Approval for Templates
E
EmmaS
Hi All,
I'm a complete newbie. I've just started a new job with a company that doesn't seem to have any document procedure / control in place. There is no Master Doc Register. I have no work experience in document control but I'm pretty logical and I'm good with procedures/templates etc so I'm currently populating a new server for them and building an MDR.
I have a couple of what I think are quite basic problems..
For processes and work instructions (where there generally aren't any fields that need to be filled in by the user), I have a section at the end of each document for "drafted/reviewed/approved by" and the date for each. No one here is using electronic signatures though so I'm unsure of the best way to record when these documents have been approved.
For templates that are being filled in (reports etc), I don't really have anywhere to put the "D/R/A by" section. And if I did, they aren't using electronic signatures so they would be empty on digital copies.
The other thing I am struggling with is where to put the document template number on some documents as their headers/footer are already packed with other details that they don't want to move. They are using a mixture of word and excel. This might sound very stupid, but it is absolutely critical that the document number appears on every page of a document? Ideally that's what I would like but cramming it into some existing templates is proving tricky.
If anyone had any advice I would be most grateful. I have already found some very helpful threads on here but I think this query is so basic I can't find anything about it. :lol:
E
EmmaS
They have the below listed on some of the current documents they are using, so I am assuming these apply. I have to confirm with them if this is still relevant to them though! I haven't any experience with standards so unsure what they require. Can I get access to them anywhere to read up?
ISO9001 (2008 Revision)
ISO14001 (2004 Revision)
OHSAS18001 (2007 Revision)
BoardGuy
The documents listed are currently obsolete and you will need to obtain the following revisions:
ISO 9001:2015
ISO 14001:2015
OHSAS 18001:2010
As for document control, you should make the system as simple as possible and here are a few pointers:
1) Documents do not have to be numbered. Standards only requires that they be identified and current revisions known; the name of the document with revision is sufficient. I.e. Record Control - Rev. A, Document Control - Rev. B, Contract Review – Rev. C, Corrective Action Form – Rev. A, etc.
2) Revision pages are not a required element. Have them be a separate document that shows revisions to be made and that they were reviewed before implementation. Doing this will prevent procedures and work instructions from having revisions sections larger than the actual documented information.
3) Have just one person with approval authority for a created document. I.e. Contract Review Procedure approval by Sales Manager, Design and Development Procedure approved by the Engineering Manager, Final Inspection Procedure approved by the QA Manager, Etc. The standards do not require that large groups must approve documents, only that they are approved for release.
4) Not every requirement within standards must have a procedure or work instruction. Use a Quality Manual to address them such as internal communication, customer communication, etc.
5) Make the system work for your organization and a not certification auditor.
E
EmmaS
This helps a lot, thank you! I'm going to print off what you've said so I can digest it tomorrow against what I've started doing. I'm not too far in to so if there's something I should or should not be doing I want to make sure I get it sorted early on. I will mention the out of date standards to them as they are currently putting these out on documents to clients.
Edit: At what point do document numbers become a requirement? All the companies I've worked in previously have had document numbers so that's why I had started numbering them here.
Eredhel
Quality Manager
Numbering is a common practice, but I've never seen it be a requirement, and I'm familiar with ISO 9001, AS 9100, and API. It's kind of like a Job Traveler, they aren't required but they fulfill a lot of things that are required and most job shops use them. Does your company have a Quality Assurance manager, or anyone that manages the quality management system? If it's something they're having you do on your own you might consider taking an internal audit class for ISO 9001, if there is a decent one nearby. It could help you get a better understanding of quality management systems in general.
BoardGuy
[FONT=&quot]They only become required if you say they must be used. When you start writing your documentation your first pass should be to record what is actually being performed. Once you know what is being done today then see if it conform to the requirements of the standards as written. If it does not then add what is missing.[/FONT]
D Changing Templates Approval Field Document Control Systems, Procedures, Forms and Templates 5
S Showing Evidence of Review and Approval of Blank Forms and Templates 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Special Approval procedure and templates for related forms wanted Document Control Systems, Procedures, Forms and Templates 5
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
B SN95 Respirator Approval Information Other Medical Device Related Standards 0
P Notified Body Approval of Change EU Medical Device Regulations 2
Marcel DS GOST-R (Type approval for Vehicles in Russia) Other ISO and International Standards and European Regulations 0
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
O Radio modular approval in Brazil Other Medical Device Regulations World-Wide 2
O Radio Modular approval in China China Medical Device Regulations 0
dgrainger Clue to UK's new regulatory requirements - approval of all devices placed on the market? Other Medical Device Regulations World-Wide 1
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
F How to fill out an Appearance Approval Report (AAR) APQP and PPAP 0
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Production approval testing - Alternative ideas for Validation Reliability Analysis - Predictions, Testing and Standards 4
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F Medical Devices - Hong Kong - Post approval changes regulation (China's MOH) Other Medical Device Regulations World-Wide 3
F Medical Devices-South Africa _Post approval changes and Software Other Medical Device Regulations World-Wide 0
C NB approval - Basic question about Notified Bodies and their role EU Medical Device Regulations 10
C AS9145 Appendix D PPAP Approval Form APQP and PPAP 2
N China - Start manufacturing before change approval? China Medical Device Regulations 3
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
D ROW Approval Matrix Other Medical Device Regulations World-Wide 2
T Clinical trial - Medical device product not cleared (without FDA approval) in a drug trial Other US Medical Device Regulations 9
S Education authority requires approval of all courses - Training services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Can Brazil approval be used for other countries in Latin America? Other Medical Device Regulations World-Wide 2
M Does cFDA accepts FDA approval or CE marking? China Medical Device Regulations 1
S NADCAP approval for Conventional Machining and Chemical processes - need assistance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
DuncanGibbons FAA approval of articles (PMA, TSO) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
M Criteria and when to carry out Setup Approval Manufacturing and Related Processes 5
D Engineering Drawing Review and Approval Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K ISO 9001 Requirements for Raw Material Supplier Assessment and Approval ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T AS9100 Maintain Approval When Business Ownership Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Informational USFDA Guidance – Acceptance and Filing Reviews for Premarket Approval Applications (PMAs) Medical Device and FDA Regulations and Standards News 0
I Document levels and approval requirements for lower level documents like work instructions, forms etc. Document Control Systems, Procedures, Forms and Templates 18
S FDA approval process for medical device US Food and Drug Administration (FDA) 2
Sidney Vianna AS9100 News PPAP in the Aerospace Sector - What is it? AS9145 - Requirements for Advanced Product Quality Planning and Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Q AS9120B Clause 8.4.1.1 External Providers Scope of Approval AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J IEC 62366 - Ethical approval IEC 62366 - Medical Device Usability Engineering 5
H Informational What is PPAP (Production Part Approval Process)? APQP and PPAP 26
C Approval of raw material suppliers which do not manufacture the material ISO 13485:2016 - Medical Device Quality Management Systems 7
S MDD in 2018 - Company with no previous EU approval EU Medical Device Regulations 1
