Applying Risk to the Medical Device Document Control Program
Q
QAINOVA
Hi, I'm working on revising our current Document Control Program. Specifically regarding the method in which document changes are reivewed and approved. Our hope is to streamline the proces to allow documents to pass through the system quicker yet ensure control over the changes is maintained. Given the FDA is looking at risk as it applies to various processes/procedure, I want to implement risk assessment to the change which will then determine who needs to approve the change. Currently we have QS, Operations/Mfg and Reserach review all PCRs. Others (e.g. planning/purchasing, maketing, etc.) also reivew but it depends on the changes being proposed. What type of examples would you apply to a change that would classify it as a 'low', 'medium' or 'high' risk change? We manufacturer IVD Class II medical devices.
To me:
Low = typo change, doesn't affect validation/process, change made for clarification purposes only.
Med = customer notification required, design change, change may have affect on validation/process. Depends on if the change affects a critial element.
High = new design, new procedure, affects intended use, requres 510k submission or supplement
Any suggestions would be appreciated. Just want to make sure I'm not missing something.
Robin:)
Stijloor
Hi, I'm working on revising our current Document Control Program. Specifically regarding the method in which document changes are reviewed and approved. Our hope is to streamline the process to allow documents to pass through the system quicker yet ensure control over the changes is maintained. Given the FDA is looking at risk as it applies to various processes/procedure, I want to implement risk assessment to the change which will then determine who needs to approve the change. Currently we have QS, Operations/Mfg and Research review all PCRs. Others (e.g. planning/purchasing, marketing, etc.) also review but it depends on the changes being proposed. What type of examples would you apply to a change that would classify it as a 'low', 'medium' or 'high' risk change? We manufacturer IVD Class II medical devices.
To me:
  • Low = typo change, doesn't affect validation/process, change made for clarification purposes only.
  • Med = customer notification required, design change, change may have affect on validation/process. Depends on if the change affects a critical element.
  • High = new design, new procedure, affects intended use, requires 510k submission or supplement
Robin:)
Suggestions for Robin?
Thank you for helping!!
Stijloor.
sagai
Hi Robin,
I am not quite sure I share the entirely same view about the application of Risk Management as defined in ISO14971:2007.
The origin of this difference could origin from the way of Change Management handled.
According to my understanding document change does not initiate Risk Management related activities, it works in the opposite order, during the investigation of a change request for process, product feature, etc. could initiate risk related activities next to the others like error correction including modification in the documentation.
So sum it up, when there is a change request related somehow the safety and effectiveness of your already marketed product you should review the safety aspect of the change request and based on that create an action plan (in case there is no effect on safety, than also has to be documented for example in an impact analysis document).
I am not quite sure the purpose of the risk assessment fulfilled if it rarely determines who should be the approver of the change.
This issue indicates me more about the need to have a clear role based definition of reviewers and approvers, based on document types and the status of the product.
Actually when your product on the market, the risk relevance analysis of the change request should do that. I do not think the classification is so important, but the action plan related to the change request and that change is safety related, that is the important.
May be there are a slightly different interpretation as regard to change related risk among us, i would be happy to discuss and see others prospective.
br
Sz.
Q
QAINOVA
Thank you for replying back to my question. I agree with your statement regarding the application of risk being followed by change. I guess my question wasn't clearly stated. My mistake....but your feedback gives me more food for thought.
:thanx:
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
J US Manufacturer of Export Only Exempt Products applying for CFG 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
L What is the very first step to prepare for applying EASA POA? EASA and JAA Aviation Standards and Requirements 1
J Applying for 510K - What is a significant process change and what is not US Food and Drug Administration (FDA) 5
M Importing a Registered Class II Device, the Applying Our Label - Need New 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
somashekar Applying legal requirements in hazardous waste management. Miscellaneous Environmental Standards and EMS Related Discussions 1
P Applying Combined Tolerances of Two Scales - Balance Tolerance Question General Measurement Device and Calibration Topics 9
C Retroactively applying procedures in ISO 9001:2008 Quality Manager and Management Related Issues 6
A Applying VDA 6.2/6.3 in a Logistics Company VDA Standards - Germany's Automotive Standards 3
P Applying design and development with unknown outcomes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Interpreting and Applying 7.3.2 Design and Development Inputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Applying Correction Factors to Furnaces Manufacturing and Related Processes 5
W Applying ISO 9001 Clause 7.3 in Special Case - Oil Refinery ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P HR knows I'm looking and that I've been applying for jobs Career and Occupation Discussions 23
L Applying the Lean Concept in Quality Management Systems Lean in Manufacturing and Service Industries 7
optomist1 Profile of a Surface - Applying Profile of a Surface Geometric Control Symbols Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Applying Statistical Analysis Methods to Work Safety Occupational Health & Safety Management Standards 3
Y Applying Human Factors and Usability Engineering - FDA Guidance Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Applying EN 62304 - Medical Device Software Architecture - Level of Detail IEC 62304 - Medical Device Software Life Cycle Processes 21
S Applying HAZOP and FMEA methods for HSE Hazard Identification in Construction Occupational Health & Safety Management Standards 3
M Consultant required for applying an ISO14001-2004 certification. ISO 14001:2015 Specific Discussions 14
H Problems with RABQSA - Applying for my Provisional Auditor (PA) status ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
J Applying Previous Failures to new PFMEA APQP and PPAP 2
W Applying for 510(k) Submission for Blood Glucose Monitor System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T Applying for FDA 510(k) for 21 CFR 892.2050 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
E Financial certification or disclosure statement for applying 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
E A question about small business qualification applying 510(k) for new product US Food and Drug Administration (FDA) 6
L API (American Petroleum Institute) Monogram - Applying and Removal Process Oil and Gas Industry Standards and Regulations 5
ScottK How to choose professional references when applying for a job? Career and Occupation Discussions 1
N Applying FMEA to all Pre-Production Processes FMEA and Control Plans 5
T Applying Lean Tools in Product Development Lean in Manufacturing and Service Industries 2
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
Y Accurately applying a specific clause to a Non Conformance Internal Auditing 10
A APQP and Food Products - Applying APQP to the production of a new kind of milk APQP and PPAP 3
M Applying AQL when 0 defects are acceptable AQL - Acceptable Quality Level 9
G Whats the difference in applying error factor and correction factor? General Measurement Device and Calibration Topics 1
T Applying Scanned Signatures to Documents for Signing Document Control Systems, Procedures, Forms and Templates 11
Q Applying SPC in a Computer Assembly Shop Statistical Analysis Tools, Techniques and SPC 7
C Too Deep? Applying APQP to a Major Component and to Suppliers IATF 16949 - Automotive Quality Systems Standard 4
B Applying the principles an practices of C/A - P/A? Corrective Action and children? Nonconformance and Corrective Action 7
Q Applying for internal job but you know 100% that you are not going to get the job Career and Occupation Discussions 10
S Applying principles of lean to a calibration lab? Lean in Manufacturing and Service Industries 8
T Comparison of EU and US GMPs - Differences applying CFR211 or the EU GMPs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
I Lean in the Tool and Die Industry (Job Shop) - Applying Lean in "one-off" production Lean in Manufacturing and Service Industries 6
U Applying Lessons Learned to other products Misc. Quality Assurance and Business Systems Related Topics 2
Tim Folkerts Applying FMEA to National-Level Issues FMEA and Control Plans 10
W Applying MTBF and MTTR to Maintenance Misc. Quality Assurance and Business Systems Related Topics 2
S Applying PPAP to Suppliers - TS 16949 Clause 7.3.6.3 Supplier Quality Assurance and other Supplier Issues 10
Q And now, let's add software development - Medical Devices - Applying ISO9001:2000 ISO 13485:2016 - Medical Device Quality Management Systems 12
