Approval of Supplier with ISO 9001 (Automotive)
Booker
I hope that I have simple question with straight forward answer.
We are automotive company and we need to release on of our supplier which has "only" ISO 9001.
Can someone recommend overall approach how to release this supplier?
I believe that conducting of process audit according VDA 6.3 is meaningless.
Thank you for any hint!
Coury Ferguson
Moderator here to help
Well, I am not a Automotive Specialist, but I would guess that if your supplier is registered to ISO9001 it should be sufficient. Any added requirements for the Automotive side could be flown down via the Purchase Order (PPAP and such).
Just my opinion.
howste
Thaumaturge
Is your organization certified to an automotive QMS standard such as IATF 16949? If so, you should refer to that standard and any customer-specific requirements documents to see if additional requirements for supplier qualification exist. For example, IATF 16949 requires:
The organization shall require their suppliers of automotive products and services to develop, implement, and improve a quality management system certified to ISO 9001, unless otherwise authorized by the customer [e.g., item a) below], with the ultimate objective of becoming certified to the Automotive QMS Standards. Unless otherwise specified by the customer, the following sequence should be applied to achieve this requirement.
a) compliance to ISO 9001 through second-party audits;
b) certification to ISO 9001 through third-party audits; unless otherwise specified by the customer, suppliers to the organization shall demonstrate conformity to ISO 9001 by maintaining a third-party certification issued by a certification body bearing the accreditation mark of a recognized IAF MLA (Internal Accreditation Forum Multilateral Recognition Arrangement) member and where the accreditation body's main scope includes management system certification to ISO 9001/IEC 17021;
c) certification to ISO 9001 with compliance to other customer-defined QMS requirements (such as Minimum Automotive Quality Management System Requirements for Sup-Tier Suppliers [MAQMSR] or equivalent) through second-party audits;
d) certification to ISO 9001 with compliance to IATF 16949 through second-party audits;
e) certification to 16949 through third-party audits (valid third-party certification of the supplier to IATF 16949 by an IATF 16949-recognized certification body).
sreeumesh
Thank you 'howste' for the right passage from IATF-16949.
As a step by step transition, IATF provides in point c):
Now the company I work for has a bunch of ISO 9001 suppliers but we do not have much resources to perform 2nd party audits. Can we ask the suppliers to have 3rd party audits done for compliance to the MAQMSR? Are the certifying bodies who certify companies to ISO-9001 and IATF-16949 like TÜV-Sud also perform audits to check complaince to MAQMSR? Since I do not find such an audit in their websites.
:thanx:
Sidney Vianna
Post Responsibly
Can we ask the suppliers to have 3rd party audits done for compliance to the MAQMSR? Are the certifying bodies who certify companies to ISO-9001 and IATF-16949 like TÜV-Sud also perform audits to check compliance to MAQMSR?
You would have no control over the competence level of the 3rd party auditor and his/her knowledge of MAQMSR, and, thus, no control over the effectiveness of such audits.
You can hire an auditing agency/auditor to perform such second party audits on your behalf and ensure the auditors performing this focused audit are qualified for the task.
Welcome to The Cove.
sreeumesh
Thanks Sidney Vianna you for the info.
I learnt that accredited certifying agencies do not certify a company to 'MAQMSR' but only check compliance during certification audit for ISO-9001. How do they then confirm the compliance? In a separate writing? Or as an annex to the ISO-9001 certification? This is when we require our suppliers to arrange the audits themselves.
:thanx:
Sidney Vianna
Post Responsibly
You are attempting to create a no-cost "solution" for you, but, as I said, it would NOT satisfy the letter of nor the intent of the IATF 16949 document for supplier development, for reasons that I explained in my previous post.
So, you are running the risk of having the situation identified by your IATF auditor and written up.
Good luck.
Ninja
Looking for Reality
FWIW, been there, done that (from the supplier end).
Either find a way to satisfy your auditor and CB to accept only ISO9001, or put in the expense req. to pay for the cost your supplier "should" pass on to you for the expense of certifying to IATF16949.
If you need the supplier, you (as the automotive customer) should be willing to pay for your supplier's cert and all support activities.
No wonder why american cars cost so much...my next car will be a Honda...better and cheaper...
Golfman25
Actually I would rather pay my customer to send one of their internal guys to audit us and drop third party altogether. I think the more interaction between vendors and customers is good.
Helmut Jilling
Auditor / Consultant
You can also ask the supplier to pay for the equivalent of 2nd party audits as part of their development. You don’t necessarily have to pay for it or use your personal staff. Also, keep in mind, that long list of recommended steps does not have a set deadline.... it is a developmental process over time, to improve a sub-supplier internal system and performance.... implicit in that list is that it will take time to move supply chain toward to “ultimate objective.” It would take years for the certification bodies to even certify that many companies.
K ISO 9001 Requirements for Raw Material Supplier Assessment and Approval ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 14001 Implementation Help & Question about Supplier Approval ISO 14001:2015 Specific Discussions 5
T ISO 9001 Clause 7.4.1 Purchasing Process (Supplier Approval) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
L Supplier Approval Process – Should the Quality Department be Excluded? Misc. Quality Assurance and Business Systems Related Topics 7
N Raw Material Supplier Approval (Inks, Resin, Masterbatch etc) Supplier Quality Assurance and other Supplier Issues 4
B Supplier Approval of electronic document storage service ISO 13485:2016 - Medical Device Quality Management Systems 8
L Chrysler's Supplier Request for Engineering Approval Form Quality Manager and Management Related Issues 4
S Supplier Approval Problem - Off-the Shelf Parts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V Ford SREA (Supplier Request for Engineering Approval) 2007 revision Document Control Systems, Procedures, Forms and Templates 2
K How to fill out an SREA (Supplier Request for Engineering Approval) form at Ford? APQP and PPAP 3
V Supplier?s PPAP - Production Process Control Plan Review, Evaluation and Approval? FMEA and Control Plans 5
E PPAP PSW Approval: Customer Drawing or Supplier Drawing APQP and PPAP 4
V Repercussions for Interim Approval of Supplier PPAP's APQP and PPAP 3
R Responsibility and Authority in a QMS - Approval of Supplier Accreditation Quality Manager and Management Related Issues 5
B Supplier Approval for Distributors of Equipment Misc. Quality Assurance and Business Systems Related Topics 5
J Supplier Purchase Order Review and Approval Requirements IATF 16949 - Automotive Quality Systems Standard 3
M Supplier Evaluation and Approval of a Translation company ISO 13485:2016 - Medical Device Quality Management Systems 6
F Who should Sign Supplier PPAP (Production Part Approval Process) documents? APQP and PPAP 13
K Questions about SREA (Supplier Request for Engineering Approval) Customer and Company Specific Requirements 4
M Researching Supplier Approval Processes - When Two Companies Merge Supplier Quality Assurance and other Supplier Issues 5
B PPAP approval based on information supplied by the supplier APQP and PPAP 2
B General SREA (Supplier Request for Engineering Approval) form for all OEM's? IATF 16949 - Automotive Quality Systems Standard 4
T Vendor (Supplier) Approval Procedure - Scope of the procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
sonflowerinwales FDA approval required for a supplier to a medical device manufacturer? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Supplier approval for special services Supplier Quality Assurance and other Supplier Issues 2
B No Supplier PPAP or PSO (process approval) Requirement APQP and PPAP 3
C Supplier Evaluation and Approval forms - Discussion and Evaluation Examples Supplier Quality Assurance and other Supplier Issues 37
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
B SN95 Respirator Approval Information Other Medical Device Related Standards 0
P Notified Body Approval of Change EU Medical Device Regulations 2
Marcel DS GOST-R (Type approval for Vehicles in Russia) Other ISO and International Standards and European Regulations 0
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
O Radio modular approval in Brazil Other Medical Device Regulations World-Wide 2
O Radio Modular approval in China China Medical Device Regulations 0
dgrainger Clue to UK's new regulatory requirements - approval of all devices placed on the market? Other Medical Device Regulations World-Wide 1
F How to fill out an Appearance Approval Report (AAR) APQP and PPAP 0
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Production approval testing - Alternative ideas for Validation Reliability Analysis - Predictions, Testing and Standards 4
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F Medical Devices - Hong Kong - Post approval changes regulation (China's MOH) Other Medical Device Regulations World-Wide 3
F Medical Devices-South Africa _Post approval changes and Software Other Medical Device Regulations World-Wide 0
