Approved Job Descriptions under Revision Control - Required?
B Krause
Hello All,
During a recent certification audit we were dinged for not having approved job descriptions under revision control. We do have job descriptions for all positions that are approved by the HR department but, there is no revision on the actual document or an approval signature.
I am having trouble connecting the finding to an acual requirement or clause from the standard (13485:2003).
4.2.3 (Control of Documents) states that documents required by the QMS shall be controlled.
5.5.1 (Responsibility and authority) states that top management shall ensure that responsibilities and authorities are defined, documented, and communicated.
6.2.2 (Competence, awareness and training) states that the organization shall determine the necessary competence for personnel performing work affecting product quality; provide training; evaluate the effectiveness; assure personnel are aware of the importance of their activities; and maintain appropriate records.
None of these clauses specifically states that job descriptions are part of the QMS or that job descriptions need to be a controlled document.
Can anyone shed some light on this one?
Thanks in advance.
Sidney Vianna
Post Responsibly
Re: Job Descriptions
Do the job descriptions contain qualification requirements? Do such documents summarize basic requirements which be used to determine competence? If so, such documents become part of your QMS, and thus would need to be "controlled".
rmf180
Hello All,
Thanks in advance.
I agree with the response above with the following additions. What documents do you have which satisfy the requirements you listed from the standard. Job descriptions normally fit the bill perfectly, but if HR wants "their" documents excluded, what documentation exists which will satisfy the requirement? We had a similar situation where HR wanted to be "exempt" from any requirements. We had to create job summaries which satisfied the requirements, but did not require control of the job descriptions (HR documents). It was a big waste of time that should not have been needed, but it did get the job done. :bonk: Hopefully, you can illustrate the situation to others and can persuade them that controlling the job descriptions is the best way to handle the situation. In our case, the HR gang is too powerful and has the ear of the "Boss". :( Best of luck!
joshua_sx1
There is no written word (or paragraph) in the standard specifying exactly about “job description”… or even the requirements to document & control it… :nope:
…but here’s the hint :cool: …if you go to clause 6.2.2 stating the requirements for competence, awareness and training… the standard requires (one of the following) that the organization shall;
a) determine the necessary competence for personnel performing work affecting product quality… now, how the organization is going to determine the competence of their personnel if they don’t have document (e.g. job descriptions with the required minimum qualifications) specifying what competence level is required for personnel performing certain task? this is also being used during recruitment process...
d) ensure that its personnel are aware of the relevance and importance of their activities and how their contribute to the achievement of the quality objectives… now, how the organization is going to ensure this kind of awareness if they don’t have a process similar to the orientation where the human resource department supposedly orienting new employees, telling them not only their benefits and company’s rules & regulation but as well as how they are going to be valuable to the company? what documents they are going to use? and how they are going to be evaluated by their superior in absence of this document as basis?
I have also experienced the same dilemma with my previous company HR Dept… they simply wanted to be invisible… :rolleyes: and I let them… but during the audit, I raised so many NCR’s to them for having no evidence of complying clause 6.2.2…
It's clear that job descriptions, per se, are not required by ISO 13485. If your organization has them as part of your own QMS, and/or they define people's responsibilities/authorities and they are referred to in your QMS documentation in some fashion, then yes, they have to be controlled.
However, your post suggests the auditor is looking for more than that; revision numbers and signatures on the job descriptions - even if they are part of your QMS - are not required as part of a control system. You only need to show that these documents are under control/approved, which (quite frankly) doesn't mean having signatures or a rev. number/letter.
Your auditor is reporting the wrong thing and putting their 'spin' on what they believe document control requires - unless your own doc. control procedure says you'll have sigs and numbers on your docs.............
M Requirements for an MDD approved device after 26/05/2021 EU Medical Device Regulations 3
S Shipment of a CE Approved Class III Device to the EU Member States Other US Medical Device Regulations 1
Ajit Basrur Why is ISO 14644-3:2019 not approved by US? Other Medical Device Related Standards 1
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
K Changing the Address in 510(K) Approved Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Ed Panek Adverse Event Clinical Trial using a 510K approved Device Other US Medical Device Regulations 6
D FDA Approved Class II Medical Device? Other US Medical Device Regulations 11
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
D Document review on already approved registrations requested by China's NMPA? China Medical Device Regulations 3
Q AS9120 Vendor of ESD Monitoring Equipment needs to be in the Approved Supplier List? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
F List of approved API manufacturers or Formulations manufacturers US Food and Drug Administration (FDA) 0
J Change management with CFDA approved devices China Medical Device Regulations 1
J Dr Training Records - Training doctors to use a PMA approved medical device Other US Medical Device Regulations 2
L CQI & IRCA not accepting new applications for ATPs (Approved Training Partner) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
D FDA filing guidance to add sterilization step for approved drug Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
Jane's Should the facility landlord be an approved supplier? Supplier Quality Assurance and other Supplier Issues 12
I Adverse Event Reported during Non-Approved Indication Use EU Medical Device Regulations 4
F Scientific and Research Papers for Foreign Approved Devices Other US Medical Device Regulations 1
P Approved Supplier Register and Calibration Suppliers AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
J FDA approved Medical Devices for PVD and DLC Coatings US Food and Drug Administration (FDA) 2
M ISO 14971:2007 Revision Approved - The Delft ISO TC 210 plenary meeting - Nov 2016 ISO 14971 - Medical Device Risk Management 2
H IVD in US Phase III Clinical Trial - Non-CE Marked and Non-FDA Approved Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
J Why Control Plan Review needs to be Approved by the Customer IATF 16949 - Automotive Quality Systems Standard 1
F China Medical Device Labeling - Not approved for use, is for an exhibition EU Medical Device Regulations 4
S API Q1 Approved Training & Professional Certification Sources Oil and Gas Industry Standards and Regulations 5
gunnyshore Benchmarking: Approved Supplier List for Multiple Sites Supplier Quality Assurance and other Supplier Issues 2
S Why Drugs and generics are Approved while Biologics are Licensed ? US Food and Drug Administration (FDA) 1
L Do HR consultants need to be on Approved Supplier List? Supplier Quality Assurance and other Supplier Issues 5
M Making a change to an approved Medical Device Other US Medical Device Regulations 9
D Is a separate spreadsheet required for the ASL (Approved Supplier List)? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
J Investigational Device Exemption approved 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T Do Machine Service Contractors Need to be an Approved Supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L Can I ship Demo Units to the UAE if we are not Approved? Other Medical Device and Orthopedic Related Topics 2
J PT/ILC - No Approved Programs within our Scope of Accreditation General Measurement Device and Calibration Topics 2
Q Is there an Approved Pigment List to be used in Medical Devices ? US Food and Drug Administration (FDA) 8
S Mexico: Paths to approval for product that is CE-marked, but not FDA approved? Other Medical Device Regulations World-Wide 2
S AS9100 Approved Supplier List (ASL) Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
V Variations - Changes to Approved Dossiers - Drug Product US Food and Drug Administration (FDA) 0
P PSU Transformer Tests Approved to IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
N Which Suppliers Belong on my AVL (Approved Vendor List)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
N TGA CA Certificate approved suppliers ISO 13485:2016 - Medical Device Quality Management Systems 3
B API approved Auditors in India Oil and Gas Industry Standards and Regulations 3
R Terminology for referring to a product that has an approved Technical File EU Medical Device Regulations 3
S Can the Management Manual have only Issued and Approved By? Quality Manager and Management Related Issues 12
K Method to qualify COTS Suppliers into AVL (Approved Vendor List) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
P Documents Approved via Email Records and Data - Quality, Legal and Other Evidence 7
I Advice Needed For EASA Approved Aircraft Mod EASA and JAA Aviation Standards and Requirements 1
C ISO 22000 Stage 1 NC's - PRPs not approved and Objectives not inline with Policy Food Safety - ISO 22000, HACCP (21 CFR 120) 3
W Listing of Similar Medical Devices approved by CE NB EU Medical Device Regulations 6
