Approval of Documents - Is Verbal Approval good enough?
Big Jim
#22
I'm in the process of writing up our Control of Documents procedure, and I'm puzzling over how detailed we need to be when it comes to approving our documents 4.2.3(a).
We're not a huge company (~50 employees), with four departments.
When a document needs to be updated/changed/created, the manager of a department, with input from his/her subordinates, will come up with a version of what they want the document to look like. The manager then communicates this information to the QMS guy (me). I formalize the change (basically meaning I type it into the computer), and then when I'm done, I show it to the manager (this could be done as an e-mail attachment or by presenting him/her with a printed hard copy of the document - we haven't formalized this part and don't intend to), and then the manager tells me verbally that it looks good (ie that I have made the understood the changes he/she wanted me to make and that I made the changes accordingly - in other words, I think it can be said that they approve of the change - verbally). Once I have this verbal approval, I proceed with the rest of the 'Control of Documents' procedure (archiving the old version of the document, placing the new version in a network share accessible to the employees, updating a document that shows the revision history (including a comment about who approved the current version of the document), etc.
So I guess my question is, is this sufficient (especially the verbal approval part)? I mean, there's no real 'record' that the verbal approval actually occured. All I do is make a note of who approved the change in an excel spreadsheet that lists all of our documents.
Do we need to incorporate some kind of electronic/digital signature document approval procedure as part of our Control of Documents procedure? I'd rather not get into that if I don't have to.
Thanks in advance for your replies, Elsmar Cove community!
FrameReader
What you have in mind is appropriate. Something that has been missed by many other posters is that there is no requirement for keeping records associated with element 4.2.3.
Anywhere in the ISO 9001:2008 where records are required, it is clearly specified and element 4.2.4 is referenced. You won't find it in 4.2.3.
#23
There are many good responses on this thread and I'm sure it will be of use to many who have similar questions.
Several posters have mentioned keeping things appropriate to the size of the company which is very good advice indeed. But one should also be aware of potential changes (growth hopefully)
The OP says his company is about 50 souls. To me this is a size that is on the cusp of needing more detailed controls (again depending on the particulars of the company).
Once you start getting much over 50 people communication can get more complicated very quickly. Particularly if business is good. Many times a company this size still has people wearing multiple hats and they are very busy.
So while in the initial start up of a system one might try to keep it as simple as possible, relying on the fact that the company has grown and prospered well with the current team, one should also bear in mind that as the company continues to prosper, more control may be needed fairly quickly.
When I took my job as QM the company was about 30 souls and much was done "verbally". It worked fine, but I could see that the company was going to grow, so I tried to anticipate the needs for greater control and greater 'documentation". When I left we were nearly 100 souls and the systems were much more detailed than at the beginning.
So - I've taken a long time to say - Don't just consider the short view of how you document these things, but consider the longer view as well. Assume tha tthe company will grow and organize your system to be able to grow with it without undue changes.
Peace
James
K
Ka Pilo
#24
Why not get the approval in writting?
In theory, verbal approval is the same as written approval.The difference is that verbal is not suported by any documentation, while written clearly shows that the approver have approved a specific document. In ISO 9001 view point, which one shows "control of org's QMS documents" and "control documents that are used as QMS records?"
What evidence you can show that the approval has actually been done?
FrameReader
It's all up to you as long as provision of evidence that what was planned, has actually been done.
Big Jim
#25
But remember that the standard does not require that you maintain evidence (records) that it is actually being done.
True, it may make the work of the auditor a bit more difficult, because when records are not needed, and he must determine that you are meeting the requirement, he is compelled to determine what your practice is. And that is done with interviewing and observing how it is done.
Likes: db
K
Ka Pilo
#26
Approval should be recorded prior to the release and use of the document. All approvals should come prior to release.
ISO 9001 4.2.3 a)
to approve documents for adequacy prior to issue,
samsung
#27
ISO 9001 4.2.3 a)
The above statement 'to approve documents for adequacy prior to issue' should not be construed to mean 'keep record of'. It does require 'approval' which can be in verbal form as well if the person concerned doesn't disapprove or deny it.
K
Ka Pilo
#28
Assuming that the approval in a verbal form is acceptable, the question became: How can you show that it precede the document’s release date?
sagai
#29
even more, how the verbal approver can recall all her/his verbal approval for each release of the documents in case auditor request?
There are several obvious cases when verbal approve can not be acceptable and not because of any standard but rather because you shall run a "money safe" business for example project plan, resource assignments, appointments, budgets, project/product risk related records, etc.
br.
Sz.
K
Ka Pilo
#30
Perhaps the appropriate statement is
Any form of approval is acceptable as long as the procedure indicates what constitutes the evidence that the document is approved.
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
I Document levels and approval requirements for lower level documents like work instructions, forms etc. Document Control Systems, Procedures, Forms and Templates 18
C Document Management Solution for Routing Documents for Approval Manually Document Control Systems, Procedures, Forms and Templates 18
J Requirements for Review and Approval of QMS Documents Document Control Systems, Procedures, Forms and Templates 14
T Document Approval Process for Company Documents Document Control Systems, Procedures, Forms and Templates 20
B Requirement for Review and Re-Approval of Documents - ISO 9001 Clause 4.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S How to show Approval for Documents and Training? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
J Approval of Grandfathered Documents - ISO 9000:2000 Clauses 4.2.3 a&b Document Control Systems, Procedures, Forms and Templates 9
F Who should Sign Supplier PPAP (Production Part Approval Process) documents? APQP and PPAP 13
S Document Approval Matrix - What manager needs to sign what documents Document Control Systems, Procedures, Forms and Templates 11
C Control of Documents - Our approval process is kinda long Document Control Systems, Procedures, Forms and Templates 2
W Approval of Electronic Documents - How do we indicate "document approval"? Document Control Systems, Procedures, Forms and Templates 9
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
B SN95 Respirator Approval Information Other Medical Device Related Standards 0
P Notified Body Approval of Change EU Medical Device Regulations 2
Marcel DS GOST-R (Type approval for Vehicles in Russia) Other ISO and International Standards and European Regulations 0
O Radio modular approval in Brazil Other Medical Device Regulations World-Wide 2
O Radio Modular approval in China China Medical Device Regulations 0
dgrainger Clue to UK's new regulatory requirements - approval of all devices placed on the market? Other Medical Device Regulations World-Wide 1
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
F How to fill out an Appearance Approval Report (AAR) APQP and PPAP 0
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Production approval testing - Alternative ideas for Validation Reliability Analysis - Predictions, Testing and Standards 4
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F Medical Devices - Hong Kong - Post approval changes regulation (China's MOH) Other Medical Device Regulations World-Wide 3
F Medical Devices-South Africa _Post approval changes and Software Other Medical Device Regulations World-Wide 0
C NB approval - Basic question about Notified Bodies and their role EU Medical Device Regulations 10
C AS9145 Appendix D PPAP Approval Form APQP and PPAP 2
N China - Start manufacturing before change approval? China Medical Device Regulations 3
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
D ROW Approval Matrix Other Medical Device Regulations World-Wide 2
T Clinical trial - Medical device product not cleared (without FDA approval) in a drug trial Other US Medical Device Regulations 9
S Education authority requires approval of all courses - Training services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Can Brazil approval be used for other countries in Latin America? Other Medical Device Regulations World-Wide 2
M Does cFDA accepts FDA approval or CE marking? China Medical Device Regulations 1
S NADCAP approval for Conventional Machining and Chemical processes - need assistance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
DuncanGibbons FAA approval of articles (PMA, TSO) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
M Criteria and when to carry out Setup Approval Manufacturing and Related Processes 5
D Engineering Drawing Review and Approval Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K ISO 9001 Requirements for Raw Material Supplier Assessment and Approval ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T AS9100 Maintain Approval When Business Ownership Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Informational USFDA Guidance – Acceptance and Filing Reviews for Premarket Approval Applications (PMAs) Medical Device and FDA Regulations and Standards News 0
