AQL Sampling Plan based upon ISO 2859
01mercy
Hi all,
I need to make a sampling plan for our material produced.
In our factory we begin with rollstock and we produce sheets out of the rollstock...it's sliced.
Now based on ISO2859-1 and the AQL levels that customers wanted us to apply I tried to figure out what was the most workable AQL batch size to maintain.
Since we produce 2 batches a 5 rollstock each a day you will understand what impact AQL sampling will have if we use the produced batches as an AQL batch size. Sure we don't need to sample a lot but if we find defects this will have tremendous influence.
I understood that within a sample plan I can switch from;
reduced to normal to tightened.
Is it also possible to make a variable sample plan.
Like;
*Sample taking on batch lvl -> to many defects -> go sample taking on roll lvl
*Sample taking on roll lvl -> to many defects -> go sample taking on sheet lvl
*Sample taking on sheet lvl -> to many defects -> reject sheet (possible rework after taking out defects)
Such a plan would save us a lot of waste material but I don't know how I should determine if we work within the given AQL lvl's.
Does anyone have a suggestion for me?
(attached I have a draft of my calculation on sample sizes)
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
A AQL Sampling Plan SOP / WI - Medical Device Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
S Class III Sampling Plan - Explain AQL vs. 95%C & 90%R Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F AQL - ISO 3951-4:2011 Sampling Plan Requirements AQL - Acceptable Quality Level 2
P Why sample size for c=0 sampling plan reduces across the increases of AQL AQL - Acceptable Quality Level 2
N AQL (Acceptable Quality Level) Sampling Plan for Small Lots AQL - Acceptable Quality Level 8
N AQL - Sampling plan (variable, inspection level ii, normal inspection S-method) AQL - Acceptable Quality Level 2
B Sampling Plan - AQL effect on Sample Size AQL - Acceptable Quality Level 9
P AQL and Sampling Plan as they relate to Functional In-Process Inspections AQL - Acceptable Quality Level 4
Y What is the confidence level for a given AQL in zero sampling plan AQL - Acceptable Quality Level 4
W AQL and RQL Calculation for Variables Sampling Plan AQL - Acceptable Quality Level 8
V How to interpret AQL sampling tables AQL - Acceptable Quality Level 5
A AQL sampling bags of parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
N The question asks about sampling plans and AQL Reliability Analysis - Predictions, Testing and Standards 5
alonFAI AQL and Sampling Size for Components Solderability Test Statistical Analysis Tools, Techniques and SPC 3
U AQL, Lot Size vs Sampling Plans AQL - Acceptable Quality Level 8
P Which Sampling Tables for AQL? Statistical Analysis Tools, Techniques and SPC 6
K Verification Sampling vs. AQL - Sampl Sizes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B AQL Sampling Tables Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
R Is AQL sampling plans applicable for Bulk Pharmaceutical Manufacturing (API)? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
A What is the purpose of using AQL (Acceptable Quality Level) for Sampling? AQL - Acceptable Quality Level 3
J Sampling Plans - AQL Table Application AQL - Acceptable Quality Level 2
C C=0 vs. AQL MIL Standard 105 E - Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
A AQL Tables or Binomial/Poisson Method? Attribute Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J Incoming Inspection AQL Sampling of Bulk Textiles AQL - Acceptable Quality Level 3
H How to decide AQL value? Sampling Plans AQL - Acceptable Quality Level 5
A What is a good lot size? We use the C=0 Sampling plans at AQL %1.0 AQL - Acceptable Quality Level 9
A Use of sampling plans like MIL-STD-105 E or ANSI Z1.4 for setting AQL's? AQL - Acceptable Quality Level 13
M Sampling AQL - Am I understanding it correctly? AQL - Acceptable Quality Level 2
S Using AQL to get true random sampling using General Inspection Level II AQL - Acceptable Quality Level 4
M Sampling a continuous process - How to use AQL with a continuous process AQL - Acceptable Quality Level 6
R AQL, Consumer Risk and MA Statistical Analysis Tools, Techniques and SPC 2
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
S ARMY AQL - Requirements which don't have an AQL associated with them Manufacturing and Related Processes 2
M AQL table - I need to sample 1250pcs AQL - Acceptable Quality Level 3
S AQL Inspector's Rule - bring into CQE Exam? Professional Certifications and Degrees 5
K Defining Acceptance Quality Level, I need clarity on AQL 1.5, 2.5, 4.0 AQL - Acceptable Quality Level 5
V Receiving Inspection AQL - Am I allowed to just pick a AQL? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
L Established a c=0 "AQL" or "RQL" table AQL - Acceptable Quality Level 5
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
P Setting Acceptance Quality Limits (AQL) for New Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
K AQL for Sterile Product - Laminate Tubes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M How to Mathemetically Derive the AQL Tables given Lot Sizes AQL - Acceptable Quality Level 5
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
