Approved Supplier List - Required to evaluate every supplier?
jenrl16
Having an approved supplier list is a "shall" in the ISO standards. Does this mean we need to evaluate every supplier? If not, how do we pick and choose which suppliers to evaluate? Is having a supplier evaluation sheet and a supplier approval list sufficient?
Also, does anyone have a list of the "shalls" that are mentioned throughout the ISO standards?
Randy
Re: Approved supplier list
What does the Standard say? Let's look...
7.4.1 The organization shall evaluate and select suppliers based on their ability to supply product in accordance with the organization's requirements. Criteria for selection, evaluation and re-evaluation shall be established.
Records of the results of evaluations and any necessary actions arising from the evaluation shall be maintained
It's not optional and, yes, you must evaluate ALL of them...
Oh yeah, don't waste time evaluating where you get your office supplies or who services the coke machines in the breakrooms....unless they can effect customer satisfaction or product conformity
arios
You may have a criteria defined in your supplier selection procedure indicating that you have various levels of vendors in your QMS, for example Type A, B, C, and D depending on their potential impact to your product. Then you can define which type of control you consider appropriate for them. For example a Type A vendor may need annual audits, COA's, maintan a current ISO certification, and IQC on each batch because it is a critical supplier. On the other extreme, a vendor type C (a less critical one) would only need to provide you with a survey suited to meet the particular needs of your QMS or bussiness needs.
I would take as valid that a vendor type D (for toiletries or office supplies for example) does not need to be listed in the ASL based on your analysis because it does not have an impact at all.
At the end, you should maintain your controls over the suppliers in accordance to the stated requirements in your procedure....and please don't forget to define a criteria for removing vendor from the ASL.
I hope this helps! This is my particular interpretation but other folks out there could provide you with their own approach.
Alberto
tlonkey
Not sure if this will help you but I have attached a copy of the format I use to record our approved suppliers. We also have a master file for each vendor where I keep all the associated records as required by the evaluation method, and control criteria. We do not keep a list of our office supply vendors, janitorial suppliers or those types of vendors on our AVL List. We keep a list of those types of vendors in our purchasing dept. and inventory dept..
tlonkey
Caster
An Early Cover
I think you got really good advice already.
If you can expand beyond ISO thinking to a holistic approach, finance or purchasing likely already has a system in place to select new suppliers which includes some kind of financial due diligence. If so, it would be easy to simply expand this system a bit to add in some kind of quality due diligence (not necessarily an audit). No need to create anything new, just add a bit to what they have.
As for a list of shalls, the ISO document is copyright so we can't share it here.
Most of us just bought a copy, scanned it, OCR'd it and built our own matrix of shalls to company procedures. It is good for the soul to go through the exercise, you get a better appreciation for the structure of the thing.
Or you could search here for an ISO audit checklist, it should get you close to what you want.
Welcome!
BradM
Thanks for mentioning that, Randy. I would suggest a risk-based approach to approving your suppliers. Like was mentioned, maybe create classifications for risk-levels. As you bring on a new vendor, perform some evaluation against the different risk-levels. If it's a A for example (coke machine; paper clips) then no further evaluation is warranted.
Keep it simple. Maybe keep a spreadsheet of all the evaluated suppliers, and what they are evaluated for (scope of evaluation). If they are not on the spreadsheet, they can't use them (or need to evaluate them). Lock the spreadsheet where it can't be changed.
Also, keep good communication with people in the organization. If there is a vendor that is not being used for bad quality, take them off the list. You certainly don't want someone else possibly buying from them.
howste
Thaumaturge
Nope, not since the 2000 standard was released. It's still a good idea though.
Yes, if they affect conformity to product requirements.
You need records that show that the suppliers have been evaluated against the criteria you specified.
If you have the standard, that is the list.
sherryg
An approved supplier list consists of suppliers who have been approved for purchases against a set of criteria specific to the requirements and needs of your company. Not all suppliers are going to make that list or should they be on it. And, all purchasers should be aware of the list, adhere to it and not buy from whomever they want (i.e., suppliers who are not approved and who may not meet your requirements/criteria). Thus, it's important to have specific, documented approval criteria for suppliers so that the ASL is a valuable tool. All purchasers should be aware of the criteria and should adhere to using only approved suppliers. Thus, there is a good reason behind this requirement. Maverick spend with unapproved suppliers is a big problem in many companies.
Q
qmslady - 2009
Nope, not since the 2000 standard was released. It's still a good idea though. Yes, if they affect conformity to product requirements.You need records that show that the suppliers have been evaluated against the criteria you specified.If you have the standard, that is the list.
Hi jenrl16,
I read some pretty good stuff here, don't know if you understood everything. I have found much help by searching engines and Wikipedia has alot of info on the Standards. I have the book so I can refer to it when I need to, but some times I need just "plain english".
Pay very close attention to the words in 7.4.1 "in accordance with the organization's standards" your company is the organization, what are your requirements for accepting purchased supplies? What are your customer's requirements for the supplies you purchase for thier product? And some customer's will tell you who they want you to buy from to meet these requirements. "Criteria for selection.....shall be established". What is your usual procedure for selecting a supplier? Do you use this method every time? Every supplier? If so, it is "established" that, that is how you do it. I have a general form, (template) for Supplier Self Survey and a list of general requirements that suppliers must meet, and if they don't, what will happen.
I hope this wasn't redundant...QMSLADY
bio_subbu
Hi
Supplier management is one of the most troublesome disciplines within a management system. Since you are implementing QMS in your organization, you must evaluate all your suppliers as per 7.4 of ISO standard. Supplier selection is based on various factors such as capability, availability, pricing and quality.
Capability:
whether the supplier have the capability to provide the type of product that you are expecting and all necessary services, warranties and information.
Availability:
The supplier provides the goods or service in time, desired location or not.
Pricing:
The supplier provide affordable price competitive given the total package of services offered. Please be noted that the lowest price is often not the best deal.
Quality: whether the supplier meets your specifications, tolerances and performance requirements or not.
Evaluation:
It is necessary to evaluate each supplier once your selecting process done, the exact frequency methods of evaluation and criteria are up to you. It emphasizes the most practical element of supplier performance, which is the ability to provide a product that meets all requirements. Evaluation can be done in the form of a signature, initials, stamp, or other identifier, along with the date it was performed.
Thanks and Regards
S. Subramaniam
U Approved Vendor (supplier) List Supplier Quality Assurance and other Supplier Issues 8
D Approved supplier list - Distributors question ISO 13485:2016 - Medical Device Quality Management Systems 6
D Approved supplier list for R&D ISO 13485:2016 - Medical Device Quality Management Systems 5
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
Q AS9120 Vendor of ESD Monitoring Equipment needs to be in the Approved Supplier List? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
gunnyshore Benchmarking: Approved Supplier List for Multiple Sites Supplier Quality Assurance and other Supplier Issues 2
L Do HR consultants need to be on Approved Supplier List? Supplier Quality Assurance and other Supplier Issues 5
D Is a separate spreadsheet required for the ASL (Approved Supplier List)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S AS9100 Approved Supplier List (ASL) Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Do I need to approve my Registrar and include them in the Approved Supplier List? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Corrective Action - AS9100 Approved Supplier List Audit Nonconformance Nonconformance and Corrective Action 14
S Trading Company - Evaluating Supplier Performance and Approved Supplier List ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Approved Vendor (Supplier) List and Supplier Evaluation Supplier Quality Assurance and other Supplier Issues 16
P Requirements for an Approved Supplier List? No new suppliers in years ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q AS9100 Clause 7.4.1 Purchasing Process and Approved Supplier List Records AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
T AVL (Approved Vendor List) Supplier Listing - ISO 13485 Requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
N Acceptance of Supplier to AVL (Approved Vendor List) - How long? Supplier Quality Assurance and other Supplier Issues 9
L Approved Supplier List - Customer Approved Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
GStough Approved Supplier List (ASL): Document or Record? Supplier Quality Assurance and other Supplier Issues 29
R Approved Vendor (Supplier) List contain Vendor Evaluation? Supplier Quality Assurance and other Supplier Issues 6
J Required to put original manufacturers on Approved Supplier List? Supplier Quality Assurance and other Supplier Issues 6
M Approved Supplier List ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 43
I Approved Supplier List - R & D, Capital Equipment ISO 13485:2016 - Medical Device Quality Management Systems 4
I Which Fringe Suppliers to Include in the Approved Supplier List? ISO 13485:2016 - Medical Device Quality Management Systems 11
Z Supplier of Automatic Gaging Systems need to be on our Approved Supplier List? IATF 16949 - Automotive Quality Systems Standard 6
B Approved Supplier List for Transportation (Trucking) and other Services IATF 16949 - Automotive Quality Systems Standard 5
ScottK ISO9001 Approved Supplier List format question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
R Approved Supplier List vs. Auctions - One-Time Equipment Buys ISO 13485:2016 - Medical Device Quality Management Systems 8
M Grandfathering suppliers to approved supplier list - Have to send out surveys? Supplier Quality Assurance and other Supplier Issues 11
Q Approved Supplier List - Control in the same way forms and procedures are? Supplier Quality Assurance and other Supplier Issues 5
D Approved Vendor (Supplier) List Issues - Class II medical device maker Supplier Quality Assurance and other Supplier Issues 2
T Our Approved Vendor / Supplier list contains EVERY supplier we currently have Supplier Quality Assurance and other Supplier Issues 15
J Approved Supplier List and Subcontractor Development Supplier Quality Assurance and other Supplier Issues 13
Jane's Should the facility landlord be an approved supplier? Supplier Quality Assurance and other Supplier Issues 12
P Approved Supplier Register and Calibration Suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Do Machine Service Contractors Need to be an Approved Supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Approved Supplier Control Requirements for Outsourced Special Processes Supplier Quality Assurance and other Supplier Issues 4
P Approved Suppliers - ISO 13485 Normal Supplier Qualification Process Requirements ISO 13485:2016 - Medical Device Quality Management Systems 9
D Do Freight Carriers or Transportation Companies need to be an Approved Supplier? Supplier Quality Assurance and other Supplier Issues 14
D Approved Condom-Benzocaine Supplier name - Need Help ISO 13485:2016 - Medical Device Quality Management Systems 6
D What document do you give to your supplier after approved parts? Supplier Quality Assurance and other Supplier Issues 12
C Approved Supplier? When supplier is no longer in business. Supplier Quality Assurance and other Supplier Issues 7
B What happens if we evaluate supplier as not approved and there are no anothers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
V How to become approved supplier by Sikorsky Helicopter? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Approved Vendor (Supplier) if Customer Pays Sub-tier Shipping Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D How can a vendor (supplier) with no third party certification be approved? Supplier Quality Assurance and other Supplier Issues 1
Q Do I have to qualify my approved vendor (supplier) status? Supplier Quality Assurance and other Supplier Issues 2
H Approved Supplier Listing - One time purchase? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
C Approved supplier/vendor - How do I approve my Registrar? Supplier Quality Assurance and other Supplier Issues 17
