scanned Signatures to Documents for Signing Document Control Systems, Procedures, Forms and Templates 11
Q Applying SPC in a Computer Assembly Shop Statistical Analysis Tools, Techniques and SPC 7
C Too Deep? Applying APQP to a Major Component and to Suppliers IATF 16949 - Automotive Quality Systems Standard 4
B Applying the principles an practices of C/A - P/A? Corrective Action and children? Nonconformance and Corrective Action 7
Q Applying for internal job but you know 100% that you are not going to get the job Career and Occupation Discussions 10
S Applying principles of lean to a calibration lab? Lean in Manufacturing and Service Industries 8
T Comparison of EU and US GMPs - Differences applying CFR211 or the EU GMPs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
I Lean in the Tool and Die Industry (Job Shop) - Applying Lean in "one-off" production Lean in Manufacturing and Service Industries 6
U Applying Lessons Learned to other products Misc. Quality Assurance and Business Systems Related Topics 2
Tim Folkerts Applying FMEA to National-Level Issues FMEA and Control Plans 10
W Applying MTBF and MTTR to Maintenance Misc. Quality Assurance and Business Systems Related Topics 2
S Applying PPAP to Suppliers - TS 16949 Clause 7.3.6.3 Supplier Quality Assurance and other Supplier Issues 10
Q And now, let's add software development - Medical Devices - Applying ISO9001:2000 ISO 13485:2016 - Medical Device Quality Management Systems 12
