AQL and Acceptance Plan Clarification
  • Thread starter Plastic Quality
  • Start date
P
Plastic Quality
I am starting to look at acceptance plans and am running into some questions. Help would be appreciated:
1. Why are there c=0 sampling plans as well as sampling plans that allow for the detection of errors, c>0? I am under the impression that either will get you to the same AQL in the end.
2. It seems after reading different posts that
Zero Acceptance Number Sampling Plans by Squeglia is quite recommended. However, I am under the impression that this is for attribute data. My company doesn't use much attribute, but mostly variable data. What method should we use?
3. I have also been reading about MIL STD 105E (something that our company does use, barely- I am trying to change that) and that seems to be obsolete, again, what should my company use instead?
4. (this might be the long one) When using either a c=0 sampling plan or a c>0 plan I have come up with the question, what lot size should I use? We make small injection molded plastic parts with a fast cycle time. I can make 550+ parts per hour. When I look at the sample size for a lot, should I look at per hour, per 8 hour shift, per 24 hour day (we have lights out manufacturing), per month, or per year? We typically inspect parts every 8 hours as an in process inspection. As the lot size increases the amount we need to sample for every 8 hours goes down. I.E. for every 8 hours at 1%AQL I need 50 parts per 8 hours, but if I look at 24 hours of run I need 60 parts across 24 hours, or 20 parts for each inspection. This is HUGE for our small company. If I carry it out further and we estimate we make 1e6 parts per year, then we only need to inspect ~6 parts per inspection period. Where do I set my sample size?
Thank you for your input, I have appreciated the advice found on other threads on this website and am impressed with the knowledge found here on this site.
I'm presed for time right now but can handle the easy ones...
Yes they will BUT they will get you to different rejection levels. a c>0 plan is more discriminating. A recent fad based on misunderstanding statistics has resulted in soem customers and agencies rejecting c>0 plans based since they can't stand it that the lot can be accepted even tho there were actually defects in the lot...even tho an AQL clearly states that some level of defects are allowed in the lot...
2. It seems after reading different posts that [/SIZE]Zero Acceptance Number Sampling Plans by Squeglia is quite recommended. However, I am under the impression that this is for attribute data. My company doesn't use much attribute, but mostly variable data. What method should we use?
If you are using variable data ANSI Z1.9 is the common standard, but you can find other books on it as well.
Mil-Std 105 was replaced by ANSI Z1.4. It is for sampling by attributes so how do you reconcile that with question 2 where you state that you don't use attributes much? (by the way most companies measure in variables data and simply 'convert' to attributes by assigning the variables results as either 'pass' or 'fail'.)
P
Plastic Quality
Mil-Std 105 was replaced by ANSI Z1.4. It si for sampling by attributes so how do you reconile that with question 2 where you state tha tyou dont' use attributes much?
That would be a misuse of Mil-Std 105 on our part. I will address that. Thank you for your assistance.
mdurivage
I reccomend purchasing the book The Handbook of Applied Acceptance Sampling. It pretty much has all the info you will need and more!
Tim Folkerts
As with any sampling decision, it comes down ultimately to economics. If you take one BIG lot, then the total number of items to test goes down (saving money). However, the potential for a BIG problem increases (potentially costing a lot of money). If you use each shift as a lot, then you at most have to reject (or sort) that shift's output when the sampling shows a problem. If you treat the entire year as a lot, and if the sampling shows a problem, you have to deal with rejecting (or sorting) the entire year's production!
Tim F
S Justifying the AQL for a Zero (C=0) Acceptance Plan (Medical Device) AQL - Acceptable Quality Level 6
K Defining Acceptance Quality Level, I need clarity on AQL 1.5, 2.5, 4.0 AQL - Acceptable Quality Level 5
P Setting Acceptance Quality Limits (AQL) for New Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
Q AQL - Can progressive acceptance be used with longer/bigger lots? AQL - Acceptable Quality Level 5
Q Final Inspection lot failures - AQL based final acceptance AQL - Acceptable Quality Level 3
R AQL, Consumer Risk and MA Statistical Analysis Tools, Techniques and SPC 2
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
S ARMY AQL - Requirements which don't have an AQL associated with them Manufacturing and Related Processes 2
M AQL table - I need to sample 1250pcs AQL - Acceptable Quality Level 3
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
V How to interpret AQL sampling tables AQL - Acceptable Quality Level 5
A AQL sampling bags of parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
S AQL Inspector's Rule - bring into CQE Exam? Professional Certifications and Degrees 5
N The question asks about sampling plans and AQL Reliability Analysis - Predictions, Testing and Standards 5
V Receiving Inspection AQL - Am I allowed to just pick a AQL? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
L Established a c=0 "AQL" or "RQL" table AQL - Acceptable Quality Level 5
A AQL Sampling Plan SOP / WI - Medical Device Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
K AQL for Sterile Product - Laminate Tubes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M How to Mathemetically Derive the AQL Tables given Lot Sizes AQL - Acceptable Quality Level 5
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
P RQL/AQL from Attribute Data Six Sigma 1
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
V AQL for Component Level and Assembled Finished Product AQL - Acceptable Quality Level 1
alonFAI AQL and Sampling Size for Components Solderability Test Statistical Analysis Tools, Techniques and SPC 3
A Inspection Plans - How to choose AQL (MIL STD 105E) Excel .xls Spreadsheet Templates and Tools 1
U AQL, Lot Size vs Sampling Plans AQL - Acceptable Quality Level 8
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
P Which Sampling Tables for AQL? Statistical Analysis Tools, Techniques and SPC 6
K Can I use ANSI/AQL for the Total Number of Containers for the entire Lot? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Determining c=0 AQL numbers Misc. Quality Assurance and Business Systems Related Topics 3
L Who and when to determine AQL for our product inspection AQL - Acceptable Quality Level 1
K Verification Sampling vs. AQL - Sampl Sizes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
E Translating AQL to a Production Line Inspection Plan AQL - Acceptable Quality Level 14
S Class III Sampling Plan - Explain AQL vs. 95%C & 90%R Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Training the absolute beginner to understand AQL Training - Internal, External, Online and Distance Learning 1
S What are typical Acceptable Quality Levels (AQL) adopted in Food industry? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
D What AQL level to use to test LEDs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
B AQL Sampling Tables Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Constructing an AQL matrix for our QC operators in a flexographic printing outfit AQL - Acceptable Quality Level 4
N Visible particles inspection in powders for injections. Approaches to AQL level Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
W Application of AQL (Acceptable Quality Level) Concept AQL - Acceptable Quality Level 15
P Deviating from AQL in a small Retail Apparel Company AQL - Acceptable Quality Level 5
M AQL (Acceptable Quality Level) for Mixed Part Defect IATF 16949 - Automotive Quality Systems Standard 1
