AQL .65 Level III - Take a particular component off 100% Inspection
shiptowns
I work for a medical device company and I am just learning about AQL's. So I was told by my boss to rationalize why we should be able to take a particular component off 100% inspection and instead use AQL 0.65 level III?
This component has an FPY of 3 failures out of 5114. This component has a high cost.
How does one determine the best AQL level and why this is the best?
How does I rationalize AQL 0.65 level III and why is it right here?
Thank you,
brahmaiah
Thank you,
AQL sampling is not recommended for safety related,critical and high cost parts and assemblies.An external advice for such issuies is not advisable.Your boss is the only competent person to advise you on this.
Although boss is not always right,a subordinate has to work under decipline.
V.J.Brahmaiah
well now it all depends. but in order to give you good advice,we need to understand more about your situation.
(I am in the medical device industry and we don't do 100% inspection at incoming or at final release testing on everything - even critical products or components - and our quality and reliabilty are very high. so it can be done.
is this an incoming inspection test? or is it a final acceptance inspection prior to you shipping the component?
Assuming that it's incoming:
what is the component?
how critical is it to the performance of your product?
Will you catch a defective component in-house, even if thru final test of the product it goes into? Or is there a potential for an escape?
what are the consequences of an escape?
what is the cost in terms of $ and time delay if caught in house?
what defect level can you tolerate in house?
if this is a product you are shipping
what is your label claim concerning performance?
shiptowns
1. The component is a CCD of value of 1.5k.
2. Very critical.
3. It is inspected incoming, and final QC so if defective it will get caught. However, component caught only in incoming QC can be sent back to vendor.
4. No time delay, sincewe get them in batches of 50-200. and so far only 3 out of 5114 have failed in incoming QC.
5. Defect level. We can live with 1-2 failures per month. We recieve 500-600 per month.
6. 1 year warranty.
So how would you rationalize AQL 0.65?
well I wouldn't. remember that a AQL of .65 will allow a defect rate of .65% (or roughly 3-4 defective units per month) to be accepted 95% of the time IF they are present in the lot.
Now your vendor seems to be shipping them at a lower rate than that
(.059%) so a .65 AQL may be safe until your vendor's process gets worse.
*I* would work with the vendor to understand the cause of the defect(s) and require corrective action and/or SPC if the cause(s) are forma factor that could be measured with contiuous data. The I would have the vendor send me the control charts with each batch. The control chart would have ALL lots for the last 6-12 months...
You may suggest a tighter AQL.
why can't you return the part to the vendor is it's caught at final inspection? that seems odd.
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
K Defining Acceptance Quality Level, I need clarity on AQL 1.5, 2.5, 4.0 AQL - Acceptable Quality Level 5
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
V AQL for Component Level and Assembled Finished Product AQL - Acceptable Quality Level 1
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
D What AQL level to use to test LEDs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
N Visible particles inspection in powders for injections. Approaches to AQL level Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
W Application of AQL (Acceptable Quality Level) Concept AQL - Acceptable Quality Level 15
M AQL (Acceptable Quality Level) for Mixed Part Defect IATF 16949 - Automotive Quality Systems Standard 1
S AQL (Acceptable Quality Level) Report Form example wanted AQL - Acceptable Quality Level 1
E AQL Level Change for FDA Validated Unclassified Dental Product Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
T Can I change AQL level from 0.40% to 0.65%? AQL - Acceptable Quality Level 1
Q AQL - How do I determine Acceptable Quality Level (AQL) for In-Process Inspection? AQL - Acceptable Quality Level 2
A What is the purpose of using AQL (Acceptable Quality Level) for Sampling? AQL - Acceptable Quality Level 3
K So confused with AQL - How does AQL (Acceptable Quality Level) fit with my company AQL - Acceptable Quality Level 7
B Choosing Inspection Level and AQL AQL - Acceptable Quality Level 1
Y Advice on this real case on AQL (Acceptable Quality Level)? AQL - Acceptable Quality Level 3
L AQL (Acceptable Quality Level) Question Quality Manager and Management Related Issues 7
M AQL and the impact of increasing Batch Size, or changing Inspection Level AQL - Acceptable Quality Level 2
H Need help with AQL (Acceptable Quality Level) for a QC inspection AQL - Acceptable Quality Level 8
S AQL (Acceptable Quality Level) for Safety Critical Parts AQL - Acceptable Quality Level 13
Q How do you calculate an AQL Confidence Level? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P Calculating Confidence Level and AQL with Increased Sample Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
P Confidence Level in percent (i.e 90 or 95%) at AQL .65? AQL - Acceptable Quality Level 4
N AQL (Acceptable Quality Level) Sampling Plan for Small Lots AQL - Acceptable Quality Level 8
M AQL (Acceptable Quality Level) for Zero Defects AQL - Acceptable Quality Level 13
N AQL - Sampling plan (variable, inspection level ii, normal inspection S-method) AQL - Acceptable Quality Level 2
H AQL (Acceptable Quality Level) for Medical Devices AQL - Acceptable Quality Level 14
M AQL - How to calculate aql and aql level AQL - Acceptable Quality Level 3
M AQL - AOQL - What % equals a certain level of AQL AQL - Acceptable Quality Level 10
Q AQL - How do I find Acceptable Quality Level? AQL - Acceptable Quality Level 75
D Problem with AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 9
D Difficult Inspection Level/AQL - Verifying it is the correct part AQL - Acceptable Quality Level 5
W How to choose the correct General Inspection Level & AQL level...? AQL - Acceptable Quality Level 5
X How to connect AQL to confidence level? AQL - Acceptable Quality Level 2
T What is AQL, Inspection Level, and Type of Inspection AQL - Acceptable Quality Level 16
Y What is the confidence level for a given AQL in zero sampling plan AQL - Acceptable Quality Level 4
C ISO 9001:2000 In Textile Industries - AQL (Acceptable Quality Level) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Using AQL to get true random sampling using General Inspection Level II AQL - Acceptable Quality Level 4
Marc AQL - Acceptable (Assured) Quality Level AQL - Acceptable Quality Level 0
apestate Custom hardware product - What acceptable quality level (AQL) is expected in the US? AQL - Acceptable Quality Level 4
J LTPD (Lot Tolerance Percent Defective) vs. AQL (Acceptable Quality Level) Definitions AQL - Acceptable Quality Level 5
N Setting AQL (Acceptable Quality Level) on C=Zero inspections AQL - Acceptable Quality Level 16
K AQL (Acceptable Quality Level) vs. IRR (Initial Reliability Requirement) AQL - Acceptable Quality Level 6
Marc AQL (Acceptable Quality Level) vs. PPM (Parts per Million) - Equivalences? AQL - Acceptable Quality Level 16
L AQL (Acceptable Quality Level) vs. LTPD (Lot Tolerance Percent Defective) AQL - Acceptable Quality Level 12
R AQL, Consumer Risk and MA Statistical Analysis Tools, Techniques and SPC 2
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
