APQP Compliance Internal Audit - Ideas, check lists or main questions to prepare
qusys
Do you have some ideas, check lists or main questions to prepare an internal audit to be compliance versus APQP AIAG Blue Book?
Who share something?
Thks a lot:bigwave:
Stijloor
Thks a lot:bigwave:
The AIAG APQP/CP manual contains a set of guidelines, not requirements, for quality planning. An (automotive supplier) organization may be required by their automotive customer(s) to use the manual for planning purposes, but not all guidelines may apply. So "auditing" against the APQP guidelines does not make a whole lot of sense to me. It would be better if you develop a process audit for the planning process as it applies to your company.
Hope this helps.
Stijloor.
qusys
Yes, actually is a preparation for our TS aduit. First time doing this.
Follow the suggestion of Stijloor.
I guess you are auditing the process of product and mfg process design & development as one of your QMS process.
My advice is to ensure the complaince to the clauses of ISO TS, checking for example for input/output of the process, responsibilities, records of verification, validation etc..., management of the changes...etc..
You could focus on one automotive product in all phase of AQPQ if you apply it.:bigwave:
qusys
Appreciated your thanks.
Consider that here in this forum there is a plenty of documentation.
Look in the green "post attachment" bar.
I made a research for you with key word "apqp".
This is the link:
http://elsmar.com/Forums/fileslist.php?mode=allfiles&sortby=filename&pageamt=1&criteria=apqp
Check to have some ideas and help for your intent. Probably there are some file that could help you, I think the 7th and the 8th in the list.
Hope this helps and welcome on the forum:bigwave:
Howard Atkins
Forum Administrator
APQP is a process which should be described- either by you saying that you are working according to the AIAG book or according to your own process
When Stijloor says it is not auditable this is correct as long as you do not say you work according to the handbook- then it is auditable.
As qusys says the APQP process is supposed to be a guide to the implementation of 7.1 and 7.3 in the standard.
You need to audit your process , the Control Plan and the FMEA are required outputs and as such only show this aspect of the process .
Check that your process does transform the required inputs- they are in the standard- into the required outputs- also in the standard.
Remember that if their are customer requirements, you must audit these as well.
e.g Ford
Says the following
4.14 Planning of Product Realization (ISO/TS 16949 cl. 7.1, 7.3.1,
4.2.1d, 7.3.4.1, 5.4.1, 5.4.2)
Appropriate to the supplier's responsibilities, the organization shall meet the
requirements of the Engineering Statement of Work (available on
https://web.gfss.ford.com )
For all supplier sites with parts launching under the Global Product
Development System (GPDS).
Effective 30th January, 2008, the Advanced Product Quality Planning form version 3.2 or 3.1 (Pan Brand) is replaced by Supplier APQP/PPAP Readiness Assessment
– Schedule A, see https://web.qpr.ford.com/sta/APQP.html and
https://web.qpr.ford.com/sta/GPDSSupplierEngagement.html on Ford Supplier
Portal.
Note: There may be vehicle programs already underway where the APQP versions 3.1 and 3.2 Pan Brand (see https://web.qpr.ford.com/sta/FPDSLaunch.html) are currently in use and this should continue unless otherwise authorized by Ford STA.
If you are a supplier to Ford- you must audit this.
Fiat
Says
6. Prototype Programme (Ref. ISO/TS 16949, § 7.3.6.2)
Supplier will provide all delivered prototype parts with Certification of Quality and Conformance of Prototypes.
These issues must be audited .
You must also show that your auditors have been trained on customer specific requirements.
qusys
e.g Ford
Says the following
Fiat
Says
Hi Howard,
your points are precise and give precious suggestions.
My post went in that sense you got deeper and deepr.
I would also like to suggest to the poster that he should also verify that the same procedure for mgf process approval used by the organization shall also apply to the suppliers of the same organization.
So, if he mentioned APQP, I assume that they are also using PPAP , so, based upon the clause of standard 7.3.6.3., they shall go in that sense too with suppliers.
So, this is another item to check in the internal audit for their process.
Hope this helps again.:bigwave:
H APQP phases costs APQP and PPAP 4
G Issues/Roadblocks with APQP implementation APQP and PPAP 7
G APQP Scope and scale tool APQP and PPAP 2
G AS9145/APQP return on investment APQP and PPAP 6
Pau Calvo PPAP customer requirements in the APQP APQP and PPAP 25
C AS9100 Rev D 8.1.1 & APQP - Operational risk management process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B What is the role of Quality Engineer in APQP and PPAP APQP and PPAP 3
S APQP Relationship Diagram APQP and PPAP 2
C Looking for APQP Training recommendations preferably in the aerospace industry APQP and PPAP 2
G Engineering Specifications - APQP APQP and PPAP 5
K APQP Gates_Project/Product Localization APQP and PPAP 4
K APQP Phase 3 - Team Feasibility Commitment APQP and PPAP 3
A New Supplier implementation - PPAP vs APQP APQP and PPAP 9
F APQP for Medical Devices APQP and PPAP 4
A How to view supplier APQP timeline and do risk management APQP and PPAP 4
J Does anyone have a good APQP template that meets IATF requirements? APQP and PPAP 3
Sidney Vianna SCMH Awareness Webinar Focused on the revised Advanced Product Quality Planning APQP AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
kedarg6500 APQP & PPAP for Process Industry - Concept for Waste to Energy Program APQP and PPAP 0
H Prerequisites for AIAG APQP/PPAP Certification Exam Training - Internal, External, Online and Distance Learning 2
J APQP Requirements - What is meant by "among other items" IATF 16949 - Automotive Quality Systems Standard 2
K Is APQP Required for All Projects? APQP and PPAP 4
S APQP, PPAP and PSW Question from a Rookie APQP and PPAP 4
K APQP requirement when a new print or spec is received from a customer - Existing Part APQP and PPAP 3
C What is the SOEP in APQP? APQP and PPAP 6
S How can I make a Process Flow Diagram for APQP process Manufacturing and Related Processes 2
M APQP and PPAP for Beginners - Where do I start? APQP and PPAP 48
R Looking for good, low cost APQP Software recommendations APQP and PPAP 2
W Certification on AS9100C - FAI or PPAP? Project Management or APQP? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
I Any recommendations on software for managing the APQP, PPAP, PFMEA, Control Plan etc? Quality Assurance and Compliance Software Tools and Solutions 2
L Continental Automotive (or any other big German OEM) APQP list wanted VDA Standards - Germany's Automotive Standards 5
M APQP for Non-Automotive Suppliers APQP and PPAP 6
Q Consult "GM APQP" Step1: Key Stakeholders Meeting - GM 1927-18 APQP and PPAP 5
A APQP in Bombardier APQP and PPAP 1
Q Need guidance new APQP and PPAP Process Improvement Software Idea Quality Assurance and Compliance Software Tools and Solutions 1
S Please Review my APQP Training Material APQP and PPAP 4
Q Electronic APQP System APQP and PPAP 7
T APQP and PPAP in an AS9100 plant APQP and PPAP 2
J Question about APQP Control Plans FMEA and Control Plans 2
J What are the Design Factors in APQP? APQP and PPAP 3
J Three Best Practices and Lessons Learned in APQP APQP and PPAP 1
T PPAP & APQP - What other sectors are Adopting/Adapting these Concepts? APQP and PPAP 14
W Production Trial Run in AIAG APQP and Run at Rate (GP-9) GM 1927 APQP and PPAP 2
L Request APQP Process Internal Audit checklist APQP and PPAP 2
J APQP Project Management in Excel - Many projects APQP and PPAP 8
J Email Reminder through Excel for APQP Planning Excel .xls Spreadsheet Templates and Tools 6
G APQP Timing Plan Template attached APQP and PPAP 3
B Frequently asked PPAP, FMEA, SPC, MSA, APQP & 7QC Tools questions for Interviews Career and Occupation Discussions 1
GURU SDI APQP Procedure For Sand Casting Process APQP and PPAP 6
Jim Wynne APQP, or Why Things Always Go Wrong APQP and PPAP 0
