Applying the Lean Concept in Quality Management Systems
LUV-d-4UM
Recently, I met with the Top Management of our organization. The meeting yielded a possible suggestion from her that I infuse the quality management system with some new life in the form of streamlining the management system so that the supply point will always be ready for ISO/TS and Customer Specific audits-OEM or non-OEM. How do I apply the LEAN principle in the management of these different quality systems. Your feedbacks are highly appreciated
RoxaneB
Re: Lean concept in Quality Management System
Why do you feel that the tools associated with Lean manufacturing are different than those used by quality management sytems?
If anything, I think there is a strong relationship between the two...especially when one replaces the word 'quality' with the word 'business'. Forget the idea of having a quality management system...and a safety management system...and an environmental management system. Have a Business Management System...a BMS that is the core of what your organization does for all things in all ways...it is your culture, your tools, your business "bible" on how you conduct business.
However, getting back to your actual question...as part of your QMS, have you developed process maps or work instructions outlining the activities that your organization does?
Are they effective? Are they efficient? How do you know? Do you have build-up of inventory along the manufacturing line? What about using Kaizen events as a means to demonstrate continual improvement? What about using 5S as a means to show preventive action or even a way to assist in controlling the production line?
What a great opportunity! I've be positively excited at the chance to do this!
An obvious place (to me) to start this is taking a look at value stream mapping. If you look at what the process and procedures say compared to the actual practice, using the eyes of a Lean practitioner, you'll see that there's a huge difference! Also, taking examples of processing forms - like purchasing requisitions -if you apply one piece flow etc an look for little 'holding areas' for these forms, you'll often find that the process isn't clear, the form doesn't have all the info etc., so a small 'inventory' of WIP appears - all indicate a problem with the process!
Think of the eight wastes. How can you reduce them?
There are 3 ways the QMS can 'be lean'.
  1. Reduce the non value add processes and steps within quality and the QMS processes. Reduce bureaucracy.
  2. Support lean initiatives within the organization. Actively participate and take suggestions from the org on how best to lean quality owned processes
  3. Actively promote lean within the organization through quality objectives and quality led initiatives and projects.
Mike Mickelwright has a decent book on leaning your QMS I strongly recommend it as a starting point for number 1.
LUV-d-4UM
Thank you for supporting this light bulb. I will update you all with this project going forward.
LUV-d-4UM
Thank you. I need all the resource I can gather before the proposal. I will call it TOTAL QUALITY MANAGEMENT SYSTEM-101.
Sturmkind
AndyN had a great observation about WIP in paperwork. I did a process flow map of a relatively small gear manufacturing site beginning from first customer contact wanting product through shipment and, if the post-it note WIP was included, the part number alone was written out 41 times.
At the conclusion of a 3 month cross-functional effort, this was reduced to 12.
Best of luck with your effort!
T Applying Lean Tools in Product Development Lean in Manufacturing and Service Industries 2
S Applying principles of lean to a calibration lab? Lean in Manufacturing and Service Industries 8
I Lean in the Tool and Die Industry (Job Shop) - Applying Lean in "one-off" production Lean in Manufacturing and Service Industries 6
N Maximum mains voltage used when applying 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
J US Manufacturer of Export Only Exempt Products applying for CFG 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
L What is the very first step to prepare for applying EASA POA? EASA and JAA Aviation Standards and Requirements 1
J Applying for 510K - What is a significant process change and what is not US Food and Drug Administration (FDA) 5
M Importing a Registered Class II Device, the Applying Our Label - Need New 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
somashekar Applying legal requirements in hazardous waste management. Miscellaneous Environmental Standards and EMS Related Discussions 1
P Applying Combined Tolerances of Two Scales - Balance Tolerance Question General Measurement Device and Calibration Topics 9
C Retroactively applying procedures in ISO 9001:2008 Quality Manager and Management Related Issues 6
A Applying VDA 6.2/6.3 in a Logistics Company VDA Standards - Germany's Automotive Standards 3
P Applying design and development with unknown outcomes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Interpreting and Applying 7.3.2 Design and Development Inputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Applying Correction Factors to Furnaces Manufacturing and Related Processes 5
W Applying ISO 9001 Clause 7.3 in Special Case - Oil Refinery ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P HR knows I'm looking and that I've been applying for jobs Career and Occupation Discussions 23
optomist1 Profile of a Surface - Applying Profile of a Surface Geometric Control Symbols Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Applying Statistical Analysis Methods to Work Safety Occupational Health & Safety Management Standards 3
Y Applying Human Factors and Usability Engineering - FDA Guidance Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Q Applying Risk to the Medical Device Document Control Program Document Control Systems, Procedures, Forms and Templates 3
M Applying EN 62304 - Medical Device Software Architecture - Level of Detail IEC 62304 - Medical Device Software Life Cycle Processes 21
S Applying HAZOP and FMEA methods for HSE Hazard Identification in Construction Occupational Health & Safety Management Standards 3
M Consultant required for applying an ISO14001-2004 certification. ISO 14001:2015 Specific Discussions 14
H Problems with RABQSA - Applying for my Provisional Auditor (PA) status ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
J Applying Previous Failures to new PFMEA APQP and PPAP 2
W Applying for 510(k) Submission for Blood Glucose Monitor System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T Applying for FDA 510(k) for 21 CFR 892.2050 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
E Financial certification or disclosure statement for applying 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
E A question about small business qualification applying 510(k) for new product US Food and Drug Administration (FDA) 6
L API (American Petroleum Institute) Monogram - Applying and Removal Process Oil and Gas Industry Standards and Regulations 5
ScottK How to choose professional references when applying for a job? Career and Occupation Discussions 1
N Applying FMEA to all Pre-Production Processes FMEA and Control Plans 5
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
Y Accurately applying a specific clause to a Non Conformance Internal Auditing 10
A APQP and Food Products - Applying APQP to the production of a new kind of milk APQP and PPAP 3
M Applying AQL when 0 defects are acceptable AQL - Acceptable Quality Level 9
G Whats the difference in applying error factor and correction factor? General Measurement Device and Calibration Topics 1
T Applying Scanned Signatures to Documents for Signing Document Control Systems, Procedures, Forms and Templates 11
Q Applying SPC in a Computer Assembly Shop Statistical Analysis Tools, Techniques and SPC 7
C Too Deep? Applying APQP to a Major Component and to Suppliers IATF 16949 - Automotive Quality Systems Standard 4
B Applying the principles an practices of C/A - P/A? Corrective Action and children? Nonconformance and Corrective Action 7
Q Applying for internal job but you know 100% that you are not going to get the job Career and Occupation Discussions 10
T Comparison of EU and US GMPs - Differences applying CFR211 or the EU GMPs Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
U Applying Lessons Learned to other products Misc. Quality Assurance and Business Systems Related Topics 2
Tim Folkerts Applying FMEA to National-Level Issues FMEA and Control Plans 10
W Applying MTBF and MTTR to Maintenance Misc. Quality Assurance and Business Systems Related Topics 2
S Applying PPAP to Suppliers - TS 16949 Clause 7.3.6.3 Supplier Quality Assurance and other Supplier Issues 10
Q And now, let's add software development - Medical Devices - Applying ISO9001:2000 ISO 13485:2016 - Medical Device Quality Management Systems 12
